View Full Version : LT1 Based Engine Tech
- what do you think ill dyno at and run
- Freaking top speed limiter
- $355 to re-install stock flywheel
- crank, crank, crank, no start
- Noise normal?
- backspacing and bolt circle for skinnies
- Might As Well Ask The Experts...
- Intake delemma
- got an SES light while driving after removing EGR on OBD1??? wtf?
- Tapping bolt threads
- Limitations on Stock Internals?
- Before and after dyno #'s of XE 224/230!
- Split-lock Mechanical Header Bolts
- How much lift can the stock springs handle? I already tried a search
- t56 trannie
- Rear End Damage? HELP!!
- Went over some bumps and my opti ate something
- Hooker or Loudmouth?
- If the SES light has been on for months non-stop...
- rear end cover options?
- fire sleeve concern
- Anyone in the Dallas area know where a GOOD transmission shop is?
- Gmmg Borla Or Corsa
- DFCO in tuner cat
- T56 tranny problem...
- What to put on intake gaskets
- I have firebird parts book I'll post if someone can host it.
- Possible for valve covers to leak?
- XE 224/230 and pushrods
- Need quick spark plug help
- Recaro Seat Brackets 93Z28
- z28/SS
- Anyone ever figure out the problem on an OBD1 car with a 3000+ stall?
- i-pipe & crossmember rattle
- cut-outs
- Ignition woes, changed everything imaginable
- rattling noise
- How much or will it work?
- Low end question for High end people
- Need help from TC/Trans-Go guys
- cam+stall= no overdrive
- Low RPM Stumble and Knock
- SLP's speedo recalibration part #? (I searched)
- Battery exploded!!! Need help diagnosing a no start condition.
- OK... finally got the money... need to know what constitutes a rebuild or new tranny
- Funny smell
- Catback right for me?
- Torque Converter
- Car misses only when hot?
- Panhard Bar
- any advice
- Coolant rushing into "overflow" after car is turned off....
- what kind of sound difference are we talking here??
- anyone else have problems geting crank hub off ?
- cutout=gas smell?
- Still haveing problems with window.....
- PN for intake manifold bolts
- cutout installed! also fuel pump question
- What is the best Cam/Head street setup?
- SES is on, but I pulled no codes...help
- Do I need tuning? What can i do in tunercat?
- what would my car sound like with hooker headers, highflow cat and cutout?
- Loud Poping noise comeing from left front????
- problems with my 4L60E, help please...
- Good cam/rr install site.... I lost mine and couldn't find it in search....
- OK guys, what is the best carrier to run in a 10 bolt ???
- Which Tranny Cooler???
- burning plug wires
- need help with components
- Can a faulty harness to the air pump cause not to start?
- Can I use 94 95 headers on my 97?
- dynomax???
- A little off
- I'm a bit confused with programming.
- Leaking coolant
- Track results finally...problem though
- Need immediate help... Car wont start.. wont even try and turn over
- Suspension Question? Help!
- idler pulley options,..
- can mismounted front shock screw up alingment?
- Gasket vs Gasket Maker????
- Simple question about Pushrods, just need someone to clarify
- Pics of your magnaflow exhaust
- Good times?
- good clutch????
- installation of HOT cam kit
- Break-in procedures for torque converter
- OBD conversion
- Cracked Dashboard
- How do I remove the foglight?
- This is It, Car Wont Start, Backfires, Changed Since Last Time I posted
- Suspension: How long?
- I have a problem
- quick question
- 4.10 gear in an A4??
- G2 TA Girdle, stud sheared off!
- Paging Shoebox??
- Is Superchips programmer worth the money?
- Are all stock fuel pressure regulators the same?
- Do stock throttle bodies from the factory come with an air foil?
- gload brace torque arm mount ?'s
- freescan how-to?
- Stumble at highway speed in OD, please help
- HELP, NEED Y-PIPE for LT's by FRIDAY!!!!!
- News on Mosers' Death
- Is My WP Shot???
- Would RR'r CLACK Louder with Bigger Cam???
- Not a normal hotcam question!
- Hesitation/Stumble Theory: Let me know what you think!
- FLP Long Tube header (emmisions) question...
- How loud are roller tiped rockers supposed to be??
- Name that clunk... Rear or trans
- tire ?
- How do these mods sound?
- Who did your PCM tuning?
- where's my rev limiter
- What could this be
- lets talk tranny fluid!
- Flushing the rad
- 1LE tranny mount still exist?
- Running rich and rough at idle
- I am changing my Fuel pump and going in from the top any suggestions?
- Transmissin help
- !EGR, did i do it right? (pics)
- Fuel pump change now flames under car!!!
- Head gaskets install (grease it or no?)
- !newb question, how to drain brake fluid?
- what shifter to buy for M6
- whats a safe shifting point???
- cam idle
- Polyurethane Torque arm mounts?
- The Next Step......?
- will the obd1 pcm from a caprice work in my 96 TA?
- plug change from the top
- where can i get an obd1 pcm?
- Coolant Flow Restrictor Valve
- Which Timing chain to Get
- Dyno numbers for my heads/cam 236/242!!
- post for SLP LM 4 297
- Auto Shifter removal
- Really..Really stupid question...
- cars with K&N FIPK....
- Anyone with loudmouths notice?
- Tick when warm, fine when cold, WTF?
- injectors
- Friends car having problems...
- Wrench size on Hypertech AFPR
- Check Out The Ride!!
- It's Alive!!!!!!!!!!!!!!!!!
- Need help QUICK!!!
- If you don't clear your codes???
- 2.73 gear swap
- Is the LT4 HOTCAM upgrade kit worth it ? ...
- Exhaust and Rear end
- Bogging at over 1/2 thottle
- 150 shot. What kind of times can I turn?
- heads hp gain?
- harmonic balancer removal question
- Severe hesitation/stumbling problem
- Longtubes with Emission Hookups
- Dynoed car today and some white smoke seeped out of tailpipes on decel?
- help me pick a clutch!!
- Those with dynatech longtubes
- Should I be concearned?
- Question on Air/EGR
- asdf
- So whats your opinion on coil overs?
- Scanner battery voltage readings?
- Keyed hub
- Getting fuel lines off!!!!
- Keep blowing the fan fuse
- NOS kit for LT1, wet
- Dyno results
- Help choosing a shiftkit for my car.
- Motor Mounts...................
- how do you get the !#$& fuel rail off?
- Does anyone have experience repairing SMC? (The stuff our doors are made out of)
- Tranny temp guage. is it working?
- My starter solenoid literally ripped from my starter!
- Anybody switched from a cc305 to a xe224/230, xe230/236, or similar?
- What extra gauges do you have?
- Autometer Oil Pressure gauge...
- Eibach ProKit Springs Front?/Rear?
- If Im using SVO's and my FP is 50 psi...
- Engine Problems...HELP!
- Gettin rid of AIR...?
- T56 six speed speedometer question
- Racetronics dual pump system ....?
- Is there an "ideal" year LT1 to get?
- Did anyone get their heads and intake ported and polished?
- Paging Madwolf............
- What gap for TR55 plugs
- Injector Size
- OBDII trouble code: Trans Component Slipping
- your engine rpm at freeway speeds
- Where do I ground tranny temp guage to the engine?
- Secyrity light (did a search already!)
- What is an engine ground? Need quick answer please
- Greg Moser Died
- how much hp diff with cc305
- D-Day has arrived for my Bolt-On LT1!!!
- BMR DS Loop/Lowered car
- Optimum shift point for a stockish LT1
- I need a muffler
- installing new waterpump.
- Auto Trans Am
- All LT1 Gurus Inside... a true Stumper question at my expense
- HELP! Need pics
- Ran out of Gas help????
- Driveshaft Safty loop
- Head Gaskets which one???
- Bad vibrations after lowering
- How much are LT4 roller rockers from Jason Cromer?
- Scantool.net
- left front wheel squeaking/screeching?
- 2nd to 3rd shift, A4 guys inside???
- Miss at idle.
- Part # for 1-LE AC-Delete pulley?
- aftermarket accesories?
- Engine Cutting out.....?
- OBD-II scanners
- It is solved! Pics within!
- cheveron supreme oil???
- Can a fuel pump go bad, but still "sound" good?
- Help me...My car is broke again.....
- Rotor/Pads install tomorrow
- Rear shocks and springs/both at once
- 230/236 cam and 700r4 are IN!!!!!
- Will my starter work?
- Not sure about my antifreeze...
- Which clutch now?
- SLP headers vs Hooker Headers
- speed pro F.A.S.T.
- XE230/236 dyno numbers finally
- Iceing The Intake?
- OMG!!!! look what i did.....
- PCMFORLESS tuning... NEED HELP ASAP... FANS ARE STAYING ON
- How to combat low MAP and TPS? Fred? Rob?
- How Loud ?????
- Stock Waterpump Vs. Electric Wp
- Gas Gauge Problem!
- me and this dam trans are gonna fight!
- Looks like my walbro pump increased my FP....
- Valve Springs for GM847 and 1.6 Rockers?
- Bosch plug guys which wires you like?
- Hypertech power programmer?
- *QUICK* Where could I find....
- GTP Stage 2 Flow #'s?
- Code p1441
- Opti-Spark Question
