View Full Version : LT1 Based Engine Tech
- last minute header question
- Hypertech power pulley coming off,is it the only one?
- Cleaning under the hood
- How to remove the IAC?
- Part # for headlight and brake light.
- Identify this part!
- Slotted rotors
- firebird trouble
- where to find....
- Headers
- Moser 12 bolt owners PLEASE HELP, check out this pic....
- Damn Brakes...ANyone else stumped on a Low to almost NO pedal?
- Knock retard...Real or not how to tell.
- Lt4 conv., Speed Inc. dyno #'s
- TB bypass? Good or bad?
- Stock LT1
- those w/ jet hot lts what y-pipe did you use?
- Who turned out the lights??????????
- 3200-3400 stahl too much for LT1???
- Voltage drop
- 550 hp on 383
- LT1 rebuild options since motor will be out...
- LT1 Guru's inside ... Need Help ASAP
- Well I think I found the problem inside my tranny *pics*
- What brand tires are you guys running?
- How much for this TA
- Page For Shoebox
- Is it possible to find out the stahl of a converter before it's installed?
- Please help with BAD low end hesitation w. new engine
- Rethinking cam selection..........any advice?
- noticable diff between modded exhaust & cutout?
- Please..Help me decide...100shot or CC306??? *POLL*
- how much would an average LT1 go for?
- installing a shift light in a '93
- durability: LT1 vs LS1
- check guages light has issues!!
- What Y-pipe and gaskets to use with Jet Hot LT's???
- Using tq to yeild head bolts have a ?'s
- emmision and o2 question
- Not turning over
- Got a new ignition box, and I think I've found the best bang for the buck box
- o2 sims '95
- what are the best swap in gears?
- idle in drive is horrible!!! The IAC steps count shoot up to 140's
- Thanks for the help guys!!
- LT4 Cam swap
- Hooker LT's or Jet Hot LT's???
- Degreeing the Cam
- Autozone Wires?
- Changing O2 Sensors
- just bought exhaust system
- Quick A/F Question
- WS6 "smooth bellows" scam on eBay
- which radiator hose is this....?
- what kind of headers?
- big stall ~ little gears
- Need cam (new to camaro's)
- Went to track, couldnt be more pissed off
- stumble solved?
- which heads are the best?
- Coolant Light is on for no reason!
- BMR Trak-Pak
- Smog Pass
- Spark plug change.....try this
- new pilot bushing looks different than old one, is this normal?
- Running W/ No muffler..will it gain HP??
- Standstill...How bad for brakes?
- M6's w/4:10's...
- Any stand alone shift lights?
- posible misfire????
- What the heck is this???
- I want to run 13's What will it take? not to much blow...
- O2 Sensor Question....
- Car Dieing Problem. Random....
- Evil Red Fluid
- weird noise?! please help
- Recharge the air conditioner system?
- Power gains from stepping up to the cc305 from cc304
- ..crank balancer question
- Cracked rod... new radiator needed?
- xe 224/230 is in
- Harwood Hoods
- MSD Digital 6 Wiring question HELP!!
- take off intake manifold gaskets
- help cant launch
- i need some help
- 04' Grand Prix trip-tronic for F-bodies?
- Last bolt on Headers
- Looks like I will need a opti I feel......
- how to convert to ram air box? help
- t-tops
- help me figure out my problem
- LT1 Headers
- what else is needed for a cc305??
- LT4 Hot cam with LT4 valve springs...
- battery amp output?
- Ground on intake manifold ? Shoebox ???
- Clutch went out today need some help
- Used seafoam to clean out engine before changing oil and it GELLED??!?
- I have a rough idle and...
- Odd Tapping Felt Through My Clutch Pedal
- Ltcc Lt1 To Ls1 Ignition Coil Conversion Lt4
- 49K motor, heads and cam, burning oil only above 4K... is it the rocker arms?
- Coolent in oil
- Street Rod Nationals in Louisville, Ky... loads of cars with LT-1's and many vendors!
- New ICM, still not starting!
- About to replace my starter and solenoid...anything to look out for?
- Should I put my old o2's in to seafoam my engine???
- new seats
- Can I get one(1) lifter out without yanking the intake???
- Wiring Up Air/Fuel ratio gauge
- car won't start
- Need help on choosing bottom end(383).
- Backfiring
- A4 cars with big cams???
- Request General Cam Info
- Hotwiring the fuel pump
- weight of custom wheels
- cleaning rims
- Will ET Streets blow my rear?
- LT1 Scanmaster Install
- Please help to get my new motor w/cc305 etc to run right.
- POP when braking moderately
- LT1 to LT4 conversion kit
- SS w/ ile driveshaft
- Got $700 to spend go with converter or LT's???
- Ditchin the Magnaflow for Loudmouth
- Car loaded down, vibrations were worse
- Need some help again lt1 guys
- Anyone ever modify the Ypipe where it connects to th eheader?
- LT1 Oil Problem
- Turn signal
- Stage 8 header bolts
- moving battery to rear, what do you do with accessory wires?
- vibration still
- Normal RPM at idal
- scyzoryk Needs to respond!!!!
- Rack and Pinion Serious problem
- TB differences?
- stock y pipe do you have one, i want it
- Rear main seal
- Anyone have the new Hooker y pipe?
- Remove cai for line lock?
- Need help lots of power loss
- insurance question
- Can this mess up my PCM?
- Problem wasn't Opti, Now What?
- T56 Pilot Bearing
- yes or no: hotchkiss strut tower brace?
- Is there a straight thru muffler w/ 4" inlet and dual outlets?
- tell me what I need
- Takes 2 hands to get into Reverse on 6spd help
- Battery problems! Need help
- What size injectors?
- plugs?
- non-vented to vented opti
- Rear-end noise; sounds like bad tire but isn't
- Valve Spring Question
- Correct torque for hub/bearing bolts?
- Th350 Or Th400
- Where can I get heads/intake ported and polished in PA?
- 96 LT1 will not start on hot days.
- hydrolocking??
- Low Tracktion warning?
- Bose stereo speakers?
- new cat
- Please quick: need help with wiring
- Went to the track with new mods
- Popping out of reverse
- Hesistation off line
- Speedometer not working
- Hard starting problem?
- one bank normal, other bank rich
- Breaking in sollid roller
- 52mm -VS- 58mm
- Quitest F-body exhaust and still make power?
- How to use seafoam?
- solid roller info please:)
- limited slip
- Is this lean because of tuning or the open headers?
- If I upgrade to a Torsen, do I need a new cover??
- Tranny Cooler Location
- What is the widest tire to fit on a 9.5" rim?
- Damn car.
- thermostats?
- Info/help/tips on diy head porting
- LT1 Roller Rockers?
- parking break help
- What wpuld be the best cam for me...
- headers gasket for brodix track 1 teh same for lt1?
- qucik fan mod question
- 18x8.5 wheels a good thing??
- supercharger question
- Replacing the reverse gear syncromesh
- Street Twin adjustable master cylinder
- is having different offset wheels up front really bad?
- Major Fuel Injector Problem ... need help ?
- Trans problem is p!ssing me off!
- normal oil pressure
- OBDII code lookup
- AC prob, sometimes it doesn't go on, then restart car it works.....
- oil pressure problem?!?!
- squek squek squek
- What year silverado pan and where do I find them?
- valve cover leaks
- Great Tool to learn about Cause and effect of cams
- S&W Racing SFCs
- Hey Fred, you need to update your website
- how often can you do seafoam???
- Clean that MAF
- quick question about sercurity feature..
- possible to hook up the abs on a TC rear on a non TC car.
- took my car to the dealer! wow what a estimate!
- Water pumps?
- What do you think about bullet mufflers??
- Question About Headers
- LT1 powder coated Intake, ported for 58mm TB needed...WHERE...
- Lean condition after header install, is it bad?
- valves why no 2.02 int 1.60 ext???????????
- Oil leaks *PICS*
- reasons for high idle?
- best radiator hoses?
- Ticking lifter???????
- Touch up paint
- Opti question
- About to go to track, what should i run??
- Which oil?
- New Track times. better but dissapointing
- stereo locked
- opinions on this set up??
- optima batteries
- I just got my car back with new mods........does this sound right or something wrong?
- Shorty Headers...what kind of gains?
- Cleaning the IAC
- Car took a crap!!!
- Product Opinions Welcomed
- Mod Bug Bites Again
- paint codes?
- how to tell if intake leak fix worked???
- SLP Take-out Posi Install?
- Another Dead End
- Anyone have experience with these companies?
- ram air induction hood
- wierd trans problem
- which swap would be better, ls1/GN?
- Using a bullet as an ORP
- Reinstalling clutch fork
- Clutch Problems HELP!!!!!!
- Need some help!!! Lookin for a G2 cold air piece...
- where to buy block off plates
