View Full Version : LT1 Based Engine Tech
- low antifreeze???
- Can I run Leaded Fuel?
- LE2 setup running rich on start up
- OPti replacement alternative
- Recirculating radiator catch can question
- What carb style single plane intake are using on your LTx's??
- What is thsi part?
- XE, XE-high lift, XE-R, XFI Cam Lobes...Who knows what the differecnes are?
- HP Estimate.
- which of the 2 is better forged piston
- Diagnostic help please?
- need some more grunt any ideas?
- High knock count after plug change?
- Before and after videos of fixing ECT sensor connection!!
- Thought I would share my optispark problem
- Plz help me id this roller cam
- Almost done this friggin V8 swap, need some help...lt1 guys...
- What is this wire?
- Seafoam
- i need forged pistons 30over uses 6inch rod
- abs inop
- Who's LT1 cam is this?
- no start after taking N20 off
- coolent level sensor HELP
- hose from passenger value cover to tb
- no start!
- Alternator Relocation Brackets?
- Goal - Street/Strip LT1 - DD
- What bolt ons am i missing?
- what do i call it?
- AIR delete question
- Camaro Lt1
- Stumbling/missing under 1700rpm
- Oil Leak from Water Pump Driveshaft
- Lt1 sparking randomly
- 1.6 roller rockers
- Which timing chain set.
- check engine light
- calculate overlap?
- Back fire!
- Another Problem (Over Heating)
- Plug wire Question?
- P1sc LT1 vs. GM847 LT1
- Urgent Need Help With Timing Cover
- My 383 @ idle w/ 3" True Dual + H-pipe + (2) Dynomax bullets video
- LTCC coil install W/Pics
- code help please
- AFR (GTP) Lt4 heads ????
- Engine rebuild in Maryland
- LE2 guys cam surge?
- wierd stumble
- plug wire ideas
- Can i remove the Air pump silenoid?
- After leaving window open in a down pour, car wont start.
- Diagnosing a bad Opti
- Throttle Body
- Video of me on gainesville's "roadcoarse"
- Home Ported Intake Pictures
- what kind of oil after rebuil?
- new lifters help wanted
- What is the best Header Gasket!!
- new damper and fuel pump?
- spark plug threads
- question about plugs
- Stumble at mid-throttle or higher, idle RPM erratic
- PCV Valve in a 97
- Engine Sputtering problem
- 150 shot of nitrous on 383 speed pro pistons
- Broken Starter Nose?
- Ok to not use oil windage tray?
- On a 94 Does the cam have 1 location for opti gear?????
- Motor shaking!
- Valve covers
- Anybody ever changed heater core hose assembly?
- Deleting the air pump question?
- How do you know when O2's need to be replaced?
- Hose coming from below going to intake?
- Exhaust Manifold Question
- Please help with front oil leak
- 1.6rrs and tune
- Whats the difference?
- engine rebuild $$questions
- "Unknown coolant loss"
- Part number for ARP crank bolt?
- so
- Low Rpm stumble.
- What causes a ring land to break???
- crank case leaking oil
- 96 Z28 Camaro - fans not working
- caprice bottom end
- 383 LE2 Dyno#s and bad track times.lol VIDS also
- crane rockers
- I want to shoot my car!
- Need more Top end
- Remounting the coil-need some help
- o2 extensions
- 93 z-28
- Help me troubleshoot / reconfigure my GM847 setup...
- Shorty VS LT Dyno
- What are the chances, LOL
- Shortblock is assembled (pics) :D
- 1995 lt1 no power
- its this enough to beat a terminator?
- Just got back from the track (was i wrong lol)
- Bad Problems
- balancer position
- Longtubes Question
- TTT car is dying randomly
- alternator brackets
- Question about harmonic balancer installation
- Shifting
- Fabricating 93 EGR / AIR smog lines
- What did I just break?
- New Engine problems...Please help!!!!
- Need some help! Car died.... Ideas????
- Optispark question (vented non-vented)
- Corvette oil temp sensor?
- ? about Engine oil breather vs Oil cap for LT1
- Quick CC306 valve spring question
- 11.48 ET on second hand LE2s
- roller rockers = sewing machine
- Car wont hold antifreeze?
- Need some veteran knowledge
- ahhhh someone help me!
- Spark Plug wires question?
- Istalling heads and got oil on new 1074 gaskets
- Cam only question
- 129,600 miles
- Pacesetter LT header questions
- 129,000 lt1
- pipe on exhaust manifold to intake
- Fast Wideband and OBD1 conversion?'s
- Someone please help. LT1 overheating
- Some 383 Questions
- CC306 question
- Ac Delco Wires Questions????
- 1.6rr/valve Spring Install Done. Webpage Walkthough Posted.
- A/C question. code 71
- Check Engine Light 93 Camaro
- lt4 hot cam gas mileage??
- hotcam kit! New timing?
- replace procharger or go heads and cam
- LT1 multiple random misfire(code 300)i need help fellas
- LT1 wont start
- TTT Car is having issues running...
- modifying the stock TB, MY WAY
- 93 LT1 Damper Removal Help Needed!
- P0135 - a question after searching
- Fuel Injectors
- Valve Covers?
- New Opti Question (Shaft O-ring)
- weird dyno graph...suggestions?
- will my h/c lt1 have a chance on sts ls1?
- Help? Lt1 coolant light
- Code Reader
- Link to LTx Shootout Results from 4/19
- Ram Air Question:::
- help
- Need Some advice Please!
- 383 fuel setup
- Automatic transmission...
- LT4 Cam kit
- huge miss 4000rpm
- Fuel issue
- SES Problem
- I think I have a quantum misfire
- Oil leak possibilities?
- i want my car back guys!!!
- Buy a used motor or do a rebuild?
- Yet another misfire thread...
- Need Help: Ignition/Fuel/Tune Problem Inside
- I've got a SES, help!
- 383 Build with 3.8" Stroke Cola Crank
- Ran my 97 the other night.
- Did the LT4 have lash caps on the valve stems?
- Noisy LT1
- what do you guys think? i need help.
- 98 LS1 Ram Air box
- Any1 ever change the oil filter adapter gasket?
- !egr question..
- help coolant in passenger floorboard . . .
- No Oil Flow to LS 1 Cam and Lifters
- Question on TB hose barb
- Waterpump heater hose inlet.
- My V6 to V8 conversion, 56k warning
- Slight coolant smell once in awhile
- Help with Hose situation!!!!.......
- Bad Opti Always throw a code?
- coil bracket?
- Dont own a camaro but do have a lt1 engine question
- 400+hp on stock bottom end with h/c setup?
- Need help!!!! (check engine light)
- Headers and rockers, MPG increase?
- moly or cast iron? help
- Fuel Leak
- New engine started and idled fine, until Code 43...
- opewn header ?
- Help.. what valve seals for this dual spring??
- Code 45 MAF System Failure
- 383 cutting out after gets hot.
- track #s le2 383 BRE cam
- Stock LT1 Rebuild
- EGR question on a 96z
- LT1 OBDII Tuning Software
- 1.6 RR's
- 3 dyno runs to help tune car
- Jegs oil pan
- Rocker Stud Question
- took my z to the track today
- TFS/AI 383 dyno results (need tuning ha)
- Need part number and source for ....
- Fuel Pump Going?
- Progress pics of my cam swap
- Engine Swap
- Rear main
- Rocker Height Mid-Lift Plan
- Bleed cooling system?
- 93 camaro heads
- Power loss
- These Mods with 111k miles?
- Heads to come off..should I keep these LE2 heads with the LPE 211/219 cam?
- opti vacuum lines????
- Hooker Headers..
- Cam Thrust Washer Question
- Red light coming "on"?
- Gasket Package for Cam Change
- Scorpion Roller Rockers
- Question on set i found?
- Bad front O2 cause bad mileage?
- Optispark ? or IAC
- Kinda bummed here
- Running rich and weird idle
- A/C Compressor Clutch
- 0.060 over
- Motor pinging underload
- Intake Manifold Leak
- Recommend me a good shop in Ky. area
- Whos using dual coil valve springs on LT1 heads?
- Narrow Body vs. Regular?
- P1641,42
- lt1 or ls1 question
- after replacing parts, still missing/bogging/low idle
- Waterpump seal for timing cover
- 383 guys come take a look...
- WHAT TYPE OF HEADERS FOR '95 CAMARO 383 Stroker?
- at what rpm you guys shifting w/ cc503
- Best way to remove LT1 knock sensor?
- valve lash question
- Need some help guys...No Start
