View Full Version : LT1 Based Engine Tech
- How hard on a clutch?
- piston install question
- th350 swappers look inside
- opti
- I need a tunercat file for xe230/236 and ported heads
- Eibach Drag Launch Springs
- How Good Are These Ported Heads?
- Looking at a used car.
- HELP!: Knock sensor
- How hard is to pull heads out?
- will it fit?
- Just took off the Air
- proper cam break-in procedure?
- Whats different between F-body and Impala LT1(wiring, computer, accessories)
- Bye bye Loudmouth...
- O2 extensions....
- 94 4l60e into a 97 camaro
- Oil In Coolant
- 6 speed and 4.56's (urgent)
- tuning questions
- Nooooo!! I think I broke that little plastic thing that goes around the shift boot..
- Is anyone doing the PCM chipping and recovery?
- replace egr, map sensor, o2 sensor?
- Best sounding exhaust for a S/C'd 383?
- Pcm4less where do i send my pcm
- Connecting rods
- Help !!!!!!! Car will not start!!!!!!!!!!!!
- Need Help!
- ignition switch replacement
- Blackouts?
- wierd z??
- Is this an Intake Manifold Leak?
- Need help with valve lash adjustment
- Header leak and O2 sensor
- Installing vortech supercharger on 118,xxx LT1?
- Tunnel Brace
- Need ASAP, cam bolt thread sizes?
- Lower A Arms?
- Whats he going to run?
- how can i take the brake pads out to paint my caliper?
- Need help fast plz :D
- Rear end grenaded, what to get and where?
- Anybody done a LT1 swap into a non-LT-1
- Need a link to the LT1 vs L98 differances
- Rocker stud problem. Not sure what to do.
- what to adjust in stock valve covers to clear 1.6rr's?
- STB in....stupid suspension ?s.....
- crank bearing clearance
- feels like car is missing
- What kind of ZIF socket for PCM?
- Need help quick T56 ???'s
- cam and heads intsall and now car won't idle.
- need a lil input
- Clutch hooped after less than 20,000km... comments please
- TA Differential Cover and Stud Install Guide?
- Need a new exhaust for my heads/cam car, which one???
- PCM 4 Less/Madz28 - Now or Later?
- Clever lil code, but what does it mean? - MALF 11
- Iac
- hole in fire wall for wires??
- Replaced Opti - Out of time
- Which wires for the dome light under the dash?
- 94 LT-1 wiring codes for swapping into a 94 Blazer
- throttle cable????
- Anyone have stock dyno chart for LT1?
- Are 12.6xx's respectable times for bolt-on only LT1's?
- Best exhaust system under $300?
- Girdle and drag radials?
- Tips or Hints on Timing set upgrade
- Transmission cooler lines leaking on 93
- Intake Hiss on project car
- Stupid Question #3: Reinstalling the Opti
- Stupid Question #2: Degreeing LT4 hotcam??
- Clunking Gears.
- Which fuel pump?
- Injector size for a 383 solid roller
- thinkin of buying a 95 z28
- Looking at a 94 Camaro Z28
- Leaking taillights
- Converting Speed density to MAF
- Transmission clunk....please help!!
- Got the trans out
- got my dynaspark in!
- cc306 at idle video or sound clip
- Resistor for OBDI
- anyone running a crane 222/230 cam?
- spring tuning
- lt1 swap question
- update on low rpm miss/surge/lunge
- Change in Pushrod length
- Camshaft Endplay
- OVC wires and ASR "box"?
- Autolite 605's???
- Taking off oil cooler
- Battery Tie-Down?
- Please Please Please Help
- Low Oil Pressure!!
- 1.7 60' on Lowered m6 with nitto!
- T/B bypass
- healthy RPM range???
- Water pump intermediate drive unit: a replacement item?
- Stage 8 bolts, 1" or 3/4"?
- What makes oil turn black?
- What does a New pilot bearing go for?
- this is getting so old!!! OVERHEATING
- Gotta serious problem!!!
- Cam
- Who does the best head work?
- dealing with Jim Winn
- Brake Upgrade?
- Those with Elec. Cutout~>opinions please!
- Anyone have sound clips of Slp2otl&Lts
- Coolant overflow tank and battery tray one assembly?
- Which is colder, Autolite 103 or 104? What one range colder than them?
- Borla Installed
- Cam is in and it is tuned.
- mac headers - unavoidable leak on driver's side collector?
- power window not working
- Why is my AC/HEAT only blowing at my feet?
- Gear swap question...
- LT4 KM necissary?
- Anybody paint there engine bay? What paint did you use?
- gtp heads
- Stock plug gap size?
- please help! how do i know if thermostat is broken?
- What is slowing my car down......
- Reinstalling rear main seal housing onto block, need RTV?
- Installing Jethots on m6
- Jet Hot LT AIR hookup size???? HELP!!!!
- Firebird owners with K&N FIPK
- Look at my homemade intake
- Car won't start
- Timing chain ?
- Where could I get my hands on a roll bar for a 95 Convertible?
- quick speedometer question
- Can I run Weld Pro Stars on the road legal?
- Need harmonic balancer hub installer ASAP!
- How many of you burn plug wire #5 with long tubes???
- WOT Air/Fuel Ratio
- Guys Please Help My Car!!
- Removing The Oil Cooler?!?!?
- easier to cut cag wires instead of pulling them??
- Clutch/flyheel recommendations?
- Will a car even turn over if the PCM is dead?
- Posi Rear
- All that have taken their engine's out...
- Borla install withOUT a Sawzall. Need suggestions.
- LT4 KM in.....results
- 5 Codes??? P0100, P0141, P0400, P1641, P1642
- proper way to change or add coolant??
- Opinions on my engine project!
- anyone replace they PCV valve? need help
- Anyone ever use Castrol Gear Oil?
- Anyone have trouble with 91 Octane
- What Octane do most people use?
- quick audio wiring question.....
- Help!
- Electric Water Pump Reliability and CAM choice
- 3.73 Gear Help
- Automatic Trans. Problems
- Firebird guys w/ headlight motor probs
- Help! quick question!!!!
- Need to know ASAP will factory salad shooters fit on a 72 Camaro?
- Grrr!! TB Bypass Help Needed w/n
- Why don't more people try for 11's?
- TCC valve for tranny where to get it
- what is the quietest and best flowing cat back
- XE 230/236 ?'s regarding stock fuel system and 3" exhaust...
- man ...what did i do now!!!!
- can a 93 take the LT4 KM?
- 561 heads
- F-Body noob needs some advice
- HELP, SES code driving me insane
- Where can I buy a 4 bolt main block in CA, ASAP?
- Cross threaded header bolt
- Trans Prob
- Good street H/C combo?
- IAT Sensor
- Would tuning help this???
- Lost oil pressure today...help.
- Car dies when I pump the gas
- Ability to edit parameters of V6 engine?
- starting problems
- Good LT1 Diagnostics tool
- Those that know their brake rotors.... have questions.
- VIDEO of POS! Any thoughts or ideas?
- Heater Core Removal - Write-up/Pictures?
- help me figure out whats wrong with my lt1
- valvetrain noise
- Hooker Lt's 2231 , y-pipe or not?
- I lost one of the clips that hold fuel injectors in place
- Anyone Know how to fix TA headrest problem?
- roller rockers
- 383 stroker guys...?Questions?
- Car wont start when its above 40 degrees out
- Need help...with grayish smoke
- Brakes
- Fuel Pump Fuse?
- weight of chromoly pushrods vs regular hardened pushrods
- those with cloyes conversion in here!
- Cutting MSD 3-step wires
- Oil level sensor wont back out
- Power adjustable seats not working
- Hooker LT's and BMR K member clearance
- LS1 driveshaft?
- Cai?
- Electrical connectors on M6, which one is which?
- Need Answer Quick!!!
- HELP! Will an LT4 head gasket fit an LT1 head?
- ran a 9.006 in the 1/8..
- Questions on OBd1 conversion with mods
- Quick Question, need quick answer!!
- Good CAI kits
- stock exhaust piping or not??
- traction control?
- Going from OBD2 to OBD1, What all has to be done?
- Wiper motor issues
- What else besides the CPU tells the trany when to shift?
- Sweet-thunder exhaust
- securety light???
- LT1 edit questions with an already programmed PCM
- LT4 Cam or LT4 Hot Cam
- Y Pipe
- Quieter after header install?
- Need some confirmation before reinstall
- Question about automatic headlamps on firebird.
- Damn it's big
- Where to buy a MAF sensor?
- Is the ceramic coating on headers REALLY worth the 200 bucks??
- BBK headers and what plug wires???
- BHP vs HP whats the formula? Preliminary dyno run for my 396!
- middle of opti swap. questions!!
- Will AIR! mod set SES codes on a 95?
- LT1 Questions
- the best mod?
- Hooker shorties quick question
- OBDI Conversion
- Is it ok to use Mobil 1 0w-30?
- Fuel Filter?
- Getting Hot
- What driveshaft?
- valve springs
- TB dimentions?
- installing new cam, should I replace lifters in high mileage car?
- need to confirm 1le bushing P/N's and pinion seal questions.
- Ground clearance w/electric cut-out?
- Those who run KB hyperslugs....
- Need some help quick!
- Interesting question I have about tranny shifting characteristics...
- cam is in
