View Full Version : LT1 Based Engine Tech
- ABS problems
- LCA bolt size?
- PLESE HELP, Cooling system problem!
- GMMG Muffler Sold Separetly?
- Need experienced plug help guys!
- Do bad 02's cause problems at WOT also?
- Gain perdiciments? (sp?)
- headers or a gear?
- Valve spring P/N
- New best track times with hotcam...
- Bassani exhaust?
- How To Check For Vaccum Leaks ?
- Part # please
- Help With Buying Rotors!!!!
- KYB shocks
- LT1 to Lt4 Conversion: 425+ Hp Proven Kit
- Do any "mods" improve reliability?
- Will an LS1 10 bolt rear work in a 97 LT1 car?
- Weird bump when tranny shifts at redline
- Next problem w/ mods...
- camotion's phone number
- Benefits of MSD 6a on a 97 Z
- horrible miss under 2000rpm
- I have a cutout,but need the electric part
- ABS Lights after cam install???
- Any way to check coil?
- Rough Idle And Burnin Rich
- weight reduction ideas?
- How do you remove a convertabile top frame?
- pulling a motor?????
- Fastest N/A LT1?
- fuel delivery problem?..or is it mr.optispark?
- Double roller chain with NON-vented opti?
- Cut-Out or SLP Loudmouth?
- Exhaust ORP Question
- auto trans 2.73/ 1st gear blocker shifter question.
- MSD Digital 6+ Vibration Mounts???
- best exhaust with headers and !cat
- max compression for pump gas?
- Any way to improve stock WP?
- JetHot LTs knocking against brake line shield???
- AC was not charged for a year, is it bad
- damage
- Got back from maple grove ... is my engine dying?
- A/C Issues, Low coolant light? Help!
- 600 dollar install high?
- Best Pressure for Street Tires
- Car wont FIRE UP???
- Front End Squels
- What part number is o2 Sensor and belt?
- PLEASE HELP w/ mod problems - LONG
- Low gas mileage?
- Problems w/ mods, PLEASE HELP!!-LONG
- Smooth Bellows?
- how much for a '97 z-28
- Would ported heads on a stock cam hurt anything???
- Stock A4 1/4 times?
- Did anyone gain traction from moving the battery to the trunk?
- Electric Cutout - Which one/Where from?
- stock I-pipe outlet size
- Is this thing kind of like a Hypertech Programer?
- stock pistons
- Need part number
- 14.887@95.25 Analyze my slip.
- WHY Synthetic????
- water leak
- problems with new motor
- Header gaskets gone?? (Pics)
- My reading lamps never turn off?
- Loosing Fuel Pressure on "RUN" Position?
- tri state f-bod association
- Help: runs good for about 15 minutes, then like crap!
- wierd track results?
- Serious problem with Z28
- A4 Question
- NEED HELP !!!!(rear bump stops)
- Weld draglites, and LT1 brakes? Spacers?
- Dyno Numbers In !!
- Brakes feel HARD, why???
- C5/Z06 brake upgrade part numbers?
- Need new fuel pump, have a question
- Do I use RTV on the Intake Manifold gaskets ?
- What weight oil in new motor?
- Which Y-Pipe to get? Help!
- stock maf vs. aftermarket maf
- K&n fipk filter replacement
- Bad Night at Track
- Optispark
- Misfire
- First track times!
- Fuel line ?
- Help w/ installing NON-vented optispark
- nitto 555's or bfr drag radials???
- How often do you change you SYNTHETIC oil??????? Why??
- Drive line noise/vibration.
- Defective lifter?
- Suspension Advice Wanted
- shoebox
- MAC header question
- o2 censor?
- A slight...errrr...problem..
- APHR help!!
- HELP!! Broke something
- 323 to 373 gear change
- Steering is way too hard at low RPM
- reading codes
- anyone know the weight of a PM rod?
- Best 3" Hi Flo Cat bang for the buck???
- Anybody running NASCAR syle sidepipes?
- Intake manifold leak questions.
- Stock I-pipe to 2OtL....
- 160* thermo
- Sparks Bosch?
- CAI\FIPK Question
- Scan tool for Palm?
- anyone with a double electrical cutout
- camshafts
- shoebox 1 more Question
- Best chip for 93 ??
- 847 cam
- When car is cold in the morning it does not want to move off the line....
- Self vs Non-Alinging Rockers
- Need Quick Turn Signal Help!
- whole optispark or cap n rotor
- Sounds like my car is falling apart...Help!!!
- Possible opti problems again!!!!!
- Door Latch/Lock problem
- electrical problem with power window
- Borla catback
- What the hell would cause SEVERAL rocker arms to loosen up?
- curiousity
- Speed pro forged pistons, any good?
- 1.6 rr install coming up...
- Jet hot headers, who all sells em and whos got em the cheapest
- Car runs rough! Help
- wheather pak connector difference for 4L60E trans , between a 94 and a 95
- Vacuum leak under load only?
- 160* Thermostat
- Quick..Fanswitch Problem
- EGR Help. What can I do?
- stuck power window
- exhaust question
- Fuel pump installation?
- Want a low alternator, but keep power steering?
- low oil pressure...
- locker in a 7.5"?
- Shooting bluish smoke..
- Help W/Broken Blinker Stalk.
- Need advice please
- how many miles do you get per tank?
- steerling wheel vibrations
- Problrms with #8 spark plug
- anyone know what different wheels weigh ?
- custom cutout?
- just measured the Ohms on my 8mm taylor wires.
- Battery relocation questions
- Drag racing 101 help
- can old fuel pump cause a loss in power
- Coolant/TB mod...
- Comp. Eng shocks Good / Bad ?
- fel-pro head gasket VS GM head gasket
- MPG with AC partially on??
- SES CAT Code. Does this sound like a good fix?
- 383 install complete-thanks for the help!
- Building New Motor
- Do Hypertech make a failsafe 160 tstat?
- LT4 (not hotcam) question
- T56 Durability
- Walbro inline pump which way does if flow?
- Car died wont start, new opti, not fuel pump.
- Header Gasket with High Temp Silcon Gasket Maker ?
- Necessary to upgrade MAF when adding CAI???
- What is the part number for over the valve cover wires?
- My re-enforced stock LCA's=strong, pics inside
- How long do air pumps last?
- oil pressure drops to zero when i hit the brakes
- Can I re-use same Head Gasket ?
- What wires on jet hot LTS
- Intake fitting?
- Do you own one of these Duel setups?
- Problems with my Baby(car) :(
- Removing traction control
- OK, a reamining couple issues I need some assistance with...
- ses light will not stop
- Whats wrong w/ my motor?? (VIDEO CLIP)
- ****people with true duals****
- quick opti question
- WEIRD *** PROBLEM, please please help me I'm sick of this noise...
- egr removal
- x pipe
- Installed the "air scoop" today
- clear sidemarkers
- Bad gas??? how do I drain the tank? please help
- Question about crank's rod journal size.
- Wow, 3 Thumbs up for Goodyear F1 GS-D3's!!!!!
- Want to know if I'm doing this correct
- Post your cam swap experience here
- Free electrical diagnostic
- What exactly is LT1 edit?
- any ideas on problem
- Passed the sniffer
- Hooker shortys
- Will LT4 Hotcam kit lose me low end torqe?
- emission legal lt's for lt1?
- Cam Comparison
- Left axel has end play and I have a clunk sound in the back...
- Help Sealing Oil Pan Please
- Exhaust
- fuel test port fix
- Coil Conversion ?
- z06 maf conversion initial thoughts
- Bad injector, with no code? And a few other questions, kinda long.
- dropped a valve what should i do
- Wrong computer program
- HEI Distributor in LT1 Block
- Engine Overheating possibly....
- Alright got some money now its time for a new motor
- Questioh for All a4 guys~Leave in D or 2?
- Horn Stopped working
- aftermarket tach on LT1
- what kind of coil do you use?
- Snapped a wheel stud
- Racetronix>>
- Dynojet in Indy area
- Car burped?? Funky whirring noises too
- Brake light.........
- 2OLs exhaust by SLP
- OE/GM cat...
- Timing Question
- Why does my opti keep failing
- Those who've replaced the IAT
- nology coil
- Time for a good ol tune up
- scanmaster
- So i cant shift but it does still grab.
- what my CR when i mill my heads
- Im pissed.....really pissed.....
- best spark plug wires for the money?
- Anti-seize on spark plugs?
- How can you tell if a clutch is going bad?
- What do orange spark plug tips mean?
- Best Gasket for headers , copper?
- YOUR hp gains when going from mail order tuning to dyno tuning
- power steering? fixed itself but why?
- Car idles/runs funny.
- Car died completely
- Alternator relocation???
- Does this sound like my battery is going out?
- Code 43 question....
- Exhaust descsion
