how bad is header "slip-in primary" leak????
Old Jul 20, 2003 | 12:47 PM
1995redZ28's Avatar
at first i didnt think the car would be that bad with the #1 primary slip-in on my Hooker LT's..... guess i was wrong. i can actually hear the leak now from inside my car! ive been busy and havent been able to take a look at it. but today i went out and saw that there is a blackish-brown colored stain right where the primary slips in! now ive read about the fixes... but what i want to know is how is it hurting me? is it really affecting performance? im guessing it is since its a leak before the o2.
anybody have any info? or if they noticed a difference after they fixed the leak?? thanks in advance!
Old Jul 20, 2003 | 01:19 PM
96z's Avatar
96z
Your O2's are reading that side as lean and dumping more fuel. If you are running really rich your performance could be hindered.
Old Jul 20, 2003 | 04:08 PM
leadfoot94's Avatar
I noticed a big difference when I fixed the leak, before it was sucking up air and throwing off my idle when I stopped. Mine was also pretty loud, I could even feel the exaust escaping from the primary with my hand.
I ended-up finding a solution that worked for me, here is the thread - Primary Fix
Old Jul 20, 2003 | 04:26 PM
97 RedSS's Avatar
It still holding leadfoot? I may have to try that stuff if so..
Cody
Old Jul 20, 2003 | 04:46 PM
leadfoot94's Avatar
Yes, it sure is. It is completely sealed now and there is absolutely no more leak. No problems for about over a month now.
Old Jul 20, 2003 | 04:49 PM
97 RedSS's Avatar
You got a part # on that furnace cement..I found a place that has some but its not the same color..I found some black cement and I really dont want it to stand out that much..
Cody
Old Jul 20, 2003 | 05:54 PM
107's Avatar
107
Mine leaks as well, in fact I cant seem to get off the soot that escaped- any good ways of cleaning it? I would like to seal it as well, so let us know what works!
Old Jul 20, 2003 | 06:59 PM
sscott's Avatar
Mine is leaking also, you can smell the raw fuel on that side. I might try the t clamp but what size should I get?
Old Jul 21, 2003 | 08:21 PM
leadfoot94's Avatar
I got mine from True-Value Hardware (my work) you should be able to order the stuff I have from any True-Value Hardware store here is a map of the closest ones to you Map
It is made by Master Plumber and it is called High Temperature Furnace Cement. Here is the SKU for the product - 345-394. The Bar Code is 078864450224. That is for the 1/2 pint tub. This should be enough info for you to order it if you want to.
- Josh
Magenta_Hearts
Mar 29, 2017 08:54 PM
ChrisFrez
Feb 22, 2015 08:47 AM
Red97LT1
9
Dec 17, 2014 06:13 PM
SpeedJunkee
Dec 9, 2014 10:17 PM
blac94Z
Nov 24, 2014 07:12 PM
