View Full Version : LT1 Based Engine Tech
- Shoebox, just sent u a email!!!
- What am I not doing right? Horrible 1/4 mile times
- Need help getting car to start after it died...
- Oversized crank sprocket or not?
- Need a push
- emmissions...
- What should CKP read with meter?
- descreening maf
- Delteq mpg
- Disabling Knock Retard
- Fuel system help
- Abs Inop Light
- whatto dowhen procharging?
- Which piston rings are best for SRP pistons?
- full length headers & BORLA vs CUTOUT??
- spring ??
- Very Impressed with Delteq!!!
- cam installation
- Who makes the lightest "AFFORDABLE" crank?
- What gauge is the starter solenoid wire?
- New sound clips of SLP LM
- Stumbling, Spittering, Backfiring...(Delteq)
- Eagle Splayed Main Caps? Quality?
- ignition gains
- Name All Causes Of Running Rich You Can Think Of
- whats the exact difference in the impala head gasket and the camaro?
- Cut Out's
- Borla Warranty...HELP!
- Part throttle stumble
- cmmotorsports timing chain or cloyes double chain with cc306?
- Stumbling After Plugs
- Header install...electrical question
- Borla ??
- How much HP do i have?
- Need a part number!!
- serious manual transmission problems, need some advice
- Longtube compatible exhaust ??
- Planned 355
- Need a tune for cc306/stock heads
- PA k-member with AS&M headers?
- Water in the Oil....YAY!!...NOT!
- typical k&n fipk gains
- Rear end gear
- How does a tune over ride the O2's?
- Suggestions...??? Heads...
- Gas Milleage Question? What do you get
- Should I buy underdrive balancer since I need a new one anyway?
- ?'s about shortblocks
- Special engine package for '96 SS?
- 3.73's
- Mac Headers
- Intake gasket for a LT4 the same as LT1?
- lt4 hotcam and p&p heads guys come in
- CC305 streetable on stock converter
- stumble after long tube install
- Plug hole where WP shaft was?
- Clueless on what just happen!!!!
- Wierd Stumbling problems
- Borg Warner O2 sensors Good or Bad?
- Problems with water pump cover install
- what options do i have in timing chains and gears for my 96 im doing a cc306 install?
- Lt1 Scanmaster Installation Help
- HELP!!! where to find oem part #'s
- code 21 how do i fix it
- No spark!!!
- LT-1 engine
- Alternator Brackets
- LT-1 engine
- Car thinks it's running when it's not ?
- exhaust and flow.
- Advantages of going with a electric water pump...
- Map senso ?
- what exhaust with 383?
- How's this for cam only LT1 dyno numbers :D
- O2 sensors
- Tuning for cc306 & 385 LT1
- AutoLOC flamekit...
- Bigger injectors necessary?
- how many miles till plugs/wires need replacement
- Can't get Lokar dipstick to fit
- Looks like it's valve float.....
- Have some questions about the T56 swap I'm about to do
- and for the 1 millionth time...
- Important: Cooling system down need to fix
- How to adjust throttle (accelerator) control cable?
- Can Blown head gasket be fixed in one day?
- MAF Translator?
- what happens when i put 2:73 gears in my car that is programed for 3:42's?
- The benefits of a Dyno tune.
- Need the site that tells how to chnage the fuel pump!!
- Cooling Problems cool in summer...over heat in winter??? lol
- Mildon Windage Tray and ARP Main Studs
- timing chain
- Remove Speed Limiter?
- Who can fix this?
- how to remove coolant line from heads?
- Overheating problem, and its not the thermostat (very long and informative post)
- porting intake and heads
- Going to the dyno!!
- Opti out of time?
- stock heads won't come off...
- T/A ---> Formula (Am I nuts?)
- Rear distributor in F-Body
- 93 Speedo calibration
- Oil Cooler
- deck surface
- weird occurance just happened and need insight...
- Who all used UNIVERSAL plug wires?
- stress/reliability 355vs383
- !underhood wires
- What do you guys think about this exhaust idea? (Pictures inside)
- Spark Plug Removal
- Rear calipers rubbing inside of brake rotor. What's up?
- Steeda Tri-Ax T56 shifter?
- LT1 vibrations... bad ones
- timing chain broke AGAIN
- Do cutouts silence exhaust when closed?
- Possibility of individual throttle bodies?
- LT4 HOT cam, were there ever any issues about its hardness
- good shift points please!!
- The BIG next step in performance!
- Need some info from some built car people
- valve springs?
- Lt4 starter question regarding hooking up.
- how difficult is a tune up?
- Fuel Pump Question Please help
- loudmouth vs. borla
- 2 foot of water!!!!!
- What color are 36# Ford injectors?
- how to open datamaster?
- Exhaust flow below threshold (bank 2)
- How do i spin a cam to 6500 safely?
- How many people here have hit 450RWHP N/A with Lt1 castings???
- clutch problems...
- Advise needed removing waterpump gasket
- Coolant leak, can't find it either.
- Iron head lt1
- rich exhaust smell inside car at idle, INjuneer, Shoebox...Someone!!
- need injector help
- decelerating pop........flame, bad thing or normal?
- Any one using an aftermarket EXTERNAL fuel pump?
- Power Predictions!
- LT1-LT4 Knock Module?
- Dyno Guesses for Saturday/Prep Questions
- camshaft swap
- cam swap....do i have everything??
- In what order would you mod your LT1 if you had to do it all over again?
- Error 46 Fuel Enable (VATS) Fail ?!?
- Engine Running Insanely Rich
- 160 T-stat killing the life span off my engine?
- AS&M headers on 96-97
- K&N Air Filter
- port matching
- Hot Cam Questions
- switched to 0w30 castrol
- Using nitrous with Delteq
- Dyno #'s after a CAM tune.
- headers and exhaust
- Coils failing
- Is it worth it to change my Cam?????
- Need Help!! Easy Question?
- Engine hydrolocked again
- Holds second gear too long.
- LE2 package
- Car consistently turns off after 3 1/2 to 4 miles
- What to plug wp hole in timing chain cover?
- knock retard @ 2300rpm
- stall questions
- talked with guy at comp cams new cam vs the cc306 look inside!
- Cuts out @ 2500 RPM...HELP
- Melling oil pump identification
- Z06 MAF on a LT1 ?s
- 1.6rr.s and ported heads didnt pick up a thing
- having motor rebuilt to 383??
- anyone have a 54mm throttlebody?
- What Sould Be The Next Mod On List
- knocking sound
- good price?
- Help , emergency with emergency brake
- I need help...anybody here?
- Header gains
- Just heard back from the shop....
- harmonic balancer troubles????
- Trans am or Formula
- clicking noise when i gas car
- Unplug Crankshaft Sensor ok to drive???
- Stall Convertor questions..
- Cricket noise when stopped??
- Please help ASAP!
- Good places to buy headers...
- Idle gets bad when rev. pops out of gear
- Poll! Did you Spin a Bearing after your Cam Install?
- worth the money?
- At what HP do you need an aftermarket fuel pump?
- Spark plug keeps coming loose.
- Water Pump Bolt question
- exhaust too raspy...crackles on deceleration
- header question
- Blown 10 Bolt Question
- Edelbrock headers
- cc306 and head combos
- Help! No crank, disabled VATS
- How much spray on a stock rotating LT1 w/CC306
- Read a lil on the Hydra Rev, but should i get one?
- At what point do I need forged internals on a street car??
- Replacing oil pump with motor in car?
- Weak parking brake
- New Rotating Assembly
- air! removal on 96
- head bolt question
- just came from autozone got code p0101??
- yes i have searched cc306 cam question on my car with stock heads?
- will this harmonic balancer work?
- Where can i get info on Compcams XFI cams?
- cam help
- Anyone have pictures of Pacesetter LTs on the engine?
- Weird alarm/electrical/starting problem
- installing an air/fuel gauge
- Rear end bump stops
- Weird noise coming from headers??
- rebuilding stock lt1 heads.
- Hey Brent, can you make a sticky about bashing!!!!
- Biggest cam with unported heads?
- Delteq question
- New Rhoads roller lifters
- GM rear main seal housing (seal)
- performance up grades
- Pacesetter LT ground clearence w/ Sportlines?
- 12SCNDZ Need your help Please
- Air Pump & A/C Removal + Power Stearing & Alt. Relocation??
- cc306 and tf heads.....refuses to idle or run past 1500
- lifters
- hard starting after FPR and Injector install
- Please Help ASAP!!96 z28 ruff idle?
- Oil Pans for the LT1
- LE3 heads/cam users come
- What Cams are you running?
- Part number for the good oil pump spring?
- alternatives to LT4 ED timing set
- No spark on new engine
- Hot Cam questions
- what heads work best with the cc306
- which belt?
- RWHP vs. flywheel
- Jet-Hot Coating prices
- few questions for Ion (MadZ28)
- Question about KN CAI on LT1
- 1.6 Roller Rockers, worth the money?
- need recommendation on lt4 heads
- Another thumbs up for Madz28...
