View Full Version : LT1 Based Engine Tech
- Best cheap scan tool for '97
- Ok so I need to know if having injectors crossed can cause a misfire...
- Help needed with opti-spark
- I have decided on my next motor....
- another opti thread
- Acceptable accuracy on pushrod length?
- 383???
- Quick question(fuel mileage related)...
- banjo bolt washers......lube anyone?
- black coating in intake plenum
- LT1 up grade
- egr block off
- OK, REALLY confused with why my security light is on!!! Shoebox??!!??
- rev kit??
- I am about to disable VATS tonight, what steps to follow?
- need new belt?
- 2800 stall
- struggling to accelerate...
- cone of silence
- Egr
- Rod knock city
- Electric waterpump freeze plug?
- Exhaust Questions
- Cam Help
- LT1 Rebuild questions
- Sensor question
- service engine light on after header install
- horrible gas mileage
- Car wants to die on cold start
- SES light on for 10 seconds, then off for 7 seconds, then repeats.....
- Alternator blet came off, lost voltage, kept going, screwed engine up.....
- rev kit on any springs?
- loose or tight wich is better for performance
- problems in happyland
- bulllit in stead ?
- Electric Cut Out-Wiring a Convertable Switch (McCord on a Borla)
- My LONG LT1 day, AHH!!! (long, and terrible)
- Bad 383, thanks lloyd and ion (trickflow head flow #'s)
- 383 idles, bogs and dies when in neutral coming to stop.
- car wont shift at wide open throtle from first to second all the sudden???
- How much would a dying alternator hurt power???
- NEED HELP, Laptop shut off during reprogram
- aluminum or steel flywheel?? which is better for 500HP?
- Running Rough
- what is an "ECT"
- overheating?
- F.I. to carb
- ok I got it in, but....
- Do you think this Golen 383 set-up is worth the price?
- Got a sound clip up of the H/C/I/Everything 383 :)
- I got the lifting hood syndrome, u?
- P0152 and p0132
- LT1's happy with 89 octane gas?
- Power
- Took the silencer tube out....
- Update On Air Pump, Dealer Will Not Do It
- Need to change to a NSA Rocker, help!
- Pros and Cons of gapless rings (ZGS)
- Crank Sensor
- how many cc's are stock pistons?
- Lt1 to Lt4 converstion
- dyno tune?
- Still rich ?why?
- Ditch A/C yes or no?
- My headers are glowing
- What Now
- Crankshaft Pulley
- A few things odd with my datalog
- Breaking in ceramic coated headers??
- Crankshaft pulley installation
- fuel system problem
- gmpartsdirect sucks
- flow # question
- EVAP solenoid
- Do I need to thermal wrap A/C pipe near header??
- higher idle?
- dyno tuning
- Where do these go?
- Help! Car Misses,but Not At Idel Or W.o.t.
- Problem with my car...HELP
- Will these heads fit?
- heres a wierd question...
- Height of Stock LT1 Valve Covers
- how good are the madz28's chips
- cooling problem
- Air pump fuse blows
- I got some problems here!!! what is code 13?
- Compression test
- why is my car idling weird??
- E-85?????
- How much HP would this car produce?
- Relacing LM Resonator
- Thermostat housing bolt?
- cant stop losing coolant
- 11mpg need help, can't take this much longer.
- Electric water pump testing?
- Stumbling symptoms:
- fuel pressure drop off related too voltage
- Fuel pressure out of the schrader valve??
- spark plugs?
- Supertech filter cross reference
- Advice Needed for Valvetrain Refresh
- Fuel or Ignition?
- About to buy gears, few questions
- X pipe question
- What kind of "Y" pipe with JetHot LT's????
- Quick Fuel Pump Question
- Can't retrieve fault codes.
- SLP CAI instructions.......
- Does this 0-60 MPH time seem too fast?
- Spohn TA vs. BMR X-treme TA
- My car won't start....
- Cleaning fuel injectors
- LT4 valves in LT1 heads
- Can i run stock plug wires with my LT headers
- Car doesn't start, just clicks...???
- 4130 rods...
- want someone to read my datamaster scan. problems running
- how do i use datamaster to change iac counts and tps volts
- Svo P/n
- valve cover gasket chewed up by rockers!!!
- Are these heads good for a blown 383?
- Another stupid spark plug question...383/ported/bolt-ons etc.
- E85 vs Unleaded
- Car Overheating.
- Coolant Leak?
- Sheetmetal valve covers
- I degreased my engine and now it's squealing and I don't think it's the belt!
- Stumbling Issue Continues..What Heats Up O2s?
- Air Bag, TCS, and ABS lights..
- Engine Problems
- Problems with the motor
- no backpressure: failed inspection
- Car won't start in the Morning but will in the afternoon?
- Throttle Bodies - 52mm or 58mm???
- where to get sea foam?
- does any1 know a guy named brent tuckers car and the mods?
- No low end power
- Symptoms of a bad MAF
- So what now?
- Ac Issue
- How would a dynomax bullet sound with this setup?
- No spark!
- Complete Wiring Harness
- which shorty emission header?
- Bad day at the track, now car missing/backfiring at very high RPM
- 306 cam, ported heads, 3.73 gears?
- cut out/borla
- Which 1.6's to go with?
- Estimate on my 1/4 mi time?
- High Temps
- Used Ecm For Sale?
- my Camaro Has a Virus....Help...bad miss
- What size injectors?
- where to get a list of what the sensors on our cars do?
- low idle issue cant figure it out
- MBA Out of Business?
- Fan Switch Wire Routing
- Early 4th Gen to Late conversion..
- Torque specs for flexplate?
- hub question
- Pacesetter LT on driver's side directly against floor board. Normal?
- new rad
- K&N
- blocking off AIR on pacesetter lts
- my car is running like dookie shute HELP!!!
- Real quick question...
- Can you Start Your LT1/6spd Car with the Door Open???
- iac not moving
- new 383 wont idle
- TPS sensor gasket
- How do you measure head flow?
- Exhaust question
- Spark knock when cold?
- Anyone in the Des Moines, iowa area????
- LT1 to Third Gen ??
- LT4 Knock module part #?
- Some last questions for my top end rebuild
- cooling system problem
- huge misfire after header install
- 1.6 rr's-worth it
- this cam?
- pulleys
- WHat kind of #'s do you think this would make..
- Lost gas mileage w/ cutout?
- What cam to get?
- Running rich....
- need help car died
- Comp Cams R Lifters, Why have yours failed or not?
- Need help from the experts- Problems with new engine
- running 306 cam-beehives or 987s
- Replaced valve stem seals - still smoke?
- oil sensor going out?
- Canton oil pan question?
- gains with my setup with new gears
- code help
- intake gains with current setup
- gas mileage has dropped
- Whats in this?
- Correct Hypertech III # for '97 LT1?
- factory radiator, Flex a lite dual "e" fans?
- Oil pressure and weird check engine light
- Horrible times, dyno, just blah
- hesitation
- Hooker LT Y pipe #
- Need some GM part numbers, Shoebox?
- Where to get a hose?
- Prepping the lifters and what oil for breakin?
- Having fitment issues with Racetronix fuel pump into stock bucket- *pics*
- Got a blown head gasket
- broken valvespring... time for some upgrades
- Lookin for 400hp is it possible with this combo or can it be done for less??
- TB Bypass. could this cause any issues with cooling
- Header questions..need ground clearance ,good plug access..
- Its done LE2 heads LE1 cam
- Oil pressure
- 383cid long block is almost ready
- Optispark, Cap and rotor or whole thing?
- Can Anyone Help?
- Forged 383 or econo 383??????
- Roller Rocker Question
- Any ideas, gf's car lost the ability to accelerate while driving
- Water Pump???
- Erratic idle in my 96z ideas?
- I think Ive cross thredded a header bolt
- pcv valve ...reloc??
- CAI for 93z
- Missfire
- CAI for 93z
- pacesetter Y pipe question
- Removed my UD pulley, Amps increased
- How to get my Y-pipe off......
- Shoebox?
- About to lose my sanity here, can't get the gas tank out for fuel pump install
- jumping the relay for the ac compressor?
- lifter noise
- heat wrap
- Maf with a screen that doesnt hold in place
- Fuel Injector question?
- Mr Gasket Copperseals and Breslin 1inch underhead bolts.......
- Air Foil or something else?
- Gas Millage & 1.6 RR's
- Tightening polylocks
- Compatible blocks
- Datamaster shows 11.9-11.6 volts at idle?
- Direction of pushrods matteR?
- Z28 Owners
- Rocker arms wont stay tight
- Earls Header Gaskets
