View Full Version : LT1 Based Engine Tech
- door lock
- Code 32
- hard start prob fixed
- Getting bigger injectors.
- another happy delteq customer
- Which Cam? A4, 2500 Stall, Stage 2 Ported Heads
- Is this cam surge?
- My tach keeps freezing up!
- spark plugs and wires 96z
- th350 convertion question
- O2 sensor part number
- Where can you buy drain plugs?
- is port matching worth while
- First time dyno do LT1's fall off this bad?
- Symptoms of a dying coil?
- question about the hydra rev kit
- best cat-back for my setup?
- elec wp. doesn't keep up on the highway
- Question?
- My stock dyno numbers
- starter motor rebuild
- Throwing code P1860...help plz
- clanking noise under console
- New dyno #'s
- VIN P motor? What is it?
- What years had non vented opti's?
- Help with part throttle stumble/backfire
- Header Bolt Concerns
- how far past zero lash?
- I need some help with disgnostics
- Are these pushrods trash??
- NEED TO HIT 12s
- estimated horsepower
- power steering pump ?
- CA guys, with LE heads/cam
- Parts needed for cam swap
- My LE1 Flow numbers.
- How much do you all weight(cars)?
- Edelbrock Torque arm=CRAP
- To much oil bad??
- Need some misfire help please
- Where to install a Trans Temp Gauge
- Rebuild Finished!!!
- longtubes, Xpipe, with hotcam
- Doin an oil change
- Major problem
- Help! Car starts after about 20 secs of cranking
- true duals: Texas Speed vs Lane's
- bigger crank, will i need a diff timing set?
- Need Help: Piston hit spark plug
- Head bolts
- welp, i went and did it, collapsed a few Comp R's
- pressed to screw in studs: how to?
- Fuel Line Disconnect
- Stock motor on a h/c tune...now it wont start
- Removing crankshaft pulley
- 383 stroker..fully ported heads, gm847 150wetshot..what size injecrtors?
- best ROCKER ARMS, VALVE SPRINGS, AND PUSH RODS ???
- vats wiring
- Header/Wire Combo
- 306 and stall?
- Fuel pump question
- Hotcam on Stock Converter related questions.
- HELP - engine problem after heater flush
- Hotcam and these springs
- TB won't open all the way
- OK Need help Please doing a V6 -Lt1 Swap HELP!!
- porting heads
- Different Cam?
- Question on the "bypassing knock" resistor mod
- vortech elbow install......
- Header opening on 1-7/8" header vs 1-3/4" header?
- Intake torque question
- Need advice from anyone who has rebuilt an LT1
- People in Colorado, help.$$$
- putting on the oil pickup tube
- which one?
- PCM Part Number
- LT1 Upgrade Hopefull!!
- Ordered Delteq valve cover mount but now have problem
- Help....Car after winter storage..Moisture/Exhaust/Running problems!
- Header Gaskets?????
- '95 headrs on a '97 car..
- rattleing noise
- Oil Leak At Back Of Engine
- Engine harness from 94 work in a 95 car?
- what will my car run and a question about gtp heads
- Belts........
- Magnaflow catback install issues
- I've been driving with no front O2 sensors!
- Head flow rate vs. HP question
- Front O2 sensor location?
- What is that hole on the SLP CAI?
- stupid question.
- CSI water pump only for 93-95?
- ac removal, whats needed?
- LE3 flow numbers
- AS&M Header install today........ any quick tips?
- tpi on lt1????
- Heater
- easiest way too drain coolant
- exhaust leak symptoms
- Where to get black coupling for Trick Flow elbow?
- Optispark Question...
- Timing chain removal?
- What valve springs should I go with
- Car won't start. What to check.
- Quick coil question
- coolant flush help
- Any estimates on what numbers my combo will put out??
- 112 or 114 LSA?
- Borla emissions help
- Need new valve springs.
- Driveability of the GM847???
- Machine Work Cost
- How Much Should the RPM's Bounce?
- helicoil question
- overheating problem
- Error Message
- How do i fix this alternator belt squeaking?
- start up issues
- how to change rear spring rubber seats, and what silicone to use?
- What the hell is the delco part # for regular delco plugs on lt1s?
- Rocker arm help
- Air filter:placement
- Headers/Stock Exhaust
- Good or Bad
- is there any advantages to this?
- Best coil for a high compression LT1?
- 22 to 24lb injectors do I need to adjust fuel pressure.
- granatelli MAF
- Please Help, Check engine light on and car running rough????
- Gained .6 tenths and nearly 5mph from Kook's LT's..
- Exhaust
- Need some help please.
- Replacing Steering Rack. How much PS Fluid do I need??
- What are the Chances, Please Help....
- Fronnt crank seal replacement
- LT1 Gas Mileage
- going for a bottom end rebuild to handle boost.. .
- Knock retard
- Shreaking Noise.
- Advanced Engine Building Questions
- 4th gen LT1 in car valvespring swap
- Need Help Bad!!
- A4 LS1 DS -----> M6 LT1
- Failed o2 (reading below 150mV)?
- Proper gap for plugs?
- First time at the track with the cc306..........look!!!!!!!
- A Few pics from my LLoyd E. H/c install
- Fired the car up yesterday
- Good Z28 Mechanic in Hawaii?
- Anyone ever try this ignition?
- after night at track car runs crappy
- Need Fuse Box Layout
- Comp 983 springs.
- Oil Change Help!!!
- .045 spark plugs
- LPE heads/cam?
- anybody use HELLFIRE rings ???
- oil level sensor
- Flaring tool???
- Hesitation/stutter at WOT... help!!
- Who makes stock LT1 pistons?
- LE2.5 & Nitrous
- Could a LT4 Knock Module cause you to run rich?
- Most Powerful Cam with Regular boltons?
- Autozone Scanned My car tonight, Need Help now??
- Help, got a ghost of a prob.
- Doh! Need some advice.
- MAC Y-pipe
- How to convert '95 timing set to '94 motor?
- ex612's for gm847...Y or N?
- Powertrax Lock Rite??
- how long did your opti last
- comp R lifters/ promag 1.6 LASH setting
- Painless Engine Wiring Harness ?
- A quick question about water pumps
- pace setter Y-pipe clearance issues, anyone else have problems? solutions?
- anybody use the MSD opti?
- Changing fuel filter
- OPTI question
- Tapping when Cold <long>
- oil pan / pump for stroker ?
- Alternator wiring and stock guage panel removal
- Can Someone Help Me Out Please
- easy fan question
- stock timing at idle
- Cheap supercharger or turbo on E-Bay?
- Valve Springs!!!???!!!
- Borla catback off 97 to a 93?
- New datalog, car still not running right. Please check it out!
- Data loging & MPG
- High load detonation...
- Ignition problem?
- Fast Chip???Anyone have one???
- Question about throttle.
- Copper gaskets don't line up with header ports, what do i do?
- anybody running AFR 210 heads?
- Those with the LE3 kit...
- manual fan switch
- what's biggest valve 4 ported heads??
- Initial SAR2K headed 355 dyno results..still a intermitant problem though
- 93 or 94 Differences
- best porting book
- Can a bad opti cuz rich condition or is it my TUNE.
- Just bought a '93 Z28 - Need help with this POS
- Difference between LT1-LT4
- mislodged pushrod
- Could a manifold leak cause a P0135 code?
- CC306 vs 227/233
- Search results 0 - Catted y for pacesetters?
- lt-1 to lt-4 converstion
- whats the best price for MAC mids/Y pipe?
- Stock Exhaust Size?
- Checking Knock Sensor
- Need to Run 11.5x by July 1st!
- EGR stud, need bolt size.
- Programming software and monitoring software for LT1 cars?
- shims?
- piston dish help please
- OTVC Looms, Ditch Moroso get Taylors?
- 3 fried lifters... what to do?
- Any suggestions on making a custom steam pipe?
- Is there a diffrence between loud mouth 2.5 or 3" exhaust
- Traction with these mods?
- Starter Bolt
- LT4 kit or Supercharger?
- 355 build research
- Oliver billet rods and probe pistons
- Any cure for piston slap causing false knock?
- a couple more lt1 ?s
- Thermostate ?
- Studded Mains
- Sweet Thunder (GMMG) muffler pics inside, going on true duals
- Injectors????
- p0300 Random/Multiple misfire
- Aftermarket ignition coil
- I have a question Shoebox!!!
- new heads, headers cutouts
- stalling
- need two things answered please....
- Got some vids of my car..Kooks LT's through cutout
- stock hardened pushrods
- Ignition issue - car will not start
- thread sealant on a head bolt
- water pump weap whole question
- Certainly don't look like AS&M's to me..
- rear wheel rattles after fuel pump change
- Hissing sound from passenger side?
