Gear Drive
Old Jul 20, 2003 | 10:19 AM
importeater's Avatar
Gear Drive
Anyone know if they make a gear drive timing set for an LT1? Anyone have one in there car now if they do? I love the sound from them so if they are available Id want to do them with the hotcam.
TIA
Craig
Old Jul 20, 2003 | 10:46 AM
AsianSensation's Avatar
Try Pete Jackson. You will have to modify the timing chain cover to clear the idler gears. Probably not a good idea, since it might cause havoc with the knock sensor.
Old Jul 20, 2003 | 10:48 AM
Jeff Belloma
Guest
Posts: n/a
you could if you go to an electric waterpump. it would most likely require some clearancing to the timing cover but i'm sure guys have done it.
unless you are using extreme valve spring pressures, you'd be better off with a good double roller chain on these motors. just my opinion though.
JB
F'n1996Z28SS
Aug 23, 2023 11:19 PM
HectorM52
Jul 30, 2017 11:46 AM
jb4xx
Feb 2, 2015 10:00 PM
Elcojoe
Nov 17, 2014 10:27 PM
