View Full Version : LT1 Based Engine Tech
- ET Streets
- How many O2's!!
- Which XE cam for my 383 ?
- Newbie needs help with A/C
- Which Header Give The Biggest Hp Gain
- Best place to put B&M tranny cooler??
- 30# or 36# injectors??
- Optispark Firing Picture
- exhaust help
- Which OVC wire set?
- Car throwing code
- fbody.com gone?
- ARP head bolts and LT1 torque specs
- parking brake removal procedure
- Area Under the Curve
- springs
- Lt4 Km
- Gonna kill my car!!!!!!!!
- What kind of gains from Mac headers?
- AC compressor
- Aftermarket tach's
- Where can i find????
- Kumho Excsta MX tires
- Questions about some drag tires
- Need to fix my OIL leak - Got advice
- one last offroad pipe question anyone with shorties might be able to answer
- Throwing Code 11 - Indicator Lamp Malf - Need Advice
- common LT1 problems
- Is this correct (hotcam related)??????????
- MAC Headers & Stock Cat
- eibach or hotchkis springs??
- Jet Hot Long Tube Users:
- any header gasket? help
- Follow up on LT1 Starters. Which one?
- where to buy felpro's?
- broke coolant temp censor
- I have starter questions.
- Roller Rocker
- Headlight problems?
- Question about shocks and struts? Where to buy?
- catalytic converter problem?
- Chrome rims and dyno?
- Opti cap & rotor question....
- Gains from ThrottleBody?
- no answer
- cam kit?
- Changing the Oil
- SLP LT4 PP/clutch....opinions please
- 1995 Mac Header Question?
- What fuse or wires can shut off red idiot dash lights?
- Resetting ABS Light
- Does anyone use their Nitto 555R's for daily driving?
- 700r4 in 94 ????
- Porting heads and a cam??....
- Help please.....mysterious miss between 4500 - 5000
- how much for cam install?
- l98 low end vs lt1
- accel/LPE SuperRam intake
- As&m Cai?
- Lt1 to Ls1 intake airbox assembly
- stock flywheel can't be turned?
- trans temp gauge
- Guys with Mac Headers inside please, ? about wires
- Anyone converted to a 98+ Instrument Cluster Dash? Is it doable?
- Custom Cut your wires (if you were to replace Taylor OVC)
- New Summit racing Long mufflers
- Spark Plug Gap
- car revs without touchin gas
- LT-4 clutch?
- Borla catback with new muffler?
- ls1 clutch on Lt1
- Oil hookup and water hookup?
- code 36 and 42 need help [long and somewhat technical post]
- P/N for Heater Hose
- Removing Serpintine Belt to Drag Race?
- How do I remove a Automatic Shifter Handle?
- Trans Go Shift kit for A4
- How does timing affect gas mileage?
- I feel bad when I get on it....
- LT1 guys opinions about LS1
- car has a stumble in drive with the brake held
- Baer brakes
- Cat Converter
- Automatic shifter knob
- How much is a used cat worth?
- Biggest Cam that will pass emissions?
- How much slowdown is needed for a topspeed run?
- My clutch went!!!
- Car lurches or jumps forward when not on the gas...
- rebulding trans.; shift kit or PCMforLess?
- rpms hold at 2k
- Car making a fluttering sound through the rpm band???
- How much are ET streets?
- Hollowing out cat
- Need advice on 3200 non-lock up convertor
- how do I set the tps, or just screw it on?
- I've got a problem HELP ME
- Power Mirrors ??
- Corsa worth the price tag??
- Darn idle wont come down....
- Quick question
- Brake light?
- I went 10.80's @123 on stock 24# injectors
- SES Light and High Flow Cats
- should I run 30 pound injectors or not?
- headers
- Throwing 3 Codes, HELP!
- A Mysterious Oil leak
- Replaced Ignition Coil Still have Issue...
- What do you think are the best headers?
- installed tranny cooler, but i have a ??
- Serious problems after tranny rebuild!!
- $500 and I'm in the 12s!!
- What Next?????
- whats the whole story on the intake manifold leak?
- where is my low coolant sensor???
- which 3inch flange gasket?
- to heat wrap or not to heat wrap
- Long Tube guys- LT's or Ypipe is hitting something??
- Looking for a good 350 build up
- Another Foglight Question..I searched
- 60' times
- Reuse accy. belt after it slipped off?
- AFR 190cc on a 396?
- Good headers for under $500??
- Differences in LT1s
- Ram Air pics
- C5 brake conversion update
- 70k Miles
- Doing LS1 brake conversion - which steel lines?
- automatic trans perform button
- why are my dyno numbers so low???
- Car won't start-optispark?
- sorry, springs not shocks....
- If A/C system holds vacuum for 15 minutes does that mean no leaks?
- car poped and died and code p1371 quick question about the opti
- shocks....
- Does an Engine wiring harness include the hook up for the ac compressor?
- Vortech Elbow Dyno
- Piston to valve clearance with this cam?
- o2 extensions? with headers
- whats next
- paging gripenfelter
- o2 senor
- Will my car run funky with an intake leak??
- not too impressed with HOTCAM!!
- Please Help got a odd problem
- Cold Air Intake
- Can someone tell me how to take off the front clip?
- Moroso CAI?
- 2.02/1.60 and a 5 angle job..
- shoebox help please
- Who here did NOT reuse their stock rear spring dampener?
- low rpm/ high torque stroker
- Why Msd Wires Are Crap!
- quick ques, how long to coppers last b4 change??
- joke
- Exhaust Question
- I dyno'ed my car yesterday...
- oil pressure gauge..problem!!!
- Any lifters cheaper than $200
- Vendor Caution!
- 2 part question about strokers
- Finally dyno'ed my car today...
- LT4 crank sprocket install did search
- Long Tube install list??
- Popping when I let off the gas....
- taylor ovc wires?? help
- lt1 gear swap
- Flowmaster ?
- Another one
- Tuning Programs for ob2
- used ring and pinion?
- Will stepping down to a smaller 48mm TB hinder performance?
- Gear change on a 93
- liquid line...
- bart rims
- lcas
- The worst day with my z28 yet need some help!
- 383 and catalytic convertor...
- Unknown Problem
- whats wrong
- J & M Double Diamond Subframe Connectors
- Open Exhaust = Loss of Low End Torque?
- Mufflex y-pipe with KBDD SFC's on a convertible??
- AC stuck on?
- Oil leeking from waterpump???
- where to buy ngk tr6 copper plugs?
- Car tries to die with AC ON!!!!!!!!!
- Leaky/Weak injectors??
- Bad Misfiring problem Help!!!!
- heat tape?
- LT-1 rocker and injector selection questions
- Debate....
- 2002 corvette injectors on camaro???
- Need Another part #
- Please help time running out!
- hawks racing underdrive pulley ?
- Question about BBK headers/y-pipe for LT1
- Car starting problems
- Will a 93 AC compressor work on a 94?
- 97 LT1 Opti, Intake and Water pump with 28k on them(Chicago and NW In. area only)
- Speed/Tach Help 93 to 1994 Conversion PROBLEMS!
- Help w/ compression test.
- damaged catback, dented, replacement needed??
- Wanted: Pics of clutch release fork
- 60 foots on DR vs. Street tires
- Need Quick Help! At Shop Installing Fuel Pump...
- Help... last and deciding factor on which to buy- xe224/230 or the cc305.
- Car down, tranny fuxed...??
- ABS INOP - Please Help
- What other GM rear ends have 28 spline camaro axles??
- Header Vibrations
- ring and bearing questions
- Dumb Cam Question
- Which Torque Converter
- Need Help Fast!!!!!!!!!!!!!!!!!!!!!
- which holes to use on the relocation brackets...???
- Finally a 1/4 time w/ 396!
- Tons Of Questions..... Wana Help Me Out
- Modded car runs better w/o HYPERTECH tunning?
- cam opinion
- couple questions about offroad pipes
- rear end carrier help
- What do you guys think of this exhaust setup (cat converter / cutout) ?
- What Rockers do I go with? Help?
- Misfires up top. please help
- Bleeding My Release Cylinder?
- Driveshafts 1LE vs LS1
- Car just stops running
- Got my dyno numbers
- quick help w/ 93 TB bypass
- I need a part number for a HOOKER AEROCHAMBER MUFFLER ONLY!!!
- HELP! Engine will not start HELP!
- safe w/o flashing computer?
- Most bang for buck.
- XE220 or XE224 on 114?
- Best Place to Buy a 12 Bolt???
- How can I start my Camaro??
- Spark Plugs, can't decide
- 1st time at the track
- piston to valve clearence
- Stock Cam Specs
- LT4 top end conversion, which cam for better HP than HOTcam, but for daily driver?
- what should i do
- Stock fsn CFM?
- 2 part ? oil / gas mileage
- New LT1 Double Roller Timing Chain Available FREE (joke contest)
- Clutch disk options with stock Flywheel and PP
- Who makes adapters to run old style valve covers on LT1
