overheating! friend in need of help
Old Jul 21, 2003 | 01:07 AM
TS 95Z's Avatar
i havent got to check the car out, but its a 93 Z and he is having problems with it overheating. he has the fans on all the time and replaced the thermostat and also says the coolant is flowing ok. I may go by his house sometime this week to check it out so I'd like to know what I should look for or try. So far I've come up with:
- bleed the air out
- drain some out to examine it
- make sure he has enough in there
i think his radiator might be bad, or maybe the waterpump is worn out
Old Jul 21, 2003 | 02:43 AM
Teek's Avatar
Make sure that black plastic air dam under the car is not broken or missing... that will cause over-heating for sure. Also, these cars are bottom feeders... could be a lot of trash/leaves and stuff sucked up around the radiator clogging it.
Best of luck.
Old Jul 21, 2003 | 05:03 AM
predator's Avatar
radiator cap, air in system, improper mixture should be 50/50,
Old Jul 21, 2003 | 01:27 PM
Carlos01SS's Avatar
How many miles does that 93 have? Does it have the factory cat?
Clogged cats cause overheating as well.
Old Jul 21, 2003 | 01:31 PM
TS 95Z's Avatar
thanks for the suggestions, i was thinking he may have a clogged cat because he said his manifolds were glowing
HAWG
Sep 25, 2015 11:41 AM
mark0006
Sep 14, 2015 12:35 PM
damnyankee36
Sep 9, 2015 07:06 PM
Pwilson59
Sep 3, 2015 08:47 PM
