30 or 33 spline axles for 12 bolt..
Old Jul 20, 2003 | 12:20 AM
96z's Avatar
96z
Which is needed or sufficient when ordering a 12 bolt? I really know nothing more than the 33 spline is stronger but also heavier.
What is a good reccomendation and what is the stock spline?
Old Jul 20, 2003 | 12:22 AM
REPO's Avatar
If the cost isn't any more, I would go with the 33 spline.
Old Jul 20, 2003 | 12:29 AM
96z's Avatar
96z
For what reason? Just reassurance?
Old Jul 20, 2003 | 12:37 AM
REPO's Avatar
Yup. Might as well go with the big stuff if you can. You never know what mods the future will bring.
Old Jul 20, 2003 | 01:40 AM
rskrause's Avatar
Moderator
The 33 spline is probably overkill for your current application. Yes, the 33spline axles are heavier. But the big problem with them is that it requires a custom differential (posi). Standard GM 12-bolt stuff is based on a 31-spline axle. I have 33-spline, but I would recommend you get 31.
Rich Krause
Old Jul 20, 2003 | 06:14 AM
RichJ's Avatar
The bigger the axle, the weaker your diff because of the increased material removed to fit the larger axle...and I've heard of a lot more broken diffs than bent 30 or 31 spline axles. I did 30s on my Moser and haven't had any problems (though I'm not putting down that much power). If I hurt an axle, I'll do the JordonMusser trick of getting bigger axles and having them machined on the ends to fit my 30 spline diff
Old Jul 20, 2003 | 12:56 PM
96z's Avatar
96z
Rich Krause
Thanks Rich, I was hoping you'd respond to this. I was thinking 31 spline from what I read but I wasnt sure. I know you asked a question a while back about it but I couldnt find it.
If I have any more questions Ill email or PM you, thanks.
Old Jul 20, 2003 | 01:00 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
moser has a great calculator on their website somewhere. Be forewarned, i think it gives a 200% "safety factor" so if you are on the border, you can "come down" a bit
www.moserengineering.com
2QUIK6
Sep 17, 2016 02:31 PM
RUENUF
Mar 13, 2016 03:37 PM
IndyZman
Oct 22, 2015 02:17 PM
karpetcm
Aug 14, 2015 03:02 PM
realistyc
Jul 28, 2015 07:32 PM
