View Full Version : LT1 Based Engine Tech
- looking a good high flow single cat and y pipe
- Bottom End Rebuild: 355's inside
- 93 blown, LTCC, ignition/fuel problem
- blown head gasket need help
- someone tell me what these codes are?
- How luch more would longtubes and x-pipe give me?
- hardened pushrods?
- quick question, head bolt torque?
- Tranny problem, help! 6 speed
- Metallic sound seems to be robbing hp
- general pushrod question
- Lil advice please
- svo 30lbs injectors
- Opti can only go on one way right?
- About to install a Radiator.
- Going to electric Water pump. ?'s about timing chain cover
- Scanned the Car....
- check out this video i put together (all GM)
- How do I replace my turn signal light bulb
- ABS Codes
- Going to a track tonight, need some time guesses.
- gm parts?
- Fog lights? Head Lights?
- How much rwhp out of this combo???
- What Valve Covers To Use With Afr 227 Lt4 Heads??
- Car stumbles then dies, need help!!
- Think the opti is dead. What ignition options?
- any other good LT1 websites?
- header gasket ?
- Accel Injectors?
- Opti #2
- Where does the TPS need to be set at?
- Valve Adjustment Question
- Dumb Question/Dumber Idea???
- extendor wires for Hooker LT's
- No oil pressure at hot ideal... Please HELP!!!!!!!
- we need an LT1 FAQ!
- lt1 intake w/felpro 1206 or =
- still looking for help W/sc lt1
- LTCC with MBA Brackets
- comp 977/Big Cam
- egr solenoid
- RPO codes
- 95 Z28 Camaro A4
- Removal of Head Springs
- Broke the dip stick tube off even with the block,whats the best way to get it out?
- Autozone opti people come here
- 87 octane ok???
- I got that 1993 z28 today a few ?
- trick flow head flow #'s
- knock sensor
- Mad Z Tune - All I Can Say Is WOW!
- 355 rebuild
- Fans won't come on
- Rear Main Seal Removal questions.
- Exhaust set up for 96Z28
- Engine Brackets...HELP!
- Damnit...lost the lil ring on the Injectors..pic inside.
- Barley idles on startup
- Installin tps sensor??
- About to install brand new lifters, quick question...
- HELP! High RPM miss!
- How fast?
- Cut-outs , With Or Without Cat-converter
- What Is The Best Intank Fuel Pump For Lt4
- is a gtech perfomance meter accutate?
- SES Light - P1641
- Anyone got a nx install instruction sheet?
- ok i feel dumb asking but...
- Shoebox/Injuneer help me! Normal pressure drop in fuel system
- Belt Squeels when shifting at WOT
- Steering box replacement
- Need Info! Trick Flow heads- Flow#s, dyno charts etc?
- Need help with finding a store that ships to chile!
- My lt4 Extreme duty timing chain had 1/2 inch of slack in it.
- List w/ part numbers similar to LT4 Hot Cam Kit?
- Main Caps??
- Car Draining battery
- Battery Voltage issue
- A note about my Powerbond/Pioneer balancer/hub: I needed a key.
- good injector cleaner
- Hey admin why my thread closed?? so i know
- If Knock sensor has been disabled, do I need LT4 module?
- Identify this noise coming from new engine...
- Canton oil pan?
- opti
- Knock count going bizerk
- Hey MD people.
- Is my new Oil Pump done for?
- fuel pump ?
- fuel injection cleaners? what one do you guys use? and oil addatives?
- Cant get rod bolt to stop hitting pan on 383!!
- Exhaust popping question??
- Can't get my new 396 to start
- holeshot w/ nitto's
- Help with LT4 Timing Set
- HOw much HP will this support
- Stocker's rockers
- LT4 Hotcam require tuning?
- too high mileage?
- Synthetics?
- Stupid noise from engine!
- Piston Removal Question.
- Bolt sizes needed.......
- Well.......dang it. Progress Lacking. Odd lifter question.
- need help fast???
- Serious and very strange misfire issue....not the obvious...experts inside please!!!
- Cost to replace an opti?
- Exhaust help quick plzzz
- Putting in 383 next week, got some ?'s
- 383 Going in next week, what do to while got it all apart
- crank/ hub bolt size?
- what can be wrong
- Stronger timing chain?
- Will these work?
- HEY im back need help! just shipped her to chile!
- How fast can i go with this?
- This is what happens when you push more power than a stock SB can handle
- Quick cam installation question (dowel pin related)...
- Are these good flow numbers?
- Intake Bolt Question
- A4 or M6/????
- LT1 blocks
- Will the following mods put me in the 7.9-8 NA in the 1/8 mile?
- engine problems!!!
- Part Number Needed
- Best spring for stock heads?
- Engine Problems!!!!!
- Fuel Injector Questions
- What is stock LT1 spring installed height
- Need help after mods were installed
- i need help finding out what i have in my car?
- how involved is opti switch
- What Springs?
- spark plugs? i tried a search
- What the difference between new and old rockers?
- LT4 ED chain with what cover?
- Need Help!!!
- Check out my FLP duals with spintechs
- Weight Reduction
- what all tools are needed for heads and cams
- What you think it should run?
- Scorpion 1.7 Roller Rockers
- Interior Exhaust Noise and Rain...
- going to dyno w/ LT's on friday, guess my HP??
- help needed on cam install
- Weld in SFC
- Weather Stripping
- Putting motor in tomorrow.. What oil to use?
- whoa..pick me up scotty
- fuel pressure regulator
- Do you have to retorque heads when using copper head gaskets ever 2 years?
- flow testing injectors
- Custom Exhaust (true dual sides) questions
- Max lift comp cams 941 spring?
- Gauge install ?s
- OB2 wire help
- Which Oil pan?
- Can you make a 4 channel rear end work on a 3 channel car?
- Low mph at track..possible ideas..
- LT1 no fuel- optispark cause this?
- SES CODE PO410 Any help?
- Will 94 shorty headers work on a 93?
- I desperately need a clutch....
- Proper cleaning/polishing for engine parts
- Rim back spacing for 15 w/et. street
- Stock fuel pump hp support?
- Car Wants To Die When I Slip Out The Clutch Off A Dead Stop
- Mac mids on 2 cat car... one question
- Canfield LT1 heads
- Fuel ?'s
- what size rods/pistons
- Cleaning Intake Manifold.
- cheap forged pistons/rods (budget rebuild time)
- Bolt-on cars in side...
- whats a LT4 hot cam kit?
- What do you think i will go with a 150 shot?
- What will happen if I do this
- duals with chambered mufflers...anyone?
- Deltec Owners, anything special about their coils or can I just buy them elsewhere?
- Removing Intake Manifold right now...few quick questions.
- Miss, stumble, at 5200-6000
- Very Important ? About Timing
- Stumbles and problem downshifting
- Electric Water-pump to do or not to do?
- Cam Lift Ration for Hotcam
- Will N20 Hurt my Lt1?
- CSI pump install question
- Spark plug wire, miss question?
- replacement muffler (what's best)
- Went to the Dyno, results are surprising.
- Broken fuel rail bolt
- Spohn Torque Arm Usefulness?
- Spark Issues....
- No Spark issue (98 V6 to LT1 Swap)
- Opinions for 3" exhaust gasket and bolts...
- what size rings to run
- exhaust
- Anyone with the LS1 brake upgrade. Any ABS problems?
- Heads/cam done now issues
- Difference between 93 and 94 ICM/Coil
- Crankshaft balancer pulley. [Shoebox]
- Racetronix Fuel pump Harness Question
- people with delteq system
- abs light
- !!!Help!!!
- How hot does your motor get?
- Surging Idle
- Oil leak and knock help please
- Fuel Pressure !!!???!!!
- Would u be afarid of this Z? Good buy?
- Powerbond balancer/hub question: Which way's it go? No key right?
- EGR Info
- Quick question on head bolt torque!!!!!!!
- V6 to V8 swap problems
- Help! Disconnecting Fuel line..what do I need to do first?
- MAF part # Question Shoebox, Jason, Dal or whoever
- electric water pump????
- Help
- PCM4LESS or MADZ28
- How's My Gas Mileage?
- Pacesetter LT's and DDSFC any problems??
- GM 847 in speed density (93) car?
- How much rwhp horsepower will this combo get me?
- what can i use to keep the ls1 injectors in the fuel rail, what kind of clips?
- Engine wont start after rain
- Jet Stage 2 Power Module information (scan tool info)
- Please help w/ diagnosis of rough idle
- argh idle problem
- Possible metal in engine, got to bearings
- Help
- Programmed out KR but still get KR...
- Comp R or not? LE2 package
- Pushrod length with small base circle cam?
- Best rings for street strip LT1?
- Need some guidence on what to do to keep an LT1 together at high RPM'S!
- Ported LT1 Heads
- everything else stock, what cam is a good choice for everyday?
- MAF sensor plug?
- Where to buy LT1 Jet-Hot MAC headers?
- Clutches
- Opti Gaskets, Waterpump Gaskets
- Cooling Fans
- A4 shift firmness mod in Z28?
- Is there a significant power loss with a collapsed lifter?
- I got in my car this morning and...
- 7/16" studs ??
- New Opti grinds???
- Recommended RPM for stock bottom end
- LT1 to LT4 conversion (HOT CAM)
