View Full Version : LT1 Based Engine Tech
- Heater problems?
- driveshaft tears off from rear end wtf!!!
- 96 LT1 z28 ... what should it idle at?
- Convertible subframe connector questions??
- So, I have a header bolt kinda stripped
- New muffler on and now WOW!
- whats a f1 camaro?
- What do 17x11's weigh?
- where are HOT cam owners revving???
- Sparks flying, car wouldn't stop- what happened?
- Looking for downsides to an OBD1 conversion
- Headliner question - Need updated info
- Timing Chain
- What's wrong now?
- no 2nd gear but...
- Dashboard !!!!!
- HELP broken oil sending unit
- how hard to fix a windsheild wiper??
- Flywheel Resurfacing????
- Was up with the 3k breakin before synthetic??
- Special tool for doing plugs?
- ECM Part Number.
- wires and pullys?
- Lots of Road Noise....Is there a way to silence?
- Heads, cam, lt's install ?
- Less then 3/8 tank = hard start???
- Jet Hot LT question
- Need insight to performance woes. (sorta long.)
- My Heater gives off a FOUL odor sometimes?!?
- Why are my Wipers sitting straight up when off?
- anybody,everbody need your $0.02
- Can someone with an MSD retard box do me a favor?
- Exhaust Question
- head bolt & intake bolt torque
- real bad miss fire after cam swap? please help
- Safe to lift front of body off K-member by a Strut Tower Brace?
- Coil/Bracker Arcing
- best shocks and springs for comfortable ride
- Going with Heads and Cam... WHAT ELSE???
- CAGS install Q????
- anyone ever wrap there M6 trans with dynamat?
- BMR K-Member: w/ Motor Mounts vs/ without...???
- This is what my car sounds like from inside.
- Anyones A4 ever leaked from around the SPEEDO sensor?
- 1 3/4 mid vs 1 3/4 LT header
- O2 sensor have 3 or 4 wires? Ordering one off summit
- Remove the front sway bar, yes or no
- What kind of Bearing Puller?
- A/C problems....
- Is 35/25 front/rear sway bars a good combo? Respond fast please! =)
- 11.5" ET Street on salad shooter?
- Need some advice. Please help
- Desktop dyno File
- Will 18's fit my Z?
- transmission fluid
- Swapping rear ends....
- TB spacer?
- those with Accel 300+ ignition
- How to stop header leak on slip in primary???
- I Dont Get This!!
- Heater Core, Im cold :(
- where to find the comp fuse...
- OK explain to me this...
- trany problems
- I give up... LTs SUCK
- renting scanners?
- Right turn signal dont work
- LPE Supertube
- Please Help!!!
- Does the LT4 Conversion put out 425+
- Hooker LT gasket ?
- Cheapest place for slp cai
- Holley TB Opens to far
- Dynatech opti and MSD 6A
- Rocker install tech. question
- hooker long tubes or slp long tubes
- statt
- HOTCAM help
- 10,000 to spend
- Fuel Injector ticking.
- hotcam guys, how many of you are still running 342 gears?
- What do you guys think of this CC XE cam. Short duration, high lift.
- XE 224/230 guys in here please!
- NGK TR6 spark plug gap with ATI procharger
- rk sport headers tricks
- which mac's to use?
- Overheating/coolant Overflow
- "Stroker Guys" mass air & throttle body ?
- SES light
- Finding #1 TDC...
- 3:42 to 4:10 how far off is speedo
- My 96 Z M6
- car has trouble starting
- Anyone know the Part number for?
- best way to do passenger wires?
- Pinging?
- Turn signal flasher number??
- O2 question: readings and replacement
- Mini Revelation on surging at idle
- This message board
- Confused
- Shoebox - Question about method 3 adjusting rockers...
- a cuple codes tell me what you think
- Who's running "true duals" all the way out the back?
- 355 TEA build up starts soon.....
- whats top speed with 3.23 and 3.73?
- Is this normal??? Urgent!!!!!!!!
- Hooker Y-Pipe Thoughts
- Resetting the PCM?
- Holley TB owners in here.
- Coolant prob........cracked cylinder????
- H20 Pump Wiring?
- will 5x120.65mm lug bolt patt. fit on 94 z?
- Omg Worst Luck Ever!!! Holy Crap!!! Help!!!
- 1/4 times with HOTCAM!!!!
- Wiper Blades
- Question about o2 readings...
- correct/good fuel PSI
- Did I break it?
- Quick Question!
- Stroker help
- Help diagnosing SES light
- comp 1.6 (non promags) vs stock 1.5 rockers
- Poor idle after cam install / Tuning
- Question about Vacuum.
- brake fluid dirty?
- way to check opti?
- new lock cylinder... now remote start wont work
- Would it be worth it to replace just the bearings in my 94 LT1?
- Place to buy a high output Alternator?
- LT4 Conversion on '96 WS6......
- Will this ignition work?
- how do i cover the hole for vented opti in the intake elbow?
- Is there a cam that will give gains below 5K rpms?
- pulling motor... wiring question???
- Sumito tires, good alternative to Nittos?
- I need help with 1le intake elbow!
- Pulling crank hub (link)
- tranny mount
- car trouble...need help!!
- Question about LT4 spring part numbers??!??
- any advantage to LT4 springs besides the increased lift?
- ignition switch installation!
- Where's my pcv valve?
- weird smell after 130
- Difference between the steering setup between 93 and 95...
- I plan on buying tires weds...
- Squeaks and Rattles
- ZO6 Calipers
- Who here is running a BIG cam (hyd. roller) on a stock bottom end?
- I need an anwser quick!!!!!!!
- A/C delete - what to expect hp and weight wise?
- Whats wrong with my car, run 16.9 in 1/4
- cant get my friends car to start
- 94 Z - Looking for Mod Input
- autotap run...Fuel trims?
- CSI water Pump
- Thumbs up for ThunderRacing
- LT4 valve springs: Will they fit an LT1?
- opti-spark problem
- electric problem
- Cam powerband question
- Which is the best Y pipe to get between the SLP and the Borla?
- If intake valve is open, you adjust exhaust valve and vice versa?
- 227/233, Lloyds Heads Dyno Results
- what do you need for clutch install?
- Rack & Pinion???
- Stock Springs on 1.6 rockers on a 93
- worth getting rid of the air silencer?
- Relocation brackets on a non lowered car ?
- Lt1 Scan master wiring?
- Please I need tips on adjust rockers w/ car running.
- What did I do wrong!?!
- Just in the middle of a plug change....??
- how much gain
- have you ever heard of these?
- Gas mileage and 4.10s...
- Easiest way to install wheel studs on rear?
- My car won't start!!!
- Panhard rod in a drag car suspension
- Should I bleed the air out of the coolant after TB bypass?
- Adjusting Crane Gold's..
- were to buy a cam
- Fill radiator
- Waterpump differences (Mez, Mez HD, CSI)
- Wierd starting / electrical problem
- New WP - Now I'm overheating?
- 233/239 Sound Clips
- water problem need help
- Where can I get a Block off plate for an LT1
- Would it be OK to do this?
- Weird Blinker Problem.
- pacesetter headers
- please help[,,about starter
- Heater core bypass........???????
- Anyone use Arao 4v heads instead of a blower?
- Help--> wiring injector #2
- any 1 got a pic of a camaro with these rims
- tranny died, what do I do with the stall and the cooler ?
- Changing throttlebody, simple plug-n-play?
- Comp XE 227/233
- 383 HP & TQ Estimates Please
- Best way to clean an Intake for powder coating?
- Comp Cams 230/236 565/565 112 lsa
- Pics of LT1 Jet-Hot LTs & k-member area
- Any and all causes for a high RPM miss.
- Heat not hot?
- Hot Cam spring pressure
- MPH low on my 383 T/A
- Crate engines...
- Clutch
- Rev Limiter
- Aluminum rocker vs Other rocker?
- pushbutton start
- How long did it take to install Hooker Cat-Back ?
- Low Fuel light question
- Squeaking!
- removing shifter cables?
- Lower control arms....adjustable or non???
- Compression Ratio Power
- How much would you go?????
- Scanmaster
- Loud Knock noise
- O2 problem, weird!
- best Roller rockers?
- How long does the Water Pumplast?
- Smaller headgasket = more RWHP??
- how good is the GMPP forged crank?
- What are the major problems?
- What would cause....
- LT4 intake?
- What are the specs?
- symptoms of a blown headgasket
- Coolant smell when I turn on AC.....
- surging...
- Crane cams' Fireball HI-6
- Front suspension
- T-56 flywheel counterweight question
- Tranny Input Shaft Seal...Anything Better Than Stock?
- TA fog lights
- Yes No question about RTV on intake manifold...
- Feels like I'm missing something with my cam install??
- Got the SLP clutch put in....
- If you're looking for a short stick for M6
- LT1 total engine weight?
- Wacky Opti Spark System Issue
- Weight Savings and Difficulty of AC Removal??
- LT1 Tune Up Guide
- went to autozone
- Opti Cap & Rotor Kit
