View Full Version : LT1 Based Engine Tech
- 160° Stat require new chip/program?
- SOS GOD HELP ME!!! (just came from garage)
- How do i know if rotors are warped?
- Sawtooth dyno graph
- pulling motor, need ideas
- A/C Compressor Install / Uninstall Results
- Argh Wipers
- my car seems to be slightly rattling, details inside
- xe224/230 at 111 LSA
- typical price for heads and cam
- 2.25 Wheel Spacer
- Tubular okay or go with boxed SFC's?
- LT1 crankshaft difference between manual/auto tranny?
- Rear end advice
- Monsoon Stereo
- 6-speed Question
- Paging shoebox (or anyone else that knows everything)
- Whats the low down on flywheels?
- Cheapest price on hotcam??
- Part # for upper shifter boot?
- How do I install the windshield wiper blade?
- Need help reading my Datamaster File
- Where to get a t-56?
- Vacumn leak
- Auto Shift Points RPM Range
- Found a cheap T56, but it needs two parts...
- What The Hells Do I Do With This???
- Shocks or Springs, which is better?
- M6 tranny not going into gear
- Valve Job and Reliability
- Anyone ever get a horrible sound from the A/C compressor?
- Drilled/Slotted Rotors..is 200 bucks a good price?(LINK)
- Guys with LT's how are you routing #7 plug wire?
- DMS motorsports
- where to purchase modifications??
- WTF is wrong with my brakes?
- overheating problem
- 2nd gen z askin for some input
- 383 help
- Anybody know how to adjust the winshield washer nozzels??
- Where can I get one MSD plug wire....
- Is it possible to mount n2o system here?
- New intake and Oil Pressure Question ??
- Trans question
- Anyone install and poly tranny mount???
- lowering kit
- Rear end ?s
- SES on non-stop for months. Now off due to better gas?
- What do these symptoms mean??
- manual fan switch??
- Does the HVAC fan slow down when accelerating? or am I crazy
- Car won't start, problem?
- TB top plate gasket - part #??
- Please HELP
- need help with removing LCA's
- What are the symptoms of a bad torque converter?
- Power door lock problem, HELP
- Need A Link
- powere ant
- Help with AC!
- ???Hot Cam Kit???
- Car starts, but then SHUTS OFF!! Whats the deal?
- anyone pass a roller emmission w/ open cutout?
- Is a cutout a worthwhile purchase?
- 17in rims to 18in rims how did it affect your 1/4 mile times??
- Is this a scan master???
- Ignition box needed?
- 95 Lt-1 Alternater
- Whats the Fastest Bolt on LT1 on Nitrous?
- anyone tango with a code16 yet?
- Security Problem no start! 96 Z
- rough running
- OK....Does Pennzoil suck or what????? Plenty of opinions are welcome...
- Need Help In street tire choice 15x10!
- how much for my car?
- Will my 96 formula cd player work with my 96 camaro?
- Stock hub on Eagle 383 Crankshaft?
- running cc306 with no O2 sensors-reasonable
- Can't decide between 224/230 and 230/236...
- Screech noise shifting, belt or CAI?
- help me with fan switch mod
- Just ordered cam kit from Combination Motorsports
- Question for those with Vortech elbow
- What the #@#$ is wrong with my car?!?
- Whats this part and what does it do???
- BCM bad?
- Multiple misfirer detected?
- Melrose t-top valve covers hit shaft rockers
- List of mundane reasons for the SES light to come on.
- air pump whine
- Negative battery cable
- Stupid motor mounts
- Comfortable RPM for a 383
- Humidity = Longer to start?
- Does the cam spin twice during a complete engine revolution?
- shoebox is this correct?
- Where can I get a clutch alignment tool??
- Power Steering Pump toasted...ideas?
- brake system
- injector calculator? Link please
- Fans on w/ AC immediately after start?
- Anybody repair a spark plug hole without removing the head???
- Post your emissions report please?
- ASR Traction Control
- 10 bolt rear... is it a 7.5?
- Holley Powershot Filter cleaning?
- Trans Mount?
- Good Cheap OBDII Scaner??
- Start up problem
- Ignition---MSD or what???
- normal operating temperature
- Ignition problem?
- autometer
- anyone with 18 inch wheels?
- Driving on flat tire
- cutting o2 wire and extending by myself
- Keep #6 at TDC during heads/cam swap?
- which y pipe???
- M/T ET Street tire pressure
- coolant swap additives?
- what springs/retainers?
- ECM Failure? Yes or No. Help
- Eibach Pro Kit. Any good?
- MSD Wire Question?
- Transmission Mount causing vibrations?
- Ford Window Motors?!?!?
- Timing Chain
- Tranny wiring (part2)
- Need part number for suspension
- 10 spoke SS wheels on Firebird
- Quick question before I get the Jet-Hots....
- Aluminum De Shaft Diameter
- Performance Automotive & Transmission Center??
- uh... am i supposed to be able to push my rocker arms in with my fingers?
- plastic nipple came off my opti
- whats a good cam to go with???
- 2.73 to 3.73 gears
- Tranny out??? need help!!
- What is this called?! Please!!!!!
- Summit LT4 Cylinder Heads ?
- summits fuel injectors
- A/C low pressure sensor q
- Need all advice I can get on buying an LT1 (motor)
- Where to find 45* exhaust bends?
- Antifreeze - High Temp theory
- Crappy track times
- need help with this mcleod twin disc setup
- No oil pressure when idle
- NO more Traction control for me!!!!
- whats wrong???????
- Do I need larger injectors?
- Has anyone done a Ram air on left splash cover?
- Is my timing gear upside down?! HELP!
- Transmission problems HELP!
- 95 Z28 Can I Use A Z06 Clutch?
- Another ? about jet hot lt install??
- No more Delco PF35 oil filter?
- Raditor stop leak?
- Anyone running a 224/236 cam?
- Installing Autometer Guages.....
- header and y pipe help
- Just go a cutout
- wide band o2 sensors.....
- Forged 327 Large Jounral Crank
- help with oil pressure problem
- I'm sick of my z running like crap help
- What size injectors should I run?
- Various lifts of the 224 cam
- Anyone have a link to the lt1 engine thats cut in half?
- Running Rich
- BBK shorty headers
- different brand o2's?
- Looking for STIFF springs stock height
- Almost time for the CAI...
- winding turning noise after cam install
- day time running light module
- Intake manifold Bolt/stud locations?
- Coolant leak from wierd place
- resurfacing pressure plate???
- TCI Super Street Fighter
- Are my new cats going bad already?
- Crank pulley question
- Heads and Cam or Spray?
- I have a transmission problem...need help.
- Re-installing my Intake to finish off Head Project question..
- Plug wire changing
- opti/wp install complications
- Random SES light???
- Radiator options
- 383 stroker experts i need your help
- Goodyear Gsc
- Tech tips
- Where can I buy a new cam dowel pin?
- 18" drag radials
- PCV Valve
- Thick smoke out of exhaust
- P/N for pinion gear shaft (94 M6 3.42)?
- raced yesterday... no traction, what do I do???
- TV cable adjustment/replacement how??
- Lost keys.
- performance shift mod or transgo?
- help! cc306 cam install
- Help with Proform shift light?
- tranny lines... got an idea
- valve seals? what are these?
- so if I bought this A4 to M6 conversion kit, how much work is involved in the swap??
- Anyone Have Flow Tech Afterburner Muffler?
- Fire extinguisher mount for a non-rollbar car inside
- CVR (or any other adjustable starter) indexing
- MAC header fitament
- Got my car dynoed yesterday....
- Intake oil leak fix...how long?
- Will 18inch Z06's with a +56mm offset look good all around on a T/A
- All those using guide plates inside, please
- Headlight control modules interchangeable??
- Getting A4 Shifter off
- ALt carpet
- will a bent pushrod cause loud tapping?
- Free conversion program
- Balancing issues
- please help. How can I get my car to run cooler??
- Could a bad opti cause this...
- LT1 vs LS1
- installed new catback!
- low coolant light on, engine running hot, but the coolant level is fine...
- Precision 3.73 gears for a 2 series carrier, good gears?
- my ongoing rocker swap problem
- T56
- possible header leak, how to FIX??
- Newbie needs help with BLM Split
- Possible to wire a switch to kill the power windows?
- Bought a Z...
- What type of oil pan...
- Building a Stroker
- Fight with friend: YOU decide!
- what is this gasket called? p/n?
- Free coolant?
- Differences between 93 & 94 throttle bodies?
- What are good window motors?
- problems w/ new engine...
- what makes up the clutch fork?
- Engine Ballancer/ Pulley - Does it matter how it lines up ?
- Max out at 90% Throttle??
- LT-4 Intake Part#?
- What size hose?
- Falken Ziex or Nitto's?
- Should I have my flywheel balanced?
- PP Performance.. PP w/ribbed finger=stock] PP w/flat fingers=?]LT4 PP =? clamping lbs
- Nobody ever discussed the SLP clutch pedal feel, over stock, in detail!?!?!?!?
- LT4 Hot Cam dyno results and points to ponder
