How far off is the stock tach?
Old Jul 20, 2003 | 03:53 PM
96z's Avatar
96z
Has anyone measured or had a stock tach that was off? I think mine maybe off especially in the upper RPMs.
Has anyone ever varified exactly how much its off?
Old Jul 20, 2003 | 04:02 PM
97 RedSS's Avatar
Usually read 150-200 rpms too high..
Shift-Lite indicated and Freescan indicated..
Cody
Old Jul 20, 2003 | 04:27 PM
FastZinTennessee's Avatar
Mine is off 200 rpm throughout the entire range.
John
Old Jul 20, 2003 | 04:31 PM
96_LT1's Avatar
same here....200rpm off throughout the enitre range, as verified with datamaster and my autometer.
96z's Avatar
96z
Cody
For example when your really at 5800 it reads 6000?
Old Jul 20, 2003 | 04:36 PM
turbo_Z's Avatar
mine is 200 rpm fast compared to my scanmaster.
Old Jul 20, 2003 | 10:27 PM
Terran2k's Avatar
mine is about 200rpm off, according to autotap. and my speedo is 3mph off
Old Jul 20, 2003 | 10:33 PM
CamaroBoy96Z28's Avatar
Mine used to read 1000 rpm at idle, after indiglo gauge install I set it at 900 for idle since that was the most mentioned idle speed that I've read in past posts.
Old Jul 20, 2003 | 10:37 PM
94formulabz's Avatar
For my 3 dyno pulls i tried to let off at 6000 rpm (i was driving) and the computer also indicated 6000. So it seemed mine was pretty good. I was actually expecting it to be off though.
Old Jul 20, 2003 | 11:15 PM
Z95m6's Avatar
200-250 for mine i have never watched to see if it gets farther off at higher rpms on the scanmaster.
Old Jul 20, 2003 | 11:18 PM
ChickenScreamer94's Avatar
hmmm....I think I see a trend here My basically stock car says 6k on shifts but is programmed to be around 5700ish at the factory i believe so about 200 rpms off
Old Jul 21, 2003 | 01:27 AM
S8ER95Z's Avatar
Yeah ive noticed when I manually shift at ~5800rpms it doesnt feel as fast and leaving it in D... since the auto shifts past 6K on the tach Mine must be off about the same as you guys.
mr28
Apr 20, 2016 05:44 PM
canbaufo
May 25, 2015 12:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
mr28
Nov 23, 2014 11:11 AM
