View Full Version : LT1 Based Engine Tech
- rev kit questions
- most n/a hp seen out of a unported lt1 head?
- Temp. sensor question
- When would a Guy need upgraded rod bolts?
- what to do?
- 1.6 rockers
- solid lift guys step in.
- oil pressure??
- Anyone removed all accessories (AC, PS, etc)
- More knock probs Any help Like a demon is in there
- help me finish my choices for my build
- How bad does this valve stem look?
- Good deal???
- 1.6 rr
- What TB brand?
- Roar
- cam duration @ .050(math)=adv. duration
- CSR Electric Waterpump Problems
- best cam for a non track street LT1
- lt1 to ls1
- back exhaust manifold bolts broken
- Stock...LT1
- I had no problem
- LE1 dyno results
- tb and bigger injectors on a cc306 + all bolt ons, is it worth it?
- 1.6 ratio rocker?
- Optispark Experts, Please Inform Me...
- Intake Elbow
- Beware of Ebay
- Are O2's Necessary
- cast or forged for LE2
- Opti w/o vacuum lines
- did anybody ever hear about switching wires 4 and 7?
- List of parts for cam swap and refresh
- What are my plugs telling me?
- need some EWP info
- Best springs for Rocker Arms
- arp studs, quick question
- LT1-injected 440ci conversion engine almost ready to go...
- Okay knock new probs
- CC306 Vid
- Motor is in car. Pics of single plane and rear mount distrib.
- No oil pumping up cold weather??
- All my LT1 problems
- Possible head damage need advice
- optispark testing
- are my lt-4 valves strong enough?
- Vendors . . LT1 02 sensors
- Dynaspark Gen 3 Users?
- Gas Milage/computer ?
- Best optispark for the money.
- Cc306?
- TB bypass question
- 383 12 to 1 compression and a stock starter
- 383 Initial Spark Advance Suggestion
- worth the change or not?
- Plastic Pulley?!?!
- cc305 vs. cc503
- Timing chain?
- Electric Water Pumps
- Comp Cams 280XFI anyone?
- LT1/LT4 Stroker Builder Who's the Best
- How much for my intake
- car wont start after freeze in san antonio
- lt4 rockers?
- CC305 Cam?
- 96 Smog Pump can I do without it ?
- lt1 spark plug problems
- 58mm holley throttle body
- Fuel Pressure?
- msd optispark
- HP guess for headers and rockers?
- Hard to start and stumble bad at 4500-5800rpms
- Whats a good Cam
- hotcam question
- i have got stock heads and need to know
- XFI Cam (Whats your highway MPG)
- ASP Underdrive good or bad
- pulley question
- gear removal question
- minimum pushrod to head clearance?
- what springs?
- Knock Sensor Problem Please help fast
- Beehive 26918 Install height question
- Radiator Worthless?
- Strange oil leak
- lets see those ported LT1 heads
- weird stumble on cold start up...
- Expecting too much from 383?
- is this a good deal?
- EWP install question
- Auto/2.73 owners step in....I'm looking at getting one
- Knocking/ticking noise
- Summit is officially selling the LT1 and LT4 manifold.
- Difference in cam from 350-383???
- Rpm's drop when i turn steering wheel
- Cam Install
- Crank Position Sensor Reluctor - Might have forgotten to install it
- Info on LT4 hot cam kit
- Cam that will
- water pump replacement
- Need answers on a 383 build
- Camaro engine swap
- Flow numbers for DIY intake vs stock, & LE2 head
- machining costs
- What else can I do to get MORE POWER but not break the bank?
- Does this look like valve-float to you?
- wiring diagram for 97' formula
- Head Conversion?
- Is the smog pump necessary??
- car acting different when accelerating
- adjusting timing on LT1's
- Motor from Autozone
- valve events help
- Getting new heads... Read this please, need help with additional mods.
- 96-97 lt1 in 95 T.A
- Ported AFR 210's just got back, need feed back
- MSD Opti Adjustment Screw...how to reach it???
- New Thoughts on Cold Air Induction
- Can the Crane valve spring compressor be used on dual springs??
- What to clean MAF sensor with?
- Which oil with 72k miles and slight leaks
- Will this work for LT1 Hub?
- I think its dead
- Dynoed my car today
- Stock Car, Where To Start??
- underdrive Pulley
- Need cam specs!
- I need roller rocker suggestions for a stock LT1.
- braided throttle cable options?
- car will not idle at correcr idle speed
- What you think my hp is??
- Milodon Pan MIL-30909
- cc503
- bleeding the system
- Please help with a few quick questions.
- weird miss, stumble at load/low rpms...
- TImes?? I'm new and need help..
- 1994 z28 newbie
- Effective Valve Mass, Effective Lifter Mass
- Teflon vs Rubber Rear Main
- XFI Lobes
- Blown Head Gasket? Worse case scenario help please!
- Cam=bad things
- 95 opti picture
- Can you still buy the LT4 intake?
- which cam is better help!!!
- Wont start
- Found my low idle tap
- Pushrod Length Checking!
- How hard is it to change plugs and wires
- 94 timing chain options
- Car wont start...
- What are your thoughts???
- Anyone running trickflow heads?
- Crankshaft Threads FUBAR'd
- Crossmember bolt sizes
- car wont start,need ideas quick
- Coolant pipe
- running temp
- Replacing Lifters-Couple Of "?"'s
- A few questions help please
- Pushrod Length for Trick Flow Heads
- 58mm throttlebody good for a bolt-on car?
- fuel lines??
- a flutter i cant get rid of
- Wierd Shaking
- scat rod torque specs.
- HI im new!!!
- 1995 Z28 special edition??????
- How Much HP am i pushing now?
- How much HP Was
- 0-60
- Lifters changing valvetrain geometry?
- Oil Leak? Possible Rear Main I believe!
- What kind of times should i expect
- 1993 camaro z28
- No Dyno?
- has anyone had luck with an poti from autozone or oreilly ?
- Best opti for Hi rpm
- low oil light sensor - wires came out, help fix!
- quick ses question
- Valve spring retainer question.
- Fans not shutting off
- need opinions on final touches to 355
- 6 month old spark problem (HELP)
- Sparying Oil, NEED HELP!!!
- Lt1 Piston Slap?
- HELP. LT1 won't start
- Broken EX612 Valve spring.
- Which cam???
- 94-95
- Need Constructive Criticism
- Dropping a LT1 in a 80 Malibu
- Fuel limitations of a H/C Z
- oil dipstick..bolt?
- ram air filter # Lt1
- New best for 396 LT1 - 11.7 @ 118.8
- Where to mount Digital-6
- Is my DS slowin me down?
- 3 & 5 crossed
- WHATS THE BEST SCAN TOOL? 94z28
- Powersteering help
- Please help diagnose some problems
- is this a good chart to go buy?
- Yet another ignition / starting problem
- Car overheated in a wierd way
- Trouble Code Help
- Cyl. Head steampipe hardline alternative?
- Car Dies & Diesels
- not sure if this the right place to post this?
- What do you guys make of these numbers?
- slight miss/surge
- crane 10308 kit
- Might be getting a 6spd vert LT1 T/A.
- i don't know what air box buy fro my new hood????
- found my misfire.. need some info.
- water pump question????
- What LSA should I install this cam on?
- compression with cc306
- MSA 6A - At what point do you need it?
- '94 LT1's & Optispark Question
- Changing spark plugs
- help asap!
- Those with LE heads/cam come inside again...
- i need help to decid on a le1 packegae or not?
- These TB's any good?
- Canton Oil Pan/Pickup
- Oil Recommendation..??
- where to buy 02 sensor simulators and price ?
- MSD Optispark issue:
- 1996 z28 lt1 need advice . . .
- Looking for longer O2 sensor.
- 93 and 94 lt1 cam specs? search won't work
- Did he replace the cam like he said?
- Just wasted $300 on a Opti that didnt fix my problem, now what?
- 383 LT4 not starting....? help
- pacesetter header leak.
- Which ARP studs?
- 96 lt4 in 95 bird...parts and fittment issue...
- Anyone against putting 1.6 rockers on a high mileage LT1?
- Will this 7 qt. oil pan work?
- Is it gonna hurt my madz28 pcm tune???
- 95 lt1 tq to yield head bolts?
- Melling oil pump users may want to look at this
- Is this something to worry about?
- oil pump??
- LTCC code 2 error???
- 98 and newer air lid on 97 lt1 camaro
- what will this setup yeild
