View Full Version : LT1 Based Engine Tech
- It Cranks But Won't Start
- coolant smell in cabin
- Timing cover bolt sizes??? i need help!
- Battery Cable Length
- Symptoms of bad O2 sensors?
- Dynoed my LE1 Setup.
- Rocker Arm question
- need inlet valve closing in degrees ABDC ( o* to 90* ?)
- Charging Problems
- Pistons...
- weird idle and car feels like its on 7 cylinders
- Size of low oil sensor
- Coolant plug in head
- Cooling fan question
- Thanks shoebox
- Dynaspark Install question
- Who currently has the best price on Mallory 685
- car died....help
- is the LT1 roller rocker stock?
- 425hp !!
- G-tech SS? How accurate as far as the dyno numbers?
- MSD 6a installation help
- Help!!! Rocker/valve metal on metal nasty noise
- cheapest way to change tire size
- which injectors to get
- Has anyone Rewired entire car using painless harness and switch box?? How did you do?
- Front and Mid mount motor plates, any significant advantage?? Who uses them??
- Belt tensioner pully, help !!
- Compression calculation correct?
- I'm Confused- high end miss - Iat Sensor
- car problem
- LT1 rebuild
- distributer problem please help
- Problem with Camaro 95' LT1
- what next
- spark plug not getting enough spark from wire?
- Solve my overheating problem
- Overheating and coolant issues
- spark plug thread repair kit??
- Retainers & Locks(Which Ones)???
- Dynomax Super Turbo Muffler
- Opti/ Delteq questions and suggestions
- Bad miss, stumble, surging
- Knock sensor thread size
- Head Gasket Question.
- What parts to buy with 1.7 Roller Rockers
- Header gaskets
- APE shortblock GP, and related problems
- 94 Formula Runs Like Crap Around 200 Degree's
- Intake backfire, slight studder..
- Help w/ codes 1641 and 1642?
- need good crank...scat ok
- spring retainers for 918's
- Crazy Dyno = Bad Opti ???
- Wheres best place to mount MSD 6AL inside car?
- Code 48 Mass Air
- Recommend some 3" (copper?) collector gaskets
- any pics of the brake booster
- Power steering pump elimination?
- April Fool.
- motor swap ?
- lt1 won't start, but when it does it runs fine.
- Paging Shoebox- fuel pump relay problem
- What is this sticking out of the Head?
- Do Accel Injectors Stink?
- Can Open Headers Cause This?
- Part number for NON-1LE elbow?
- Engine prep for supercharger
- More Car parts... What to do?!!?
- stout 1.6 rocker setup on stock cam (for now)
- Are summit brand rockers sa or nsa
- True Duals???
- battery doesn't seem to be charging
- 93 to 94 PCM HARNESS Conversion HELP!
- 94 headers on a 93
- Spark plug gap on TR55's??
- need help with oil pump shaft install
- Losing power up top?
- Lt1 engine noises?
- how hard is solid roller cam setup?
- need your suggestion on rods
- LPE CAI....97 LT1, doesn't fit!
- Stock spark plug gap?
- Super Victor fit in a 4th gen??
- Trickflow Heads (Advertised verses My Flow numbers)
- best place to purchase H beams/forged crank
- Can you ID rods
- question about ground running from coil to chassis
- oils leakssssssss
- opinions needed
- Optispark Troubleshooting
- CA Smog legal Headers
- any one running a 200 amp MR Alternator Alternator
- Doing 1.7 RR's. What parts do I need
- I need the gasket thiickness on the sealed power head gasket (no one has it!)
- Whats up with Speed INC? (ls1speed.com)
- 97 Z28 headers.
- $225 reasonable quote for gear change???
- Upper Intake Cooler
- What's the difference???
- Plug Wire with way high resistance,
- What plugs for cc306 Cam
- strange electrical problem
- Switching Catbacks...Question
- true duals worth going 3" ?
- rebuild questions
- Rebuild Engine??
- Calibrate speedo on a 97 Z
- RKSport Header flange bolt holes
- Intake Backfires
- Mufflex Catback or Borla you tell me.
- Need Help Major Skip
- OMG is this car a piece of work or what???
- stock or hp fuel pump?
- Best PA Emissions Legal Headers????
- best fuel pump...
- PN 10206039, LT1 or LT4?
- Finally have some pictures of my Stroker.
- what fuel pump should i get?
- Desired Idle Speed? 355 lt1? pcm tune
- Front End Squeak
- Who is better at computer tuning?
- How much is usual port and polishing on stock heads?
- installing engine
- OK, I'm going with the cc306, 1.6 rr's, springs, and leaving everything else stock.
- Is this package safe for a car with 110k
- Wrong Comp Cam Pushrods?
- Who uses Compcams guideplates on LT1 castings?
- Need help with how to adjust lifter pre-load
- Quick ? on installing SFC's...help
- Can this kind of water pump work with LT1?
- new rockers...
- Hot cam with 396; to small or what
- head gasket question
- P/N Request: A4 Dipstick Tube Seal
- Stock CC on lt1 heads? I keep hearing two answers.
- Accessory Bracket Bolt Size
- Is it worth it?
- Electric Water Pump HELP!!!!
- gm 234 242 539 558 cam
- hardened pushrods with S/A Rockers
- Egr ?
- Finishing up my 383 ?'s
- H/C + 1.6rr price list -- does this look reasonable to you?
- popping exhaust and no power
- car runs just a few problems left with volts, studdering, and fuel pressure
- What shift light mounts in the A Pillar?
- PTK 355 LT1 Turbo car with AI Advanced Induction heads
- Cam decision help need, flow #'s for heads inside.
- 116 gas and O2 sensors?
- Taylor wire part #?
- Stumble after Plugs/Wires install
- Aluminum or iron heads
- Any problems installing Pacesetters?
- accel 375+ ?
- Which plugs wires are long enough?
- Just got TF heads with few *pix*
- Walbro 255 intank for a 99+ Mustang work on a LT1?
- warped mac header flange?
- Trick Flow head spring question.
- throttle body plate gasket
- Headers do not line up.
- Auto meter A/F gauge?????
- NO POWER to my fuel pump HELP PLEASE
- Where is best place to buy a lt1 block?
- A car won't start thread
- Radiator problem?
- airfuel ratio at WOT
- How can I figure out what size my Aftermarket TB is
- doing a swap, wanna do mild rebuild, can i use alum bearings?????
- misfire issue???
- Anyone got a step by step on removing guage cluster from LT1 car?
- Borla Catback????
- Replacing Spark plug wires
- Rod Knock?
- dunno what the deal is
- Please help ASAP! High rpm miss?
- what to do for new fuel pump?
- Mystery Problem Solved w/OBDI
- stock lt1
- Opti ? and a few other ?'s
- Can someone host my Stroker pics?
- I Really Need Help!!!! Think A Small Bolt Fell Into Injector Hole
- Mystery coolant problem
- missing under a load
- 5.5rpm shift into 4th bang?
- MSD Blaster Coil?
- Would 1.7 Rockers be worth it for me?
- better rev limiter
- Cam Install Help Please
- Slowly losing power
- where is the ign module located on a LT1?
- is this true
- Please help, what else do I need for my exhaust.
- MSD 8.5 wire install on pass. side.
- passing California smog
- Looking for a reliable short block
- Low pressure VS. High pressure fuel pumps ?????
- Installing 1.6 Pro Mags, LT4 Springs, etc.
- Replacing V6 with v8 a bad idea?
- anyone ever see the bottom part of an injector come off SVO?
- Injuneer, FYI
- Very soft ramps a bad idea on a cam?
- 58mm BBK TB needs rebuilding... where to take it?
- Need more info 357ci LT4
- Vacum leak related to brake pedal pressure?
- Installed wrong coil on my car, sort of.
- Valve spring height check
- Storage of Used Lifters
- These headers on my 93... please help!
- rear mount distributor
- CA Emmisions
- Pacesetter TFX cat-back exhaust
- Fuel question
- my jet hot pics
- Motor mount question...
- rear main seal
- Doing long tube install, do you need to get EGR and AIR block offs?
- New in box opti broken!!
- Im in trouble!!! I was replacing the cap and rotor and ran into a problem. HELP
- Question about popping & Scanmaster readings
- Time For A Tune??
- CONSTANT TPS Problems!
- 96 PCM pinout diagrams
- Is there anyway to clear this code?
- lt1 383 stroker kits
- 246/252 @ .050 .550/.550 stock heads yay or nay
- What injector, SVO or Lucas(Delphi)
- Smells like Gas BAD!!!
- Cam install 50% complete, complaints and questions inside
- starting problems
- Headers??
- Blown head gasket, wish me luck!
- opti hose diagram
- Any way to test an O2 sensor? Still working on miss/hesitation/rich condition
- It died and I cant seem to revive it!
- spark plug question with different setups?????
- Auto meter oil gauge on a lt1 ? ahhh.... shoebox?
- Opti-crap question ( the inside)
- Do I need PCM mod. for 3200 stall?
- What clamshell bolts For poly Motor Mount
- Has anyone ever shipped an engine?
- Question about idle speed on startup...
- Best plugs and wire for stock motor?
- MBA LT1 Harmonic Balancer cover
- LT1 stock wire loom clip needed
- I Need Help Now!!!
- I took the opti off, where can i find the tool to take it apart. NEED HELP!!!
- MSD digital window switch??
- LT1 Rear Main Seal
