View Full Version : LT1 Based Engine Tech
- No spark! Opti?
- Should I run dual cats or a single cat???
- Pulled motor, accidentally pulled two wires out, what are they?
- trouble starting...new fuel pump
- Oil pressure sensor , How to change it
- AFR head question.....
- Which degree wheel to buy?
- 2otl installed
- keep blowing a fuse....
- getting giant cam to pass emissions
- Fuel issue
- Oxygen Sensor Part#
- Buzzing sound
- uh oh
- Shift light not working MSD Digital 6 + LTCC
- difference of this 2 hookers mufflers?
- Can anyone tell me the difference of this 2 hookers mufflers?
- Magnaflow exhaust not thrilled
- 95 LT1 auto won't crank, no start - please help!
- Thermostat.
- o2 sensors
- 2 quick questions
- LT4 starter install problems...
- When to Replace Ignition Coil
- Front end assembly torque
- WOW, insane bill from machine shop
- 130K miles small cam okay?
- PCV problems, help?!
- header ground clearance? please help!
- EGR Blockoff Help
- What do you have to do to make a Flowmaster loud? Everyone who has it come in...
- Comp Cams Guideplates?
- Synthetic on a 93z ?
- Oil Pump
- Alternator? Issues
- Cam choice...elevation a factor?
- Periodic problems starting 96LT1 and suddenly dies as well.
- Oil
- grinding sound
- Spinning bearings due to oil cooler.
- I need a good start!
- Opinions on my fuel problem
- Moving Back To California! Will this Pass???
- 1996 camaro needs some more hp!!
- quarter mile time estimates
- 3 1/2in cowl induction. Intake Possibilities?
- Replacing oil pan, need some help =)
- 383 Dyno results
- Part number for lt4 knock module?
- Car run's like CRAP in closed loop
- roller rockers
- service engine soon, misfiring, and voltage bouncing???
- Is there a separate computer for abs?
- Valve Cover Supports/Bolts
- changing front main crank seal..hard?
- Low oil pressure? Need Help!
- electrical problems!!
- power washed the engine bay and problems!!!!!!!!!!!
- Electric cutout owners, where did you put your switch???
- A/C hose next to batter P/N
- Wont rev past 3.5k Fuel problem. I need help!
- How many miles are on your LT1 ?
- 8k miles, header install, bad 02?
- Coolant Leak Passenger side, leaking on starter
- for the mains should i go with arp studs or bolts
- Overheating......HELP
- Can I re-use barley run Intake Manifold Gaskets?
- will mufflex y-pipe fit dynatech longtubes?
- Bought a used block- Owner said it "smoked" ??!!
- Misplaced my OEM Serpentine belt, anybody know partnumber ???
- Car Not Starting!
- Engine on a stand? Coyles double roller chain? Gonna use a vented opti? come inside
- keeping my engine cool under extreme conditions!
- beating the egr flow ses light?
- temp sender adapter ?
- What do i need to beat this Foxbody
- Asr 94
- 3.73 to 3.23 ?
- Super charger set up. Good idea or nah?
- 11:1 Cr
- in speed density = no more power loss
- swapping a radiator
- ZEX kit or Predator programmer
- FI, rotating assembly help
- Got a crankshaft question ....
- Brand new engine misfire
- Funny Oil pressure readings and volt issue
- Fuel pump or Optispark?
- More opti questions
- Advise on rebuild ---> Please
- Want to run cool...
- injector question
- mac headers on my 1 inch lowered z28.
- Re-built engine-other mods- dyno tuned- and still terrible
- Question..
- to stroke or not to stroke
- JUST GOT DYNO'd
- air in fuel line
- Pulling Engine.....Next Mod?
- lt1 traction
- I hate my car but love it more
- 1.6 NSA pro mags, guide plates...clear valve covers?
- horror day at dyno
- What do you think my car will dyno?
- Car Shaking?
- OBD 2-> OBD 1, gauges???
- valve spring seats on stock heads, question?
- Spark Plugs..Having a hard time reading them
- whats the concensus on the filtermag?
- Oil Leak need help ASAP!
- Cam Gurus - I have 2 cams, help me select which one to use
- ***!!! Darn power steering!
- opti caked in oil
- Low Temp Thermastat at a local auto parts store?
- Is A $400 Dyno Tune A Good Deal?????
- New Meziere electric pump overheating car?
- Belt Tensioner pulley bolt?
- Need Help!! ticking sound coming from engine
- I have a "MISS" AFter engine is Gets Warm
- Would this hurt my Porformance??
- Oil pressure at 0psi, car still runs
- LTCC Help Needed (3 red flashes)
- spark plugs?
- opti vent hoses...it hooks into the intake elbow?
- Want to swap an LT1 into a '91 Suburban
- How many miles you guys with 383's getting out of your OPTI
- Vibration at high speed acceleration????Help
- **Need halp fast**
- rocker arms
- LT4 intake manifold
- Fuel problem
- How often should you re-adjust roller rockers?
- Please, help me build my own stand alone fuel system.
- need some help!
- Burning oil at startup?
- CSI Reliability
- Questions on some mods
- help!! How coolant light!!
- Another complex overheating lt1
- Which bolts for accesory bracket??
- how can you tell what lb injectors are?
- Daily Driven 383
- Tips On A Tune Up
- Replaced fuel pump, still have problems.
- 200 or so shot of nitrous with forged bottom end but stock heads?
- How far back should a muffler be?
- Help! car won't start again!
- 3:73 or 4:11 gears
- 383 build LT4 heads - question about Head Gasket
- DTC 21 - TPS too high on Holley 58mm TB. Any ideas on how to fix?
- Changed the dowl pin on my 383 stroker cam
- Which K&N filter will fit on the Moroso intake???
- Bracket On Heads!
- should i use gasket seal when mounting elec water pump on stock housing
- Fuel pressure problem
- my car wont go to closed loop
- OBDI to OBDII
- Can someone check my logic
- 93 LT1 and adjustable fuel pressure reg.
- Strange Misfire or stumble when car is warm?(searched already)
- waterpump rebuild
- what the heck
- change cams???
- Oil in my tail pipes
- water pump goes out!!
- where to wire fans to???
- Anyone ever seen an oil leak *here*?
- underdrive pullys!!!
- whats a good way to clean stock injectors while out of the car?
- Header list, confirm
- Intake bolts?
- 1996 z28 LT1 or Lt4, 2 bolt or 4 bolt?
- Knock retard at idle but not higher rpms madz28?
- Engine is finally in the car!
- pushrod length
- 96z28 Gutted Cat
- where is the PCM Ground?
- car eats optis for lunch
- where can you get air fliters for slp cia
- coolant bleeder pipe
- Stock Hp range
- Fuel pump check valve
- dyno results; want to make it to 300 rwhp
- Gas Pedal Stuck, Maybe Cable?
- Help. I Have Traction Controll on my 95 Z and I cant find a Cold Air Kit to Fit
- slp fan switch stoped working
- just when i order parts
- Pacesetter did some R&D work on my car
- plug wire clearance from header 1/8"
- INjuneer and shoebox File within
- Rebuild/low oil pressure
- Hooker Longtubes with Sidemount Valvecover looms...!!
- Building Valvetrain!.. How does she look?
- Important Help me!!!
- Codes being thrown..Help me!
- question for le2 cam owners
- Mac Headers install worth it
- Pacesetter LT guys, quick question
- Lt-1 Motor Install??
- ASAP Can I run without Rear Sway Bar?
- hard start up, won't start
- how many pony do you think i will be able to put down???
- LT1/LS1 Electric Cooling Fans??
- quick intake elbow ? (with slp cai)
- HELP -issue with adjusting valves
- new timing chain?
- Overheating - Still not solved
- stock internals handle an LE2 package?
- Need HELP! ready beat car with slug hammer!!!
- poor acceleration under load...spark missing?
- Delteq wires
- LT1 spun a bearing for the 2nd time after rebuild.. What the heck???
- Gains with CC306, 383, 58MM TB, etc....
- car broke.. 383 time? or no?
- rocker arm studs
- Lt4 Cnc H/c Rwhp#???
- is this true??and what else??
- putting motor in through top...
- turning engine over
- security light
- High RPM miss/cutout
- Help!! ABS INOP light and Brake light both on!
- Heavy duty battery cables
- LT4 Hotcam issues and gains
- speedyjr..........11.4s??
- O2 sensor extensions
- Do AIR tubes get too hot for....
- spark plugs angled?
- off road LT's vs EGR AIR ones
- my fans run and SES light on when i start
- cam is 224/230 getting springs but need to know about beehives
- What size belt
- At a lost...Code 44(LO2 Lean)..replaced both O2's??
- Total cam swap cost
- Oil leak at oil filter- What is going on?
- Car quits then restarts - help with codes please
- Crank indexing/ big problem?
- Engine Codes
- Whats my best bet for RR brand..
- Ramchargers Scanmaster & Translator Plus
- Is my Fuel pump dead?
- ARP 4 bolt kit
- What is this part number and whare can I get one?
- Most Quiet Exhaust
- retarding timing for N20?
- Overheating Question
- Dont Buy From.....
- Putting motor back in..
- Will This Work??(Battery Relocating Wiring)
- Replacing rear main housing gasket
