is it ok to pull a head bolt to reseal it?
Old Jul 19, 2003 | 01:21 PM
Z95m6's Avatar
My motor only has about 1k on it and i am changing oil and i noticed one head bolt is leaking coolant. It is very easy to get to and i was wondering if it would be ok to pull that one bolt put more sealant on it and retorque it. The head bolts are ARP's so i can retighten it. Also should i torque them to gm specs or arp specs for a head bolt. I don't remember what i did the first time.
Old Jul 19, 2003 | 01:25 PM
thewinner's Avatar
personally, i wouldnt do it, would throw off the clapming on the head
Old Jul 19, 2003 | 04:18 PM
Leaking = poor situation.
Don't tighten bolt = situation might get worse, no chance of improving.
Tighten bolt = possibility of improving the situation. Maybe less chance of making things worse.
If you do reseal and tighten, you might check the torque on the bolts around this one.
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
Chris Anderson
Jan 27, 2015 08:30 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Catmaigne
Dec 25, 2014 12:16 PM
thenewkid
Nov 27, 2014 09:41 AM
