View Full Version : LT1 Based Engine Tech
- How high will this cam make power to?
- horsepower?
- Help me please decide.
- Guys with bad heaters check this out
- Low mile injectors
- Where to buy Custom Valve covers?
- need p/n for GMPP cold air induction kit for 94z
- How many quarts of oil with PF1218 filter??
- Stumbling Problem in Great Detail
- Strange Problem
- 383 question
- Buying a 137,000 mile LT1
- 160 blms on drivers side only at idle
- Some reassuring words for lloyd
- Code Trouble
- windshield wipers
- ABS/TCS quick question, info needed
- How many miss fires r to many?
- awesome... car was pulling serious degrees timing
- Pointless to get a bottom end rebuild without ported heads?
- 396 stroker part advice
- NeverEndingStory continued!! CAM Problems
- Autozone Aimco Rotors?
- consequences of timing failure
- Still stumbling and stuttering and hesitating
- CC306 Smog??
- EGR went to crap?
- Anyone have experience with PaceSetter Headers?
- "Free Mods"...
- Will 14" wheels fit on a 94 camaro?
- How many miles do NGK-TR55s last?
- trash!!
- Voltage problems...drops under wot
- 02 sensor question
- exhaust manifolds
- Hpp3
- tps voltage
- To put in a new cat. converter, I need......
- 160 T-stat
- Pesky Coolant Level Light
- head porting.
- intake question?
- Best sfc's for a 94z28 vert
- Coolant in the oil pan?
- Custom shifter needed for M6 in 58 Camino
- LT4 KM part#
- Anyone test resonators for HP loss?
- Can I use these Injectors ?
- how much could i get for my car?
- SLEEPER time
- Compression test...
- Where to buy 02 sensors
- What to do next
- is the kenny brown DD SFC worth it?
- Waterpump seal...
- Quick Question
- Low MPH with Hot Cam, WHY??
- Adjusting Fuel Level
- Weird question
- Summit Racing?
- trans. mount question
- Help make my car run!
- Feel like a traitor....sold my 97Z
- new exhaust idea
- need obd2 pcm pinouts...
- replacing fuel pump
- Best header gasket w/ hooks on the end???
- Does anybody have or heard a Magnaflow?
- how to get ahold of jason cromer
- Cold Start????
- Question about cam lift
- Help asap please.. intake elbow..
- Are Hooker LTs the same as The Jet Hot coated headers.
- Salad Shooters and 255's
- opinions
- Electrical problems prior to startup...
- Scanmaster Questions
- Comp 224/230 Cam Q's
- lt1? TPi?
- Micrometer?
- Lightweight flexplate/flywheel?
- Eibach Drag Launch Springs 2-4 tenths off et???
- 383 stroker people what do you run??
- what temp does your camaro run???
- SLP Products
- Worth getting this chip?
- custom CAI
- OBDI v6 vs v8
- Removing Oil Dipstick?
- gear question
- Just Getting Started Questions
- CSI.. Nothing goes as planned
- XE230/236 and emissions
- Good price on flowmaster???
- where to buy clutch disk?
- A cure for spark plug wire problems?
- Dyno Videos
- Tools
- 93 Z28 Fuel Gauge Not Working
- Headlight problem
- SLP's convertible subframe connectors are now available!
- What do I need to install hotcam kit?
- '95 ORB1 and 3200 Stall with 2.73
- abs inop light on
- Are 12's possible w/ my mods?
- lt4 computer question
- Idle Question
- got my cut-out installed today
- cam/spring break-in procedure?
- LS1 vs LT1 rear rotors. ANy diff?
- My stock exhaustw/ cut out vs 4 inch straight to muffler
- Strange sound when I shut engine off-see what/where
- Good place to buy a stroker kit?
- I need help fast
- Welds & Backspacing questions
- Valve spring size?
- Need some advice here.
- Anyone have the link to "how to make your own datamaster cable?
- Do you need new bushings with LCA relocation brackets???
- Maintenance Questions
- Newbie Alert!!!
- Chris96ws6 or others experienced w/ cc304. Hell just people that know cams
- please help w/ timing chain! which for electric wp
- Granatelli MAF worth it?
- Leaking Oil from TB!!!!
- Header torque specs?
- Dynotuning for both OBD1 and OBD2 LT1 cars in Florida?
- extras with cc306
- What are the causes of knock?
- Sportlines and Boxed Subframe Connectors
- Radiator hose, are they prebent??
- Removing LT1 injectors
- Radiator not held tight after a/c delete
- Please help, brake line related
- 4000rpm sputter doh!
- 16X8 tire size question?
- Q about throttle body
- Anyone use the SLP Loudmouth
- Lt1 vs. Ls1
- Mac Headers w/ orp
- fuel line melted how hard to fix
- clutch disk
- SLP Loudmouth specs
- What's the best sounding exhaust for the LT1
- time for bigger cam
- How do I tell if my cat is bad? (NT)
- T-tops are leaking
- Noise coming from Front left wheel
- 11.2:1 CR vs. 10.0:1 CR on a 383, ported heads...all the same, how big HP diff ~400?
- Exhaust for LT1
- QUICK Traction Control Question.
- Cheapest place to find HotCam Kit?
- Gear Swap After effects questions
- LT1 steps
- Guess what i just got?
- Bolt in VS. weld in SFC
- Mufflex made dual cat y-pipe, PICS
- sputter around 4000rpm
- what to do about my star stage 3
- Is this a good replacement motor for power windows?
- Will the valves hit the pistons?
- BBk pulley question
- Who Wants A Full Gauge Pillar for a 93-96??
- o2 sensor or cat...
- Headers for autocross/stock motor
- Whats the....
- wireing problem
- cash to go fast
- German made synthetic oil?
- Headers Question
- Little things to do
- fixing intake leak
- Heads and Cam coming soon! what to buy...
- Air filter options
- '94 trans work in a '95?
- Do Not Buy Product From Fiberglass Fabricators Inc.
- When to change the oil....
- Battery Question
- spark plugs
- Lifters
- Harland Sharp Rockers
- what gaskets to use for porting?
- homemade airfoil
- I'm an idiot!
- mac header installation
- Fuel filter
- Valve cover modifications for rockers...
- People using Ford #30 injectors come inside
- what ignition box?
- best price for et streets
- hypertech programmer
- OH Poo! Opti bolt broke in block!
- How do i get ahold of Lloyd for a port job?
- Changing oil pan gasket?
- self built Stroker
- When did your tranny start to go???? If it good how many mile you got?
- Taking battery out with LT1 Edit
- Any tips on removing the EGR valve?
- air foil with NOMAD's 52mm?
- True Duals with Full-Size Mufflers
- Any way to have a quiet valve train with 1.6 rr's?
- Stock timing chain slack...
- LT1 Tune Up
- Pulling airbags.
- How to ruin your car!
- Y-Pipe knocking on frame
- Guys with K&N FIPK...
- Tranny problems due to aftermarket TB?
- Heads and cam fellas....
- I need Comp R lifters!!!
- will LT1 gears work on an LS1
- Any one with LT4 valve covers and Made4u looms that leak oil?
- 0-60 times?
- Gear installer said Motive 3.73s were too big?
- looking for part number
- Thud, knock
- Sweet!
- Preparing for the track
- Want to delete A.I.R. have a couple questions
- sensor life expectancy
- Getting an LS1!!!!
- Painting Subframes???
- Is this LT4 worth the money?
- LED Light.
- Should i buy my friends Adj Borla for $175?
- broken dip sticks
- New Headers!!!
- car dying problem!!!
- Water Pump replacement on Grand Am???
- Good oil for storage
- What will I need
- what arp header bolts to get?
- AIR vacuum solenoid valve - where does it mount?!?!
- Making your own 383 stroker??!!!
- Any new information on Kook's Headers
- Couple vids of my car
- Is the G2 CAI respectable?
- Got 100,000 miles, what to do maintance on suspension, what should I look at/for?
- Anyone change their water temp sensor??
- How hard is it to replace my shocks?
- How can I test my CSI to make sure it is working??
- Bad Alt?
- 355LT4 or 383LT4
- Bryan at Pcmforless
- Car is idleing funny, any ideas?
- Cam choice VS Altitude
- gm 847 cam and s/a roller rockers?
- Anyone sell over-the-valvecover wires in Yellow?
- Rust in cylinders
- Wires burning up after LTs installed?
