View Full Version : LT1 Based Engine Tech
- Exhaust POLL
- GM part number (lifters)
- Is upgrading from shorties to Long tubes worth the $$ ?
- where to buy an lt4 km
- What are good lifters to use on an LT4 hot cam swap?
- LT4 valve spring swap - accessories
- lt4 km
- Basic Suspension Mods
- 600rwp with an NA LT1 opinions
- Has anyone bought the new black 40 Series Flowmaster??
- Where is the block heater?
- Rear-end lubrication level question.
- gas tank size?
- K&N 3002 oil level ?
- Need Help Fast, Can I run Two Timing Cover Gaskets??
- opti install- Using bolts to pull opti flush?
- Car randomly dies...seems ignition switch related
- A4 to M6 conversion codes
- Easiet way to hook up temp gauge
- 383 ?'s
- what's next
- 2 cam related questions
- Hooker vs Magnaflow
- Cam spec design theory
- 95 shift kit
- desperate need of help
- I need gaskets!!!
- Valve guides and 1.7 RR's
- Front Seal ?
- Rebuilding an Alternator ?
- Stupid question
- I need taller valve covers???
- pro 5.0 install question
- Gas in my oil?
- Oil pressure sending unit
- independent rear suspension?
- LT1 4 bolt ? and Windage Tray?
- anyone replace outer door handles
- Wipers won’t park and washer fluid won’t pump…
- How hard is it to bend the rear axle?
- Cams
- What oil pump do you like?
- fuel pressure release...
- MSD Coil Part Number
- bad stumble at idle
- surging/missing?
- 1LE What is it and do I have it?
- Hub&Bearing
- What springs to use for .600 lift?
- TB Bypass
- low oil pressure after redoing head gasket's
- How to tell if my optispark is dying.>>>
- Afpr ????
- low coolant level light in 94 Z28, need advice
- LT4 knock sensor
- Will SFC's help my times much???
- LT1 passkey system
- question about air intake
- Usaed Macs?
- rear brake rotor install?
- which lt1 head gasket??
- Oil level sensor.....( Canton Oil Pans )
- Tonight, Stock alarm randomly sounds and dome light wont go off. HELP?? (did search)
- A good pair of heads and cam helps me in high altituded places??
- Best LT1 tuning Software????
- Trans Perf Button P/N
- Free / Cheap Mods ?
- I Need A Part Identified
- Rattle noise while revving in neutral, and at low rpms. HELP
- Putting Keyless entry into a no power anything car?
- Self aligning vs Non-self aligning rockers
- Joe Overton cam
- Broke a header bolt
- Coolant leak
- if i get in on this GP....???
- MAF Translator instructions
- lt vs SBC
- Bought new coil, icm, and still won't run!! (Shoebox any suggestions?)
- Dyno cross at 5250?
- Replacing Oil Lever sensor question
- Shocks and springs
- Cam solutions...
- Put the 350 in the V6
- Power seat from `99 TA to 95 Formula, need help!!
- Will 17x11 ZR1s fit with bump stops on?
- Using new piston rings on stock block
- what's the typical price for......
- 383 vs. 396
- best place to buy head/cam package?
- need help with block casting numbers
- Do the front tires really matter??
- jacking up the motor
- Help - Weird upshifts
- Fed up with this bolt!
- Info on air/fuel &FP gauge
- headlight question
- Rear End question ASAP
- Installing TA cover..
- For those with SCANNERS or SCANMASTERS... please help.
- need help tuning or any suggestions
- BLM's 118 and lower..??
- SLP 'Brake Control' info anyone?
- Fuel Pump Switch
- CAI on Trac Ctrl. Car
- Turning NonVented to a Vented
- what is the best ignition system for lt1
- Brakes
- people with racetronix fuel pump kits
- Bad o2 sensors?? PICS
- Best cam selection for my setup?
- What is the opti alternative with the LS1 coils
- Where does this wire lead to?
- Fuel pump, check ball questions.
- Thoughts on Auburn Posi w/ 3.73
- Has anyone EVER run these tires?
- Oxygen Sensor Analyzer
- trouble shooting....probably simple
- Finally got my headers!!!
- Nitrous and 02 sensors
- Is there a stand alone LT1 controller?
- LT1 Throttle Body question
- Are 3.42 gears appropriate for me?
- cam install gaskets
- keep losing brakes
- bay area cam install ((who wants to get payed))
- 355 vs. 383
- Will a bad o2 ALWAYS throw a SES light? 93 related
- angling long tube collectors for ground clearence.
- LT1 headers question
- Corsa catback rattling like crazy
- Heater core is gone!!
- Is this motor, trans & rear end still good after 8 years???
- valvetrain noise?
- Crane Sa 1.6 Rr Preload...
- Lightweight Carpet
- CAI, Thermostat and Idle
- weird transmission finding, worry or not?
- Opti Test
- Whats the website for autotap. Please look!
- Camwise, What makes an engine rev quicker?
- New Problem Maybe
- How much power kills the 10 bolt?
- Just received my Hooker Cat-back, question...
- Hard Starting, Coil Arcing
- which fuse?
- SLP header install
- starting and dieing?
- LT-4 heads or get my stock heads ported?
- dynaspark update, hurst shifter
- Car Wont Start - No sound from fuel pump on cranking
- TB Bypass - 94 vs. 95-97
- Best way to check timing is correct before installing cover???
- $30,000 dollars!!! What should I do???
- Where to Clearance Timing Cover for Double Roller Chain??
- T56 question need help
- slotted/drilled rotors
- rounded head bolt
- Edelbrock heads
- Important information regarding MADZ28
- all chevy engines
- Do i have to use a Canton Oil pan with the 396?
- 400HP 383 LT-1 from Golen Engines
- Anyone like theLT4 heads?
- Assorted G2G pictures from dyno!
- midwest converters, any good?
- What crank to run for 450hp N/A LT1 and 300shot?
- Crank Position Sensor Part #
- do I need to remove rockers/pushrods for pull the heads?
- '94 LT1 6-Speed, Basic Questions
- Fuel Filter Replacement
- getting rid of water pump driveshaft
- DTC #42
- What all I do I need for a cam install?...
- SS intake
- Looking to buy some shocks!
- OVC kit help... parts
- So is Combination Motorsports open or not?
- Need mis NX parts
- SERIOUS PROBLEM new motor LITERALLY smokin
- Spitting out the transmission dipstick
- fuel pressure gauge
- Opinions on BF Goodrich G-Force KDWS
- Complete install LT4 Hooker
- gas lines???
- Stock headunit questions..
- brake pads... semi matalic?
- over valve wire kit just in
- alignment
- Brake Rotors???
- foglight bulb size??
- trouble placing pictures??
- Scat Budget 383 cubic inch Rotating Assembly from cmotorsports.com?
- VATS/pass key.. bypass disable???
- Anyone using the S-10 Torque Converter?
- Caliper dissasembly
- Pace setter Lt's or hooker shorties?
- Trick Flow LT1 heads
- pics of my cars
- 1LE elbow
- check this out for 96-97 SS owners
- Which would be the best way to go?
- K&N on 96-97 SS not recomended
- what radiator do you recommand
- Summit Rebuild kit
- How to drop my IAC counts
- Pushrod Help - Weight
- injector ?
- Cutouts - Few questions
- Another "guess what I'll dyno tomorow" thread!!
- max rpm for stock lt1, speed in gears?
- Need Part Number Help
- 700r4 vs 4l60e trans pan
- Service light kinda blinks? Misfire?
- donkey dong
- replacing the window regulator / motor
- Now whats going on here!
- Should I buy???
- Part Number for the Oil Pump Drive/Camshaft Gear
- Will 275 tire fit on a rim 8" wide?
- ticking sound
- Car Die While It was Fixing to crank it up
- how to remove fuel rails
- quiet catback?
- Hooker vs Jet Hot Long Tube Headers
- keeping close to stock compression ratio
- Vac from opti/94 intake
- help with roller rockers
- Changed oil, misc stuff. INTERESTING FINDING!
- Smooth Locks
- window help(help in IL)
- MSD plug wire burnt
- MAC Headers and ORP
- cheapest place for Crane 99893 springs
- stock studs with GM 1.6 SA rockers
- Steering/Suspension problems!?!
- Cost for a new rear axle '95 Z28 Auto?
- Need views from anyone who has driven a lt-1 with bolt on's and a stock Ls-1.
- CCA-7808-16 Comp Cams 5-16" PR's
- EGR Tube Repairs, Any Ideas?
- how is your car in the heat?
- Header Confusion
- anyone done a complete Autometer gauge cluster?
- crazy looking rear differential covers
- This noise is driving me crazy!!!
- Cutout Installation
- how much is to much
- bilstein p/n ???
- NO! did i just F**% myself!
- LS1 airbox under stock LT1 hood
- best deal on 396 short block
