View Full Version : LT1 Based Engine Tech
- Heavier oil may be worth a try with hydraulic lifters!!!
- MSD blaster coil
- Pull Motor or Body Lift??
- ls1 lid on lt1 need help !!
- RHS 235 heads and Super Vic IN THE CAR BABY!
- fuel injection flush worth it??
- No fuel/No spark :(
- Something weird happened today..
- Unplugged IAC and car ran, what the problem (93 input need too)
- Summer Tune Up? Opinionators inside please
- Tranny leak, NEED HELP.
- do i take timing cover off w/ new EWP??
- initial dyno
- OK what shuts a 93/97 off after running for a couple seconds?
- stupid question
- Fuel pump "bucket" not sealed, Problem?
- cyclinder head 12555690
- New water pump now car won't start
- Starter runs continously
- losing power at higher throttle engine just revs
- Passenger side header
- EGR block off
- Dipstick depth
- Pulley won't go back on.
- NightTrain 66
- Pics of SLP lid and Nitro Daves noid mount
- Dynatech opti
- lt4 long block
- Need to replace opti seal when changing opti?
- 1.66 as a bolt on
- LT1 vs. LS1
- 383 stroker on EBAY, WHAT DO YOU THINK?
- Service engine soon, very habitual, depends on weather
- Thread chaser size?
- got my heads flowed
- Cranks but won't start...no spark??
- ET Prediction for this lt1
- MSD Cap/rotor question
- 383 lt1 loads up with fuel at idle,
- Help a fellow CZ28'er out......please read.
- optispark
- Throttle response less after car warms up?
- valve covers??
- gmpp guideplate pics vs. edelbrock
- 94 starter interchange?
- Here's Morosos answer to HV oil punp/stock pan combination...
- RR to tight, loss of power?
- Final mockup pics, going in car Saturday
- Just seeing if LT1's just have a vacuum problem??
- Car running rough at low rpm
- Way to measure cam dowel pin legnth?....
- plug wires!
- Delteq w/headers?
- Low oil pressure and loss of power
- 97 Engine harness into a 93- Any thing need to be adjusted
- lt1 to 69 chevelle swap questions
- Will I Need An LT4 KM?
- beehive valve springs
- lt4 starter from an auto parts store
- can an opti be fixed?
- LT1 no start-help!
- I need some Gm part #'s and spark plugs?
- rear mainseal ??
- Motor mount question????
- TA project questions
- What Weight Oil For A Fresh Motor?
- stalling problem
- Comp on pump gas LT1
- Goodies have arrived.
- Anyone here ever use a Lunati 54743?
- How much hp gain?
- Thank you, Lloyd Elliot (LE3 pic's)
- Changing heads with
- oxygen sensor part #?
- Clunking noise from A/C?
- Switching to non-emission headers
- Delteq Coil Upgrade Can I Use These !!!!
- Wire gauge for O2 extensions?
- What engine oil grade should i use?
- what does it takes to beat an LS1?
- HOW much engine oil goes in a stock 5.7? (1996)
- Lt1 Pinging higher rpm
- Opti?
- Canton Valve Covers, Custom Alt Bracket, pics inside
- 396 timing chain
- Weird coolant problem.
- Comical H/C dyno numbers
- how much stall?
- Backfiring issue
- Steering linkage wont budge.
- Code 29 Secondary Air Injection
- LT1 rebuild, victory?
- All thats needed for head gasket swamp.
- ways to get more power out of a cam'd 355 without porting heads?
- Leaky oil level sensor
- Motor mount tutorial?
- Short block SWAP
- 3 Quick Rocker Stud/ Poly Lock Questions..
- Opti shaft seal(small "o"-ring)
- Attn: Engine Builders
- Video - My LE2 Journey
- leaky distributer seal
- How much compression for 355 on 91 octane
- LT1 SWAP Please help!!
- difference between code #32 and 400?
- 1/4 time with mods
- Under plate intake manifold bolts torque specs
- ported MAF, worth it?
- HELP! do I have LT4 heads?
- Valve springs on trick flow heads good with 224/230 cam?
- Rocker Upgrade From 1.6 To 1.65 Quick ?
- GM LT4 Intake worth $400?
- Over reved the MSD Opti???
- Wiring electric water pump into ABS circuit
- one wire needed to be hooked up
- '94 + aftermarket cam options.
- Erratic coolant temp gauge
- Where to get ws6 ram air box seal to hood??
- H/C swap down time.
- 96-97 Engine Diagnostic Trouble Codes Lists.
- bleeder screws backing out- help
- holley 58 mm tb
- Stock head casting flow numbers
- 400 RWHP build help
- Need help on engine symptoms
- what are these codes and how to fix them?
- Crane gold RR's..
- Corsa with LT's
- have bottom end knock, want to rebuild, need help
- Edelbrock LT1 Intake Manifold
- lt1 swap into 1980 trans am
- optispark oil seals
- need help choosing cam
- this is a good one
- Is there any way to test optispark?
- LT1sounds.com needed
- ECT sensor for PCM on Water Pump
- roller rockers?
- Cam
- input on Crower Enduro series full roller rockers
- Best deal (Cheapest)
- motor tries to stall when stopping
- rings or starter?
- 94 opti seal
- While replacing the rear seal...
- 2.00/1.56 valves..... Question?
- B&M Shift Kit???
- Need Straight Answer (Plugs)
- so I'm tyring to fix this problem...
- Oil Pressure low after CAM install
- 4.10's
- PCM MAF problem
- Found out I have Hypertech chip..
- NE one ever snap off the crank hub bolt?
- k, i need help fast!!! please!!!
- Do I need to replace my head gasket?
- ls7 lifters
- Slp Lt1 / Ls1 Maf
- Canton Valve covers
- Low Coolant Light
- Le1/cc306
- Crank Hub Removal Help
- Stock Bottom End
- standard length pushrods with new cam?
- how to install water pump seal
- New best today, pulling the front wheels on launch
- Intake and TB question.
- Are 1994 z28's, trans ams & firebird formulas as fast as eachother?
- need a belt for bbk crank pulley..part #??
- Miss fire?
- steam pipe in the back of each head..neccesary?
- Harder to start after minor mods?
- Could vacuum leak cause DTC 64 code ????
- Loose Harmonic Balancer? help please...
- Aftermarket steering wheel problems - Need help
- who wants to shop for me LT1 swap....
- got the bird dynoed
- New pics, and XFI 292 sound clip
- Throttle Body Question
- Good FP.....no pulsing injectors
- Hypereutectic Pistons: How much NOS?
- Alternator: How much power gain without it?
- Thunder Racing OTVC Plug Wires
- Car is not where it should be
- Another wont start thread
- Low idle when in gear
- Which pellet??
- lt1 in a hotrod need some help
- Cam help, to do or not to do that is the question
- odd starting issue
- Possible to get just new rotor bug for opti?
- Good question from veteran member idling prob
- somethings messed up
- Car bucks at low throttle, in-town driving at 2K RPMs
- cam
- Speedo twitching and falling
- Ran slow at the track
- P1351 Code Help Needed! Thanks
- Dumb question - PCV Valve
- lt1 edelbrock intake
- Car misses under load when its cold and a power dip at 5800
- Need help, New engine will not start!!
- crane oem lifters and RR adjustment
- Canton valve covers
- So I found a CRACK in my HEAD...what can I do? Pictures inside...
- How to clean contaminated lifters and rockers?
- Whats needed to carb an LT1?
- Looking for good eng. combo lt1
- Rocker Arm tightening help needed!
- I need help, where does this go?
- Cooling Fans coming on at startup?
- another knock sensor?
- fuel pump relay issue
- Water pump cover gasket??
- How many bolts holding the power steering pump?
- Car running crappy
- ses light when fans come on.
- valves
- spark plug suggestions
- help
- Who's using Isky 235-D springs? Valvetrain experts?
- professional products throttle bodies
- Car starts then dies...
- need a good shop
- timing cover help please
- I need info
- Anyone Running AI 200cc cnc heads
- Fantastic! Got some work done today
- cam install questions need help fast
- 385 LE2 Setup, 466rwhp 449rwtq
- wierd codes
- what should my oil pressure be? (385 LE2)
- Putting ls1 heads on an lt1
- Kmotion k800's
- under dash tach wire location on a 0bd1 94 z?
- rod bearing clearance
- Will LS1 spark plugs work in Lt1?
- Hard starting with a ses light
- Oil leak/AFR Heads and LT4 Valve covers
- 224/230 on a 110LSA vs 112LSA
- car running richer than heck
- spark plug wire part # or link?!??!
- so...is this supposed to be here? (pics)
- gallons of coolant
- head turnaround times
- Another Breather Idea
- Lifter position
- Help! I think my Opti-spark blew up
- Heads/GM847 dyno... dissapointed
- Need help quick
