Need help finding a !CAGS diagram
Old Jul 20, 2003 | 10:05 AM
bigsteve7's Avatar
There was a diagram I saw posted a while back which had a picture of what wires needed to be disconnected from the ECM in order to do the !CAGS mod for free. The diagram was just a picture of the ECM with text over it, and highlighted teh specific wires that were used.
Does anyone know where I can find this? I've been searching and cant seem to come across it.
Old Jul 20, 2003 | 10:08 AM
bigsteve7's Avatar
Nevermind, I just found it.
Incase anybody else is curious, heres the link.
http://www.bfranker.badz28.com/96SS/skipshift.htm
Old Jul 20, 2003 | 11:16 PM
Personally, I'd much rather just pull the harness plug off the solenoid than go poking around in the PCM connectors. Takes 5 minutes.
Old Jul 21, 2003 | 12:33 AM
RedPhenx's Avatar
also, doing it that way will cause you to fail emmisions if you have obd2 and you get tested by the scanner... just a thought
Old Jul 21, 2003 | 10:58 AM
bigsteve7's Avatar
Pull teh harness off of the solenoid? Could you please elaborate on how to do this? What solenoid located where?
Old Jul 21, 2003 | 11:20 AM
His signature says he has a 95.
The skip shift solenoid is located on the drivers side of the tranny, toward the middle. See picture below. Pull the harness connector off the solenoid. Tape the end of the harness connector, and the connector on the solenoid. Tie the wire up out of the way.
When you do this with OBD-I, you will get DTC 84 set in the PCM, but no SES light. On OBD-II, you get the code and the SES light.
The way to avoid the code is to buy a "skip shift eliminator" for $15-30..... or buy a 2.2Kohm 1/2watt resistor at Radio Shack, and puch the resistor wires into the harness connector before you tape it up. Having the code set doesn't hurt anything... I drove for 5 years with the connector unplugged.
Drivers side of T56
Old Jul 21, 2003 | 08:53 PM
bigsteve7's Avatar
thanks
Old Jul 22, 2003 | 07:42 AM
Brent94Z's Avatar
Super Moderator
Yeah, but you still have to go to the PCM harness to get rid of the upshift light so while you are there, might as well just yank another wire and be done with it
Old Jul 22, 2003 | 08:04 AM
My T56 has been gone for two years, and I still have the "skip shift" light coming on...... Sort of compliments the "AIRBAG" and "ABS INOP" lights..... gives the instrument cluster a more "balanced" look........... At least I cut the wire to the SES light.
Old Jul 22, 2003 | 09:26 AM
importeater's Avatar
Well I used the Radio Shack version and been on there a year, works great. Light still comes on but never notice it.
Old Jul 22, 2003 | 10:42 AM
HardcoreRM125's Avatar
So all i would have to do to eliminate CAGS is unplug it, tape it to the harness so it aint just hangin there , and go? I have a 95 so its OBD-I , So it would store a code but no light... But if i do that , will the skip shift light stick on or anything? Does it affect anything else ?
HarleyZ28
Oct 5, 2015 06:23 AM
surreybrad
Apr 22, 2015 06:40 AM
Lakebratt
Feb 5, 2015 07:55 PM
slocody
Feb 10, 2003 01:04 PM
turbo_Z
Aug 19, 2002 10:50 PM
