Alternator output only 14.1 volts
Old Jul 20, 2003 | 06:22 PM
$hawn's Avatar
checked the alternator with an multimeter with the car running and it was at 14.1, drove it around for about 30mins. turned the car off and the battery was charged at 12.6. I'v always understood it should charge at 14.4 volts, what should be the least it should be? Or is 14.4 the lowest it should be? Even though it seems to be charging low, the battery was at 12.6 and that seems good.
Old Jul 20, 2003 | 07:00 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
its fine
Old Jul 20, 2003 | 08:34 PM
Mine reads right at 13v most of the time. I just looked at one of my Datamaster logs and it showed 12.6v at 131 mph. I could say that was trap speed, but y'all would call and rightfully so.
14.1 is good.
Old Jul 20, 2003 | 10:21 PM
Terran2k's Avatar
yeah its fine, my alt. will also put out about 13v mostly, except for right after starting it up, then its more. but it'll be 13v after that.
Old Jul 20, 2003 | 10:31 PM
CamaroBoy96Z28's Avatar
Mine does the same. My old one used to put out 16v before it died last week with my March pulleys for the last 3 months. The new one hangs between 13-14v.
Old Jul 20, 2003 | 11:10 PM
Z95m6's Avatar
mine carries about 13 i wish i could be cranking out 14 from it.
68camaroboltz
Oct 5, 2015 01:46 PM
fift5
11
Oct 1, 2015 10:31 AM
drt
Sep 27, 2015 04:39 PM
tommalcolm
Sep 11, 2015 03:39 PM
jackpawt883
Sep 10, 2015 08:53 PM
