View Full Version : LT1 Based Engine Tech
- Unique Exhaust Question!
- MAF question
- 1SA AND 1AY Options
- Anyone know if a LS1 radiator piece and intake lid will fit under a T/A hood?
- 233/239 cam in 383 ... dyno next week
- What a weekend!
- Quick question.....Fog light out......replacement?
- rear end cover
- whats burning? oh yea its my car :( long!!!!!!
- Torque Arm For Convert?
- Poly motor mount install problem....
- emissions
- SLP TOTL vs. Hooker catback
- gas milage...........need some help
- Hotcam and stock timing chain?
- Speed density people...
- Is my 97 different??
- Hooker y-pipe for LT headers
- need help quick
- Hard Starting & Running rich
- New to modding..what to do?
- how do you know if your maf is working right??
- where to buy ls1 brake up grade
- bleeding system w/radiator cap off: open bleeder screws and radiator level overflows?
- lifter diameter
- Interesting info on MAF readings from different CAIs
- Firebird Headlight Stop
- Driveshaft question
- Lt1 to Lt4 conversion?
- How big of piping....
- Fenders...
- High Oil Pressure ?
- Drivetrain Forum
- Hooker Catback and Headers
- break light bulb help quick!
- what cars came with 3.08 rear gears stock?
- Valve Seal Or Piston Ring
- so aparently my car thinks its a corvette
- Gauges???? What should i order?
- 02 simms needed on long tube install???
- clutch help
- Preloading lifters with car running question
- whats needed to convert to a th350 or 400
- Need Help? Please read!!!!!1
- Steering Problem
- rims and tires
- 400rwhp N/A with...think I need a bigger cam
- I knicked part of the water pump trying to get the shaft out for a CSI install...
- stock programming from a 1995 a4 z28?
- Tranny problems on a 94...
- Put in a new stall and now the car doesn't want to move
- Long tube headers
- Ramps
- Did LCAs help your traction that much?
- valve lash
- valve spring suggestions
- Analyze My Track Slips
- just thought i'd share it with ya...
- Vette starter difference (LT1/LT4 vs L98)?
- Camshaft Question....
- Can someone tells me what their gas gauge does at startup?
- C5 corvette gauge cluster swap into 97+ camaro!! possible??
- What will it take to drop the motor?
- RTV or something better?
- Which is Faster A4 or M6
- how hard to change opti?
- Motor Partial Rebuild
- Popping Noise distant in exhaust?????
- HP drops off like a rock after 5700RPM's
- Where can i get a shorter stick for my Hurst shifter?
- How can i get my headers to stop leaking?
- Questions about tire fitment.
- Trans wont go into gear when cranked, but will when turned off... wtf?!
- whats weight diff. between 94 z28 6 spd and 96 ws6 formula 6 spd?
- thermo leaking
- swaybar removal
- Anyone know about the NOS/Holley TB?
- Stage 8 bolts and alternator bracket?
- Anyone whose running skinnies I need input.
- Part numbe anybody?
- Best cam for stock lt1
- Z06/ls6 Maf Faq!!!!
- Avergage gain?
- water lines in back of heads...... can I connect that to an expansion tank??
- 383 ?'s..
- Bad Vibration at 90mph+...PLEASE HELP!?!?!
- Knock Module!
- Stock 0-60mph numbers for our cars?
- B&M ripper hissing at me
- Need VATS help/ what are these wires for?
- Tach Question
- Low coolant light!!!???
- Do you have to replace the opti after you do a cam swap????
- How much is my catback hurting me?
- Opti removal instructions: ?
- N/A 12.05 @ 112 MPH tonight
- Dyno #'s!
- 4" stroker crank in lt1
- GMMG cat-back
- 3.73's installed
- any1 ever fix a bad gas mileage situation?
- Help
- Rocker Arms
- pissed off at my car - just about to sell it
- Evaporative Emission Canister
- I did it this time....
- spec stage three
- flowmaster exhaust!!???!?!??!?
- got her dynoed
- AFR Heads and Intake problems
- Camshaft alternatives?
- A4 Shifting Problems
- Hotcam users with M6 please
- What oil for my 6 speed?
- help w/ no start problem
- Sucking oil through intake manifold gasket??!!
- Tire was mounted wrong questions
- Header bolts?
- Fuel pump before mods or after?
- Crank Balancer Removal??
- Who got LT4 Extreme Duty Chain???
- another "car wont start" question...
- Best Exhaust to go with my car
- Low Oil Level Sensor
- Engine Code 11
- TB problems, WTH is going on?
- Vibration problems with LT's
- bmr track pack
- radio...
- Idea for cooling intake tract
- Massive wheel hop!!! HELP!
- How hard is the crank hub supposed to be on there???
- Exhaust
- Fuel Filter
- Full cage in a t-top car
- Anyone have a writeup?
- Too much carbon out of pipes...fix?
- Broken sensor
- LT's and stock wires...
- correct backspacing?
- exhaust ?
- missing intake bolt
- cooling problems
- cam confused
- 6 spd burnout on nitto's
- HELP: Drivers-side rear-most manifold bolt was snapped off!! What to do?
- guide plate ?
- power window alignment
- Something new...air fuel controllers, can they be adapted for LT1's?
- #1 cylinder not firing! Why?
- Ramchargers Fuel Pump
- So this GM CAI doesn't wanna go home.
- what do i expect form the dyno tommorow?
- Rockers
- walbro 255 ?
- gains with lt4 hotcam kit and 2400 stall?
- cant loosen coil nuts
- I hate plug wires
- where to buy Hooker Lt's
- How to syphon gas??
- Jason says:::
- gears
- opti ??
- Finished Opti/Water Pump Install, my advice...
- Head gasket problem....
- OptiSpark Life
- Need Quick Response, Easy Question
- Cat question
- How much 50/50 is needed?
- how good does the lt1 intake manifold perform compared to other manifolds?
- fog light replacement
- Anyone had an electric waterpump go bad?
- need a real pic of Hurst Billet/Plus Shifter
- T-Tops
- coil replacement question
- 245/35/17 or 245/40/17? whats the differences
- MAF plugged in: BLM's at 116'ish, MAF unplugged: BLM's 128'ish
- tick tick tick tick tick tick tick then starts, what gives?
- Am I just stupid?
- Fuel Smell
- who is good at looking at datamaster or freescan data logs?
- Car wont crank...possible alarm issue?
- Need a good laugh?
- passenger seat bump
- Where can I order o2 simms from and use Paypal???
- AC Compressor
- 396, cc306, GTP Stage 2, 434 rwhp!!
- Heads/cam self install, can it be done...
- Oil pump drive play....
- alarm problem
- Opti spark...
- what precautions to take before road trip?
- SPEC Stage 3 Ceramic people inside!
- I want to remove ALL of the EGR stuff, please help.
- Stock clutch
- 80 series flowmaster
- Cutout with stainless exhaust or Hooker coated Y?
- New hotcam times inside
- Stock Cat.
- Pullys
- Almost at 92k what to look out for?
- window motor problem
- Failed smog, need help plz
- Need pic of cruise control module location
- Help me
- How to determine flywheel hp from rwhp
- 93 M6 guys..what gear?
- quietest muffler
- What will headers, full exhaust, cai, and a cc305 cam give me?
- inable to burn out
- all you 97 lt1 guys, i need help!
- PLEASE HELP big problem with car
- LT4 heads vs LS1 heads
- What is all needed install 1.7 rockers?
- sea foam on an lt1
- shift kit?
- Melling High Volume oil pump....
- two tranny cooler??
- closest dyno?
- T/A rear bumper ona Z?
- Fog light removal
- Layover Z28 decals
- car is acting strange!turn on headlights and the taillights dim\blinkers dont blink
- should i get zo6 maf?
- High Flow Cats good idea or just bs?
- 345/35/18's on a F-body
- Why arent my O2 sims working?
- Were to buy a Pressurized oil canister??
- Long tubes or what??
- Felpro Oil Pan Gasket????
- Just put in my 410s
- Nice jump with cutout!
- Is This the EGR?
- OMG.....Jet Hot LT's + no cat = pure brilliance
- how does the hotcam perform with stock exhaust manifolds?
- What's the story on 15w50 oil?
- Is there really a difference??
- car sits for a while = white smoke coming out exhaust
- Stupid Question
- No Spark!?!?!
- 96 z28 6-speed .. cable clutch or hydraulic ?
- Help with exhaust questions
- O2 sims different for different years?
- 10's with HOT CAM? Is it possible
- Cruise control box the same on all LT1's?
- Wiring A/F Gauge
- more then one p/n for ac delete idler bracket
- Shoebox or anyone that can help. need to remove radiator.
- Moroso intake owners...inside
- Will this valve spring be good enough for this cam...
