View Full Version : LT1 Based Engine Tech
- Carbed LT1
- Can anyone tell if this bottom end is forged?
- Car feel on me!!!!!
- Ping at idle (or maybe it's not a ping)
- 355 or 383??????
- Trick flow TB
- Best headers
- This is a problem isint it????
- Tearing down the LT1...Heres some pics. And a question.
- No Oil On Top End - New Motor Problems
- Planning on firing it up soon.
- missfiring problems????
- New Holley Stealth Ram Design LT1 Intake
- true duals
- Comp Cams 304 / 503
- BIGGER Throttle Body????
- Cam selection
- Is this 383 kit any good?
- Dead battery?
- 95z no start and no dash light and head light
- motor mount replacement
- Are 42lb injectors too much for my motor?
- oil pressure help
- speedometer & tach guage needle flickering...
- car chugs under 50% throttle
- need help diagnosing
- Cam Degree
- Throttle Stuck open
- car won't start need help!!
- EGR Block off
- Head Gasket direction
- Block fill and 396
- valve adjustment
- SES light, please help!
- LT1 Keyed hub
- Alternator Not Charging at idle in gear
- Problems after cam install!!!
- 3:73 Or 3:90 Or 4:10
- first oil change question
- Oil Cooler leaking????
- need help ASAP
- block is DONE!!
- high idol after start up. 385 lt1 cont...
- new opti needed couple ?s
- Low coolant sensor malfunction?
- Oil coming out of Exhaust #8 PICS
- Throttle body bypass
- Lt4 Knock Module
- Bad fuel pump?
- New Engine problems
- Rear Main Oil leak symptoms?
- What's the deal with 10A fuse #11?
- Overheating Problem
- Throttle body porting
- Piston Rings
- Main Studs...which do I need
- Starter free spinning?
- Dyno Numbers
- SS blowing gaskets
- 95 coil pigtail part numbers please
- oh joy...opti?
- Inside an Opti's optical sensor.
- what can i do to minimize spark resistance?
- 383 guys step in for a moment
- fuel line recall?
- Eratic idle and no start
- knocking at mid rpms
- LT4 valve cover discontinued?
- 94 Z slow to respond....wheezing at times
- Can 96 z28 car retard with no check engine light?
- Racetronix, Lucas, Delphi..Are these all made by the same company?
- Can a Fuel Pressure line be spliced?
- rebuild
- wheres the crankshaft pos sensor?
- carb lt1 help! please look
- major oil leak problems
- ShBox Website TDC
- Adjustable Fuel Pressure Regulator For 94Z
- Comp 918s
- injectors
- My baby won't start
- coolant boils over everytime i park
- Help changing passenger side o2
- How weak are the flywheels?
- Starts when it wants!
- engine harness question
- LT1 running warmer - electric pump
- Dyno Tune
- What sealant to put Opti back together.
- lt1 water pump gear shaft???
- Need engine building advice--383 solid roller connecting rod clearance
- Whatever to do with ~$1000
- How bad did I just mess up? theft module?
- Summit Valve Spring Height Micrometer
- Which valve spring kit
- My cammed LT1 vs 2001 LS1.......
- Need LT1 stroker HELP!!!
- Trouble with driver's side motor mount
- Leak fro Above Oil Filter
- Anyone have the Ebay Hot Cam?
- Oil Level?.. 5Qts Shows Way Overfull??
- 93 z28 wont start...PLEASE HELP!!
- Rebuild
- Exhaust popping...
- anybody know a good honest mechanic in/near Baltimore?
- F body Central in Baltimore anybody familiar with
- Le ??
- Please help with engine diaganosis!!
- Is this worse than i think it is?
- Cam install question - Do I need oil?
- idle problems
- 1997 Z28 only runs for 20 seconds
- CAM Removal LT1
- 93 LT1 Oil Pressure Question
- 95 pcm harness wiring gauge
- Lifters.
- opti
- DTC 61 AC issue
- EGR Block off plates sealant
- power loss sensor problem
- What headers
- Heads and Intake for 383
- bottom end and internals, durability for 600HP
- LT1 missfire.
- LT1 smooth bellow??
- First Startup Video..
- Charging Issue..this sound like a Alternator?
- Going to Seafoam, but car in Fixed Loop...
- Banjo Belt
- Parts sheet
- New plugs and wires
- play in opti shaft
- lt1 power problems
- egr question
- Setting Roller Rocker Lash....more simple than I've read????
- Port which itake?
- Motor Oil question!!
- How much HP with these mods
- Wierd blown headgasket incident
- New Heads big problems help!!!
- Fuel Problems !! HELP!!
- Running a bit hot
- Engine Fuse for the Mass air flow?
- Drivers side fan doesn't come on
- Need help with codes, car running bad!!!
- GM847 install and first start!
- Stock valve covers, 1.6 ratio rockers, and baffling....
- can a 94 Camaro starter be used on a 94 corvette?
- I proudly present... AI 226/234 video
- Sticking Valve|'91 Z28| LT-1
- lt4 or 383 stoker
- screw size?
- can you shim the springs for more lift
- 1995 camaro z28 - rough idle
- Lt1 knocking/ticking
- LT1 turns over, but doesn't sound like it's cranking
- Mechanics are such babies
- LT1 steam pipe replacement kit
- Starter Question!
- LT1 Intake Powder Coated
- Polishing Crankshaft
- P0148
- Hydraulic lifter to solid lifter (valve train setup purposes)......
- opinions
- DYNO tune?
- speedo and tach malfunctioning
- engine swap
- Okay guys I was hoping to hear a little more interest then what I've seen so I need t
- heeeeeeeeeelllllllllllllppppp dumping fuel!!!
- TCS delete
- engine knocking!
- Plug wires mounted on valve covers
- New heads and such.Car missing and hesitating under load.
- New old problem
- Making My Regular Centerbolt Chrome Rocker Covers Work (Notch For Alt)
- What size are the threads for the tb bolts?
- LT1 shortblock questions
- new heads.misses after warmed up
- good combo??
- spark entering, but not exitting the opti...
- Installing Cam Package - Timing chain & valve question
- Oh boy milky oil
- Want to rebuild, no budget, have some guildlines though
- pcm tune
- valve question...
- Is blue RTV ok for intake?
- programmers
- Help...LT1 Oil in Antifreeze?
- lt1 bolt ons and offs
- From Your Experience (basic mods)?
- back fire problems help!
- Question about removing cat
- What does this hose go to?
- cam questions
- Chipped valve edges???? Picture....
- Done With Engine Build - Leftover Gaskets.. AHH (Pic)
- 94 Z28
- How to find true TDC
- 94-95 Mac Headers
- 4th gen newbie.. need advice
- What parts are LT1 specific?! ---
- gm main cap bolts part number
- could it do any damage?
- so.... I think my lt1 just.... (kinda long)
- hellp...just finished cam install...
- Does anyone have an idea what these wirings undermy hood are for?
- Code 36?
- 383 dyno numbers.more power?
- Installing Cam Package.. Questions
- yet another cam question
- Anyone running portmasters stage 2 head?
- Some updates on my car
- Runs fine then dies
- Uhm.....weird thing happened while driving
- Valve Spring Height??? Oh no....help needed....
- how important is matching piston to rings Brand names
- Please help identify unknown noise! Vid incuded
- which sparkplug boots have the aluminum heat shields?
- 383 piston options oem heads
- Where do these vaccums go
- Low Iol Sensor
- oil pump priming, a different way?
- Help confirming bad opti diagnosis
- ltcc install ?
- Help with 400+ rwhp Budget rebuild
- I can't find the problem!!!!!
- sputtering after key is off
- not sure...spark plug?
- Fans Wont Kick In need help fast
- Help with pushrod lengths
- SLP Dual Cat Headers
- It runs
- How to get to the 10's
- indexing opti?
- Evap to TB hose
- new lifters?
- Leaking exhaust valve?
- Solid core plug wires
- Right Head Sensor or Plug?
- pressure in cooling system
- Why is this thing going dead?
- what can I do to bring the volts up 12.3 I need 13.5
- Does a burned plug wire also kill an Opti?
- LT1 no spark
- is this my opti crappin out?
- My First Test Drive (are these known issues?)
- Quick ?
- stud girdle
- 1.6 pro form full roller rocker ?
- O2
