how to reset PCM? dark soon help!
Old Apr 12, 2004 | 06:08 PM
Supermanx500's Avatar
How do I reset my PCM? Where is the Fuse?
What should my PSi be at with my mods?
Will this reset stuff pcmforless did or the dyno tune I got?
Old Apr 12, 2004 | 06:15 PM
1msfyter's Avatar
Unhook the negative on the battery and wait 10 minutes. The PCM will re set and clear.
Old Apr 12, 2004 | 06:19 PM
Will this mess with Pcmforless or dyno tunne?
Old Apr 12, 2004 | 06:31 PM
On a 1995, find the PCM BAT fuse in the underhood fuse/relay panel. Pull it for at least 30 seconds and you should be good to go. Removing power from the computer will not erase any programming.
Old Apr 13, 2004 | 06:38 AM
Eliminator's Avatar
I pull the fuse quicker then doing the battery.
Old Apr 13, 2004 | 06:54 AM
carlos64030's Avatar
WOW, 95's are way different than the 97's, on my car that fuse is in the fuse panel on the side of my dash.
Old Apr 13, 2004 | 09:01 AM
That's right. Actually, 1995 is the only year that fuse is under the hood.
Nayr
Mar 3, 2023 08:34 PM
football4life
Oct 4, 2015 07:48 AM
fift5
11
Oct 1, 2015 10:31 AM
drt
Sep 27, 2015 04:39 PM
damnyankee36
Sep 9, 2015 07:06 PM
