Got a problem with car, need help!
Old Apr 12, 2004 | 05:14 PM
Supermanx500's Avatar
Unhappy Got a problem with car, need help!
If I have a broken Map sensor and replace it but not clear the code, Is it still broken as if the map sensor wan't replaced?
I had a broken map sensor but I replaced it. I did not get the computer reset for the code that it was throwing because it couldn't move because of a broken tranny.
I have a fuel pressure regulator that is set at 42 psi. When I went to the dyno the map sensor was bad and so we set it at 32psi (was the best pressure setting so I didn't run lean.) Should I set it back at 32psi or should I leave.
Old Apr 12, 2004 | 05:25 PM
Anyone?
Old Apr 12, 2004 | 05:40 PM
Pullngz's Avatar
Just unplug the pcm fuse for a few minutes, it will clear the code.
Old Apr 12, 2004 | 05:45 PM
Will this clear things that Pcmforless or dyno tune did??
Where is the fuse for pcm?
What should I set the Psi At when I reset it?
thanks
Old Apr 12, 2004 | 06:00 PM
Need answer before it gets dark in a few mins.
liamcg97
Nov 25, 2019 05:55 PM
Noenav
Mar 1, 2019 07:38 AM
Britbilly
Jan 7, 2015 08:49 PM
97SSdude
Dec 31, 2014 07:43 PM
USAirman93
Nov 24, 2014 03:37 PM
