Valve seal replacement
Old Apr 11, 2004 | 12:20 PM
Derek M's Avatar
...background... 95 LT1
How difficult should new it be to push a new valve seal over the top of the guide? Never doing this before I wanna ask before I **** something up.
Removed the old seal, and measured the ID .550, the ID of the brand new seal is .530. Wonder if the difference is in old versus new condition? Is this normal as expected?
Trying to get the new seal over the top of the guide I've used hand pressure, then progressed to using a deep socket over the seal. Using what I consider a pretty firm hits on the seal it still doesn't go.
As usual thanks for the assistance.
Old Apr 11, 2004 | 12:32 PM
OBE1 95Z28's Avatar
I've always used the GM seals and there is a difference size for the intake vs the exhaust valve. I put a little oil on the seal, slide it down in place and tap it home with a deep socket.
Old Apr 11, 2004 | 12:46 PM
krazwag's Avatar
I'am not positive on this but I'am pretty sure there is a .550 seal and a .530 seal. I think you have to turn the valve guide down to use the .530. Hopefully somebody that knows for sure will reply for you.
Old Apr 11, 2004 | 02:43 PM
Derek M's Avatar
Thanks for the info guys. I think I've been able to prove that I have the wrong seals.
It appears I have Compcams PN# 503-16
Doing some more measurements here's the low down.
Valve Stem = .343 = 11/32
Valve Guide OD = .550
Current setup (black rubber color)
Valve seal ID = .553
valve seal OD = .675
Valve seal I'm trying to put on (light blue color)
Valve seal ID = .530
Valve seal OD = .675
It appears I have Comp PN# 503-16, when I actually need 501-16 or 502-16
Thanks again for the help.
HectorM52
Jul 30, 2017 11:46 AM
Roadie
Feb 16, 2015 10:34 AM
Jazsun
Dec 29, 2014 12:14 PM
dansam
Jul 20, 2002 01:10 PM
