zz4 crank with 6 inch rod
Old Apr 11, 2004 | 10:41 PM
atljar's Avatar
Will it work? I know some cranks say must use "xx" rod, and others dont. Just need to know if it will alow the use of the longer rod.
Old Apr 11, 2004 | 10:47 PM
my94blackz's Avatar
Whats so good about a zz4 crank vs aftermarket? Is it better or you just got one laying round?
Old Apr 11, 2004 | 10:53 PM
atljar's Avatar
forged steel and you can grab them for ~200 bucks
Old Apr 11, 2004 | 11:07 PM
my94blackz's Avatar
How much does it weigh? If its less than 50 like my eagle im gonna run and cry, i spent 600 bux on it.
Old Apr 12, 2004 | 07:25 AM
atljar's Avatar
Not sure on weight, im sure its nothing special on the light end of things though.
TTT, auction ends shortly, need an answer.
Old Apr 12, 2004 | 07:48 AM
Camaro_Maniac63's Avatar
Not 100% sure but I think you need to use 5.7" rods with the ZZ4 crank.
Old Apr 12, 2004 | 11:28 AM
disco192's Avatar
The thing you gotta remember when setting up a rotating assembly is you gotta do the math. Im not sure what the stroke on the crank is.
In order to calculate how long a rod you can run you take the deck height of 9.025 (The height from the center of the crank to where the heads rest) minus half the stroke and minus the compression height of the pistons. That will give you an exact figure on what kinda rods you can run.
9.025-3.48/2-1.25=6.035 (so 6" should work with 1.25 CH pistons)
To calculate compression, it just takes a little more math.
TitoPR221
May 26, 2015 12:20 AM
pimpss96
Feb 12, 2015 01:28 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
Bill'sWS6
Aug 5, 2002 01:00 PM
