timing chain or fuel pump?
Old Apr 9, 2004 | 09:35 PM
93zguy's Avatar
ok guys do you think this is the timing chain or fuel pump and how hard is either of the two to change. sometimes my car starts right up and some times it turns over ten or twelve times before it starts then this week it started to sputter when i tried to accerate i think it even backfired once let me know what you guys think
Old Apr 9, 2004 | 09:45 PM
97WS6SCharged's Avatar
I'd say fuel pump would be the place to start looking. You may also try changing the filter and checking the pressure regulator.
Old Apr 9, 2004 | 10:29 PM
The timing chain is not goint to cause intermittent problems. If you suspect the fuel system, check your pressure with a test gauge.
Old Apr 9, 2004 | 11:57 PM
texasTA's Avatar
Yep, check the fuel pressure witha guage. More than likely your check ball is going. This is what keeps the fuel pressure up through the system. Once this starts to go, the fuel pressure will start to decrease ever so slightly.
Old Apr 10, 2004 | 01:46 PM
93zguy's Avatar
if it is the fuel pressure what should the correct pressure be any help would be great
thanks guys
Old Apr 10, 2004 | 01:48 PM
RamAir95TA's Avatar
With the key on, engine off, pressure should be around 43psi and hold constant. With the engine idling, pressure should drop 3 to 10psi, and increase slightly with throttle pressure. Anything different than those conditions and you have a fuel system problem.
Gtpguy
Jan 26, 2015 04:50 PM
ANDYZ28
Dec 29, 2014 09:13 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
