Tps
Old Apr 12, 2004 | 12:06 PM
SnakeSkinner28's Avatar
Tps
Can anyone give me some symptoms i might get if the throttle posistion sensor is going bad. Im having some a consistant problem with my car only it wont hold the code, was wondering if anyone could perhaps confirm what im thinking. Thanks.
Old Apr 12, 2004 | 01:51 PM
95z6spd's Avatar
I would think it would give u an idling problem. You can check your voltage coming out of your tb with a voltmeter. It should be close to 5 volts at wot and around .55-.60 volts at idle. This is all with the engine off, just the key in the igntion one click before it starts.
truecontr3
Oct 11, 2015 09:30 AM
drt
Sep 27, 2015 04:39 PM
tdigger9899
Sep 7, 2015 10:56 AM
4586
Aug 18, 2015 07:08 AM
