How do these head flow numbers look?
Old Apr 9, 2004 | 11:31 PM
texasTA's Avatar
These are stock LT1 camaro castings that have only been slightly ported and cleaned.
LIFT Int. Exh.
.100 62 51
.200 130 109
.300 182 156
.400 230 181
.500 255 187
.550 265 193
Does that seem like pretty good flow numbers? I am contemplating on buying this from a local friend of mine? what can be expected if I was to have a valve job done on these heads
Old Apr 9, 2004 | 11:35 PM
chesee48's Avatar
I think they are good!
How much was he selling them to u for? What is the .600? Just to see if the numbers are still increasing or decreasing...
Old Apr 9, 2004 | 11:39 PM
texasTA's Avatar
I will have to find out what the .600 numbers are. But I am almost positive they were still increasing. But for the time being I am going to be using a LT4 hotcam for at least another 6 month or so.
Oh and he is selling them to me for 200. He owed me from some parts I had given him.
Old Apr 9, 2004 | 11:41 PM
chesee48's Avatar
Very sweet! Stock heads go for 200-250!!!
You got a steal my friend!
Old Apr 9, 2004 | 11:44 PM
texasTA's Avatar
That's what I thought.
Do you think a valve job on them would help out any?
Old Apr 9, 2004 | 11:48 PM
97WS6SCharged's Avatar
Have them tested. If they leak any fluid then a valve job/springs would be a good thing. If not, then run them and save a few bucks.
Old Apr 9, 2004 | 11:49 PM
texasTA's Avatar
So the valve job is not going to net hardly any power. If so, then I will just bolt these puppies right on.
Should these heads work good with an LT4 hotcam kit?
Old Apr 10, 2004 | 12:01 AM
Those mid flow numbers are awesome, they should work great with a hot cam. I would still have everything checked, if the springs are weak or the valves are leaking then the car will feel like it's towing a boat behind it.
Old Apr 10, 2004 | 12:03 AM
juiced_lt1's Avatar
the hotcam has .525/.525 lift, so with 1.6rr's, you'll be making .560/560 lift. If the heads are still flowing well at .600 lift, then yes, you will make some REAL good numbers for sure.
Old Apr 10, 2004 | 12:04 AM
texasTA's Avatar
Cool man, thanks. Do you have any idea how much a shop will charge to flow a set of heads? I know different shops have different prices, but maybe a round about price.
Spinner's Avatar
The hotcam makes .525/.525 WITH 1.6 rrs
Old Apr 10, 2004 | 12:05 AM
texasTA's Avatar
Thats the impression I was under? Maybe I was wrong?
Old Apr 10, 2004 | 12:17 AM
Spinner's Avatar
You were right. Juiced_Lt1 is mistaken
Old Apr 10, 2004 | 01:02 AM
That would be the hotter cam. GM PN 8675309
Just kidding.
You only really need one chamber flowed. Usually it's like $25 per chamber so you only want one chamber flowed, unless you've got alot of spare $$ laying around. And in that case, send it to me instead and I'll send you any flow numbers you want.
Old Apr 10, 2004 | 09:43 AM
texasTA's Avatar
Not a TTT, just want to get the day people's input.
