Why does my ABS light come on when I get on the gas?
Old Apr 9, 2004 | 08:14 PM
'93 formy ...'s Avatar
Just like the title says, why is it whenever I hit WOT, even if it's only for a second or two, my ABS light comes on and stays on untill I shut off the car? When I start up the car again, the light is out. I'm not getting any "service engine soon" lights and it happens whether I'm on the highway or going from a standstill. WTF
Please reply if you can suggest anything.
Old Apr 9, 2004 | 08:21 PM
FireHawk409's Avatar
Well if you just did your spark plug wires you might have them to close to the sensor. That happened to me my first time i did plugs and wires. It also could be your sensor is going bad,loose wire or something. Have you looked at yet?
Old Apr 9, 2004 | 08:31 PM
By "sensor" I'm assuming your talking about the ABS sensor correct? Yeah I did look at that and evething seems to be the way it should be. I haven't touched the plug wires recently so I don't think that would be the reason. Could this possibly be costing me power? My car is really loud (especially now that I switched over to LT's over my shorties) The car shakes a lot. Could all the vibration from the noise be interfearing with some senor somewhere on the car? I really have no idea. I need help fast. I'm scared that I could be damaging something on my car whenever I floor it.
Old Apr 9, 2004 | 08:51 PM
I dont think the vibration would cause it to go off. If you can get ahold of a scanner it might tell you if the abs sensor is bad or not. If i recall right the abs sensor is on the wheel hub and its not hard to change at all. Dont think it was very expensive either. I cant think of anything else besides one of them being bad. Hopefully someone else can help ya.
Old Apr 10, 2004 | 12:58 AM
Fatdog's Avatar
Cool
Check your third brake light ,for proper bulbs,and replace all the fuses(panel on left side of dash,even if they look good to you).Hope this helps.(brake fuses)
jj_burchiel
Mar 21, 2015 12:51 AM
dluna333
15
Mar 13, 2015 12:30 PM
squarehead
Jan 15, 2015 07:02 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
simple
Aug 11, 2002 11:56 AM
