Bad alternator?
Old Apr 10, 2004 | 09:46 PM
neil350's Avatar
Bad alternator?
Replaced the batery with an optima, car was running fine how ever the voltage wasnt that great with a whole bunch of stuff on. Today we had a real bad storm and I noticed the needle was dipping in the yellow, enough to the point were I knew it wouldnt restart, sure enough, turn the car off and then try to turn it back on and no dice. My guess is the alternator is shot?
The opti is fine
Old Apr 10, 2004 | 10:02 PM
ram air camaro's Avatar
check all your ground connection and battery terminals that they are all tight, if they are sure sounds like your alternator took a dump which most likely drained your battery which is a very good idea of replacing it again with the new alternator. good luck
eanhl2004
Apr 4, 2015 12:01 PM
Red97LT1
Mar 1, 2015 05:08 PM
dale3in98
Feb 14, 2015 12:18 PM
Gtpguy
Jan 26, 2015 04:50 PM
HectorM52
Jan 16, 2015 10:21 AM
