oil leaking from bottom of slave cylinder
Old Apr 12, 2004 | 06:33 PM
Jesse_Boyer's Avatar
I din't have a flash light, so i can't tell exactly where it's coming from. However, I can tell you that it's a drip every few minutes. I had a leak from the valve cover, but that's not leaking anymore. I don't think the intake is leaking as I can't wipe any oil off of there.
Anyone have any other ideas?
This is the last leak i've got to fix and then i'm going to the dyno.
Jesse
Old Apr 13, 2004 | 11:41 AM
no ideas?
Old Apr 13, 2004 | 11:47 AM
ZDriver96's Avatar
master/slave is leaking (brake/clutch fluid). Mine was leaking, dripping inside of the bellhousing and drip out onto the ground.
Check how full your slave and or master cylinder is. It is sealed unit so you'll have to replace both
Old Apr 13, 2004 | 11:59 AM
It's brand new billet master from McLeod and I used the stock slave cylinder. Can I simply buy a new slave and use that with my McLeod?
Jesse
Old Apr 13, 2004 | 12:17 PM
My Red 93Z-28's Avatar
my clutch hose busted and you have to buy a whole new master, slave, reservoir, and hose from gm for about $170 I think
Old Apr 13, 2004 | 12:22 PM
can't, i'm using a McLeod Master Cylinder! There has to be some way to use the MMC and a GM slave, right?
Old Apr 13, 2004 | 12:41 PM
you can try a junkyard.
Old Apr 13, 2004 | 01:17 PM
always a possibility.
The question is, is it the master/slave assembly that is really leaking? Could anything else be leaking...?
Old Apr 13, 2004 | 01:54 PM
have you checked the hose that runs from the master to the slave, mine wore out from rubbing up against the firewall all these years, causing fluid to leak, or maybe it isn't connected right.
Old Apr 13, 2004 | 02:40 PM
negitive. I'll have a look at that tonight.
I'll check the fluid level of the master tonight and see if it's actually low. If it's not, no use heading down this road.
Old Apr 13, 2004 | 03:15 PM
meengreen 94z's Avatar
Its possibly your intake manifold. When mine was leaking I would have oil dripping all over that area, coming down from the sides of the tranmission. I even had some inside the clutchfork cover. Just reach behind your intake on the transmission and feel for oil.
HectorM52
Jul 30, 2017 11:46 AM
Magenta_Hearts
Mar 29, 2017 08:54 PM
Briah.hood
Feb 17, 2015 02:10 PM
artic94
Jan 17, 2015 11:19 AM
