Back after a long time
Old Apr 9, 2004 | 07:43 PM
RyanMacZ28's Avatar
Well, the Z28 took the winter off, and finally came back this last week.
Before I had a 94 Cavalier
Pros
1) Power
2) Looks
Cons
1) Drinks gas, getting 13 miles to the gallon
The question I have is could old spark plugs and wires be causing this? I put in a K&N filter, but the rest is stock. Could a fuel filter be helpful as well? And does anyone have any information on changing the fuel filter.
Old Apr 9, 2004 | 07:54 PM
25thBird's Avatar
Your fuel filter will definately improve your milage, especially if it has not been changed in a long time. It's really simple to change. You just pull out the lines at both ends, on both ends you need to hold them with a wrench. Have a catch pan under it because there will be some fuel being drained for a bit. You can also find some detailed instructions and guides if you search around, but like i said it's not hard. Your spark plugs can also affect your gas mileage. They're a pain in the *** to change though. Hope this helps.
rideordie
Nov 5, 2019 04:52 PM
AdsoYo
May 2, 2018 03:21 AM
cmdeshon
Dec 12, 2014 10:51 PM
Snoman73
Nov 17, 2014 07:22 PM
