Fuel rail shrader valve leaking
Old Apr 9, 2004 | 05:17 PM
supermo26's Avatar
Unhappy Fuel rail shrader valve leaking
I found something wrong when I was working on the car today. I had fuel dripping down the head onto the floor. After looking around for a few min I found the fuel pressure test port (schrader valve) leaking fuel. I tried to tighten it up but had no luck. I am looking for a few new Ideas for my fuel rail now. I would like to have a different pressure reg with dual feed lines and a guage that will read the fuel pressure all the time.
If you see anything cool let me know.
Old Apr 9, 2004 | 11:55 PM
I feed fuel into the back end of each rail, with a -6AN connection welded on each one, and take the return off another -6AN fitting welded to the cross-over tube at the front of the rails. The return line runs to a Weldon AFPR under the cowl. I have a 1/8" NPT fitting welded on the passenger side rail for the fuel pressure sensor.
Dual connections at back of rails, and AFPR under cowl
Return connection on cross-over pipe
Pressure sensor on rail
HectorM52
Jul 30, 2017 11:46 AM
4586
Feb 13, 2015 09:16 AM
LT14LIFE
Feb 9, 2015 09:35 PM
Jul 4, 2005 05:00 PM
