question bout gasket change
Old Apr 11, 2004 | 01:50 PM
lt1g3n's Avatar
do i have to have the timing cover and etc off to change the oil pan seal ? I want to do it without having to take off all that stuff , can i ? just drop the pan and redo it from there? the pan is empty, never had oil in it. harder, ok ? thanks
Old Apr 11, 2004 | 01:55 PM
OBE1 95Z28's Avatar
The LT1 oil pan drops straight down and you do not need to remove the timing chain cover. I'm not sure about your clearance between the oil pan and the cross member. You may need to raise the motor or drop the cross member to gain clearance.
Old Apr 11, 2004 | 01:57 PM
lt1g3n's Avatar
****. i really do not feel like doing that :/, ill have to check the clearance..
Sergio
Jan 27, 2016 04:27 PM
PCLZ28
Dec 24, 2015 05:19 PM
InfernalVortex
Jan 17, 2015 09:35 AM
Queens94z28
Dec 20, 2014 09:11 PM
startingstock
Exhaust System
Dec 12, 2014 06:40 PM
