Need help with Accel injectors
Old Apr 12, 2004 | 08:24 PM
RealQuick's Avatar
I bought 48lb/hr Accels used. I am installing now but when I go to put the retaining clip on, I noticed something wierd. There are 2 grooves on the Accel injector. One groove goes all the way around, so the clip will fit. However, if you compare the injectors side by side and line the heights up, it looks like the clip should go in the 2nd slot (higher up), but it is not a full slot. This is preventing the clip from going in. Should I just not use the clip and rely on the fuel rail bolts to hold the injectors in place?
Old Apr 12, 2004 | 08:51 PM
will62085's Avatar
my bosch's did the same thing, once the injectors are in, you dont need the clips...so i put the clip on so it would fit with the injector sideways, and once they were in i turned them 90* so they were sitting right, the clips popped off, but then the injectors were aligned height wise...if you dont use them to align the hieght, they will leak
Old Apr 13, 2004 | 06:17 AM
RealQuick's Avatar
Wont the bolts holding the fuel rail down set the height?
Old Apr 13, 2004 | 05:39 PM
will62085's Avatar
mine didnt, it pushed the injectors too far into the manifold and not far enough into the fuel rail, so it would leak out of the fuel rail
G-BODYT56
Jan 14, 2022 11:14 PM
93 RedBird
Nov 15, 2015 08:24 AM
autoxr166
Sep 25, 2015 04:21 PM
95blkss
Sep 22, 2015 03:18 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
