What does it mean to float a valve?
Old Apr 11, 2004 | 12:20 PM
My 97 Z28's Avatar
My dad told me not to rev my engine because I will float a valve. What is this he is telling me?
Old Apr 11, 2004 | 12:25 PM
Black6SpdTA's Avatar
Floating a Valve--Usually occurs at higher RPM's when the spring doesn't have enough pressure to bring the valve back up (to let the motor fire). So before the valve ever fully closes, it's being opened again by the rotation of the cam. I'm fairly sure that's the jist of it anyway.
Old Apr 11, 2004 | 12:30 PM
Eff's Avatar
Eff
Yes, and usually this is considered to be a very bad thing. Since floating valves, often hit pistons.
Old Apr 11, 2004 | 12:41 PM
OBE1 95Z28's Avatar
The valve doesn't seal hense you can't build combustion and your car looses power.
Old Apr 11, 2004 | 12:46 PM
MY91Y84's Avatar
You both are right as it happens at higher RPM, not enough spring pressure and is bad for your engine..
Float is actually when the valve bounces off the seat when its closing...
Not enough Seat Pressure causes float...
Old Apr 11, 2004 | 01:26 PM
97SS0594's Avatar
and this is why god made revlimiters!!
Old Apr 11, 2004 | 01:38 PM
Or higher pressure/triple rate springs
BTW: The LT1 doesn't come factory with a limiter does it?
Old Apr 11, 2004 | 01:48 PM
ibanez6rg's Avatar
That's why man created rev-kits.
Old Apr 11, 2004 | 02:32 PM
CamaroBoy96Z28's Avatar
6200 RPM is the factory rev limiter.
Old Apr 11, 2004 | 02:39 PM
kgkern01's Avatar
Nope, 5750 RPM is the factory rev-limiter on an LT1. At least on the M6. 6100 is LS1 I believe.
Old Apr 11, 2004 | 04:36 PM
My 97 Z28's Avatar
So how high can I safely rev my engine?
Old Apr 11, 2004 | 05:09 PM
MY91Y84's Avatar
the LS1 limiter is 6250...
if you still have the stock cam theres no reason to rev past the limiter, providing you disable it, because peak power is made at 5,200 rpm. Spin it right to the limiter and be content with that...revving higher with a stock cam will only slow you down..
LT1 makes peak@5,200
LT4 makes peak@5,800
i have my limiter set at 6 grand on my stock cammed carbed LT4...
As far as how high it can be spun, there are guy that turn them 6,800, but no *****in way id spin a stock rotating assembly that high and hard
Old Apr 11, 2004 | 05:20 PM
scoobysnax83's Avatar
I think there is a misconception with how high the stock rev limiter is set to on an LT1. Unless the previous owner changed mine (Highly doubtful for an old lady) mine is for sure at 6200....or more
Old Apr 11, 2004 | 07:45 PM
kgkern01's Avatar
MY91Y84 is correct on the LS1 limiter is at 6250. The LT1's stock limiter is at 5750.
I even verified this info when I got my Harlan shift light, 5800 hit the limiter before the light, 5700 would hit the limiter basically on light up. I'm set at 5600 on my shift light.
Old Apr 11, 2004 | 07:55 PM
I know that the stock tachometer is not completely accurate, so that must be the problem.
