Exhaust Question
Old Apr 10, 2004 | 07:10 AM
tormie's Avatar
Arrow Exhaust Question
Ok... I was wondering.. what is the stock Exhaust on a 1996 Camaro Z-28... the brand, headers and such... the one that gives the V-8 a kind of bubble gurgle noise... I'm curious to this cause I'm thinking of putting something like that on my Second Gen camaro...
thanx for the info on this exhaust type.
Old Apr 10, 2004 | 07:36 AM
The stock system has no headers and all the parts are just stock GM parts-no particular brand that I know of.
Old Apr 10, 2004 | 10:04 AM
tormie's Avatar
so if i take my car to chev. and tell them what i want they should be able to hook me up with the same thing then...?
Old Apr 10, 2004 | 06:56 PM
Got-LT1?'s Avatar
tormie,
chances are you wouldn't be able to get those parts to match up correctly, and if you could you probably wouldn't want them. Look for an inexpensive cat back exhaust and that will give you a much better sound and gain some performance as well. Trying to fit GM parts would be super expensive, your money would be better spend on a $300 Hooker cat back, or a $300 SLP Loud mouth
Old Apr 11, 2004 | 07:21 AM
nateh's Avatar
The stock cat-back was made by Arvin Exhaust for GM. This was a design specific to that car and pipe configuration. It's kind of restrictive for a performance application. The y-pipe/cat assembly was made by Delphi. I'm not sure who cast the manifolds.
Old Apr 11, 2004 | 08:00 AM
tormie's Avatar
Well its mostly to make the car quiet... everyone in this neighborhood is a B! and calls the cops when they hear the car running... not to mention the wife would like it to be quieter too...
Old Apr 11, 2004 | 09:43 AM
Steve0's Avatar
Try dynomax's website. They make quiet performance exhaust systems that still have a rumble to them. Itll sound and look better than a OEM system without being obnoxious. I'd also suggest running a set of headers on that car as opposed to the stock manifolds. They make a few kits for 2nd gen cars, depending on the application. You can get a set of dynomax coated long tubes from somewhere like jegs or summit for cheap.
http://www.dynomax.com/documents/pas...ral_motors.pdf
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
alex5366
Feb 17, 2015 09:07 AM
Chris Anderson
Jan 27, 2015 08:30 AM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
