Crank Shaft Sproket key!!!
Old Apr 10, 2004 | 04:57 PM
crashin001's Avatar
Do I have to have a key on the crankshaft to hold the timing sproket on or is it just pressed on?
Shawn
Old Apr 10, 2004 | 05:03 PM
slmdgmc's Avatar
Pressed, no key.
Old Apr 10, 2004 | 05:30 PM
crashin001's Avatar
So I just line the gey hole up with the notch in the crank timing gear and press it on?
Shawn
Old Apr 10, 2004 | 06:14 PM
Dave89IROC's Avatar
Originally posted by slmdgmc
Pressed, no key.
ummm
the timing sprocket does so have a key!
the balancer does not
Old Apr 10, 2004 | 06:47 PM
slmdgmc's Avatar
Whoops, didnt read it all the way through. Yes there is a key on the sprocket and on the shaft itself. There is no key on the hub itself.
Old Apr 10, 2004 | 06:51 PM
You also must have the correct cut-back key for the year LT1 you have. 93-95 uses one key and 96-97 uses another.
cyteone
Feb 7, 2015 06:04 PM
Chevyguy358
Jan 28, 2015 08:04 PM
