Split BLMs and car wont idle right...
Old Apr 9, 2004 | 05:22 PM
xxsaint69x's Avatar
what can be causing Left side to bottom out at 108 ? right is at 140ish. Also when i come to the stop the idle drops down to 400 before going back up. Drives me nutts.
Old Apr 9, 2004 | 05:59 PM
gb95zconv's Avatar
Hows your fuel pressure.....I had some wierd stuff like that going on when my fuel regulator crapped out.
Old Apr 9, 2004 | 06:00 PM
xxsaint69x's Avatar
fuel pressure is set at 48psi...i have a AFPR
Marcin
Old Apr 9, 2004 | 06:16 PM
gb95zconv's Avatar
I would back the fuel pressure down to 42 and see if your left BLM at least gets off the bottom limit where the pcm can control the fuel.
I would also check for a exhaust leak on the left.....false lean can cause fuel to be dumped resulting in a rich condition oddly enough.
Old Apr 9, 2004 | 09:15 PM
xxsaint69x's Avatar
no exhaust leaks as far as i can tell
Old Apr 9, 2004 | 09:29 PM
xxsaint69x's Avatar
hmmm....what can be causing my IAC values to be at 70 at idle (875 rpm) ? SHouldnt it be at around 30ish?
Old Apr 10, 2004 | 06:14 AM
xxsaint69x's Avatar
ttt
Old Apr 10, 2004 | 11:30 AM
xxsaint69x's Avatar
fiured out the split blms one of the o2s in on the way out. I am guessing that will also fix the idle
Marcin
Old Apr 10, 2004 | 01:12 PM
IrocSS85's Avatar
lets hope, let us know ifthat takes care of it. also, have you checked for vacuum leaks? if there's a vac. leak, the pcm will add fuel which will also make the iac counts shoot up and take out the 02s w/it. def. worth a check.
Old Apr 11, 2004 | 01:52 AM
92LT1RS's Avatar
Marcin
yup, thats exactly what was happening on mine. I had just replaced the drivers O2 a few days before, then I noticed my BLM's were split, each maxxed in opposite directions. Slight idle and hesitation prolblem. New passenger O2 solved both problems immediately.
Old Apr 11, 2004 | 09:20 AM
IrocSS85's Avatar
before that the 02's seemed to be reading and switching properly? seems like I should probably replace mine since they are at least 5 years old. who knows, maybe orig..
Old Apr 11, 2004 | 09:43 AM
xxsaint69x's Avatar
the way i traced it to the o2s is i swaped the o2s, when i did that my split blms swaped sides as well
SpeedJunkee
Jan 27, 2015 10:02 PM
Britbilly
Jan 7, 2015 08:49 PM
Cam's maro
Dec 28, 2014 09:30 AM
SpeedJunkee
Dec 9, 2014 10:17 PM
USAirman93
Nov 24, 2014 03:37 PM
