TB By Pass Question
Old Apr 12, 2004 | 02:06 PM
95Z28ConvertCam's Avatar
TB By Pass Question
is it possible for coolant to leak out the open nipples when the by pass is finished????
Old Apr 12, 2004 | 02:25 PM
Only a few drips of what might be left in the TB. Couldn't be much.
Old Apr 12, 2004 | 02:29 PM
There is no connection to anything internal to the throttle body. The coolant from one hose simply flows through a passage in the TB bottom plate, and flows out the other side. Once you remove the hoses there is no source of coolant inside the TB, so there is no way for coolant to leak out, except any drops left inside, as Rob/Shoebox points out.
Old Apr 12, 2004 | 02:37 PM
krispy's Avatar
just take a paper towel, put it on one end and blow from the other, will get rid of the excess
dluna333
15
Mar 13, 2015 12:30 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
T/A lt1
Oct 10, 2002 03:14 PM
guyomatic
Sep 11, 2002 02:11 AM
guionM
18
Jul 11, 2002 01:45 AM
