Ls1 brake conversion
Old Apr 12, 2004 | 04:54 PM
CodysRedZ's Avatar
What do i need for the conversion and how much is it going to cost minus the calipers?
Old Apr 12, 2004 | 05:07 PM
z28marine's Avatar
You need new brake pads, rotors, and the knuckles. Two of each. also, i would probably replace the lower ball joints, mine got screwed up on the install.
Old Apr 12, 2004 | 05:56 PM
ishz28's Avatar
Parts: as mentioned above. Plus three cotter pins, 2 med. 1 small
Costs: I bought a junk yard, spare knuckle (first one bent) for 50+tax. I rxcd other quotes from 60 to 100 per knucle. Rotors, IMO, just get a set of Bendix or wagner 30- 50 depending on store. DON'T cheap out on the brakes, I learned the hard way, they'll glaze the rotors quick. Hawk pads 85+tax. Use the brake lines that come with the LS1 calipers, that way you don't have to change the Bango bolts. Both lines are the same length. Just take the hard line brake that connects to the rubber line out of the bracket and bend it over. Make sure when your done that the tires don't hit the lines at all angles of the wheel. The hubs are interchangable.
Tools: 22mm 17mm and 15mm wrench, 13mm&18mm socket&rachet. Pliers, snub and needle nose. 2Lb. sledge or regular hammer. DON'T tap on the bolts you destroy the treads. ONE good tap on the upper A arm and tie rod, pull up of off the lower control arm.
Finally, get an alignment, if you think it needs one or not.
HarleyZ28
Oct 5, 2015 06:23 AM
Jasonz28camaro
Jun 7, 2015 09:14 PM
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
