Quick question about oil pan
Old Apr 12, 2004 | 09:27 AM
fstenuf's Avatar
I was just wondering if you can remove the oil pan without taking out the whole engine. I called a shop today and they said that i may need to take out the engine to drop it. Any help would be great.
Old Apr 12, 2004 | 09:34 AM
WS Sick's Avatar
No ! Some have been able to get it out by unbolting the motor mounts and raising the engine with a jack. I had to do that and loosen the K-mamber bolts about a half an inch to get mine out with the engine still in the car.
Old Apr 12, 2004 | 12:43 PM
KillWhitey's Avatar
I was not able to get mine off with a 6 speed. I couldnt get the engine high enough for the pan to clear the bottom of the tranny. It was close but no luck. I have heard that it is possible with an auto.
Old Apr 12, 2004 | 02:04 PM
sseeya's Avatar
That's what we had to do. We jacked the motor up as high as it would go and then loosened the k-member bolts to drop it a couple of inches.
Old Apr 12, 2004 | 04:24 PM
SweetZRag's Avatar
Same here with an A4. I just remove the motor mount bolts and jacked up the motor. Also removed the Y pipe and the flex plate cover. It came out fairly easily. Can't speak about the M6 though.
Old Apr 12, 2004 | 04:55 PM
Scream And Fly's Avatar
I did it without removing the engine. Just unbolted the mounts and raised it as high as it would go. I changed the oil pan gasket that way.
I had to replace the oil pump (oil pickup problem, decided to replace the pump), and I had the dealer do it this time around. Yeah, I spent $800 (including Mobil 1 oil change), but it was worth it to me. They ended up removing my Y-pipe and in the process replaced all the bolts. That will make my header install MUCH easier, now that all the bolts are new!
They even fixed an unrelated oil leak for me - for free. I was pleased.
Greg
Old Apr 12, 2004 | 07:38 PM
fstenuf's Avatar
so no luck with an M6 then eh? well crap!
Old Apr 12, 2004 | 07:55 PM
chy20k1's Avatar
yeah, i just did that this weekend with my auto. jack it up till the tranny hits the floor lol.
Old Apr 12, 2004 | 09:00 PM
will62085's Avatar
i did it yesterday with an m6 to change my oil pump...it sucked but its possible...it was a 13 hour job though!!...ahh it suck
i jacked hte motor up all the way, lowered the k member, loosened the strut bolts and it finally dropped enough to clear with the use of some force ...but hey it doesnt leak so whatever
Old Apr 12, 2004 | 09:02 PM
fstenuf's Avatar
13 hour job how long does it take to yank the motor and do it?
Old Apr 12, 2004 | 09:55 PM
Red96Lt1's Avatar
How hard is it to pull the K member. What do you have to unbolt?
Old Apr 12, 2004 | 10:39 PM
chy20k1's Avatar
wasnt close to a 13 hour job on my car but it an a4. never dealt with an m6 though. i can imagine it bieng alot harder since you can take the inspection plate off autos.
Old Apr 13, 2004 | 01:03 AM
Lt1t56's Avatar
I have an M6 and have had oil pan off. Before you start to remove pan remove low oil sensor so you dont break it off when lowering pan, anyway back to pan removal. You must lower K member about 3/4 inch by loosening bolts, then remove motor mount bolts then jack engine as high as it will go then pan will come out. If you have oil cooler you need to remove it also. Be carefull when engine is jacked all the way up put some wood blocks between engine mounts and K member in case something slips, you dont want to loose a hand or fingers.
Old Apr 13, 2004 | 09:20 AM
Red96Lt1's Avatar
What bolts hold the k member on? How many and where are they?
Old Apr 13, 2004 | 09:31 AM
WS Sick's Avatar
There are six of them (three on each side) get under and inspect the K member and you'll see them. Have I think a 20 mm head
