what wire for ACC on switch??
I'm wiring two illuminated switches in the ashtray area near the shifter. i'm replacing the CAGS switch and adding a switch for ASR reverse. anyways, since both the switches will be illuminated, i'm wondering what wire i can tap into to make these switches only illuminate when key is in the ON position?
TIA,
Ryan
TIA,
Ryan
There should be a switched +12V power source in the fuse block at the end of the dash.... a small square hole with a 0.25" male spade lug in it, labled "IGN"...... on the Pontiacs is right here where the orange wire is connected. In the Camaros, I think the block is upside down compared to the Pontiacs.
Jul 4, 2005 05:00 PM
